be quiet! Expands Pure Power 11 FM Series with 850 W & 1000 W Models
  • Ribbons : 84
2022/01/25 23:34:39 (permalink)
https://www.techpowerup.com/291322/be-quiet-expands-pure-power-11-fm-series-with-850-w-1000-w-models
be quiet!, the German manufacturer for premium PC components, is expanding its Pure Power 11 FM power supply range with two high-wattage models: 850 W and 1000 W. Pure Power 11 FM is aimed at mainstream computer users who appreciate the versatility of modular cables and 80 PLUS Gold efficiency up to 93.9 percent. The new high-wattage options are specifically aimed at value-oriented PC systems with high-end graphics cards.
At be quiet!, Pure Power stands for peerless dependability and a comprehensive feature set at a competitive price point. The new additions tot he Pure Power 11 FM series are no exceptions: by exclusively using fully modular instead of fixed cables, only cables that serve a purpose are installed, resulting in a smoother airflow, lower temperatures, and easier handling inside the case. Pure Power 11 FM comes equipped with black flat cables for all common connections and a black sleeved 20+4-pin ATX power cable. With two independent 12 V rails for signal stability, up to six PCI-Express connectors, and power output options now ranging up to an impressive 1000 watts, Pure Power 11 FM is fully suited for silent PC configurations and even gaming systems with a high-end graphics card.
Pure Power 11 FM is 80 PLUS Gold certified with an efficiency rating of up to 93.9 percent, a truly outstanding level for this PSU class. The most compelling benefits of this high efficiency are lower power consumption, lower electricity costs and a cooler, quieter operation. Pure Power 11 FM is equipped with LLC + SR + DC/DC technology for advanced stability and voltage regulation. Cooling is achieved with a silence-optimized 120 mm be quiet! fan with airflow-optimized fan blades, enabling the extraordinarily silent operation that be quiet! is famous for. As usual, all modern protection circuits (including UVP, OVP, SCP, OPP, OCP, and OTP) are integrated. be quiet! offers a 5-year manufacturer's warranty on all Pure Power 11 FM.
Pricing & Availability
The be quiet! Pure Power 11 FM 850 W and 1000 W will be available to purchase from February 8th.
  • Pure Power 11 FM 850 W - €124.90 $129.90 £109.99
  • Pure Power 11 FM 1000 W - €154.90 $159.90 £134.99
Hopefully there will be enough stock. The 5 year warranty is a bit weak in my opinion.
5 Replies Related Threads
    Hoggle
    Re: be quiet! Expands Pure Power 11 FM Series with 850 W & 1000 W Models 2022/01/25 23:55:27 (permalink)
    Normally the PSU fan only spins on most quality PSU when it’s near load so not sure how much noise would really exist in the first place unless you close to using the full load. I am not saying it’s not a quality product just that noise from the PSU probably isn’t the main source in the case in the first place unless you have a cheap PSU that doesn’t have an eco mode.
    Miguell
    Re: be quiet! Expands Pure Power 11 FM Series with 850 W & 1000 W Models 2022/01/26 02:03:03 (permalink)
    who makes these?  the real manufacturer?
    i already know they develop in Germany...
    They look nice actually! BeQuiet used to be ok in the past
    and yeah.. 5 years is very little warranty!
    ( SEASONIC gives 12 years  warranty )
    post edited by Miguell - 2022/01/26 02:14:13
    Case: Cooler Master Stacker 830
    Display: 32" AOC Q3279VWFD8 @2560x1440@75Hz
    Cpu: Intel Core i7-8700
    Cpu Cooler: Cooler Master - MasterLiquid ML120L - RGB
    Mobo: Asus ROG Strix Z390-H Gaming
    Vga: Asus Dual RTX 4060 Ti 16GB Advanced Edition
    Ram: 32GB DDR4  G.SKILL - RIPJAWS V @3200Mhz
    Sound: Hama uRage soundZbar 2.1 Unleashed  - (Optical)
    Storage: 500GB SSD M.2 A2000  NVMe  Kingston (OS) + 8TB (4+4) HDD X300 Toshiba (Data)
    Psu: SeaSonic M12 700W
    Os: W10 Pro 64Bit
    Flint 1760
    • Ribbons : 45
    Re: be quiet! Expands Pure Power 11 FM Series with 850 W & 1000 W Models 2022/01/26 03:54:52 (permalink)
    Based on the price and warranty, they are probably targeting builders on a tight budget.
    Miguell
    Re: be quiet! Expands Pure Power 11 FM Series with 850 W & 1000 W Models 2022/01/26 05:16:11 (permalink)
    Flint 1760
    humm i agree. these prices are very accessible
    my Seasonic M12 700W  ( 80% +) was around 230 euros in 2009!
     nowadays i could buy their top of the line fanless PRIME TX 850W  ( 80% titanium efficiency) for 260 euros with 12 years warranty
    its a good deal if you divide 260euros  per 12 years ( only 22 euros per year investment in a top notch psu)
    post edited by Miguell - 2022/01/26 06:22:57
    Os: W10 Pro 64Bit
    Ted-K
    Re: be quiet! Expands Pure Power 11 FM Series with 850 W & 1000 W Models 2022/01/26 05:30:26 (permalink)
    While this seems like a good deal I am sure that competition will arise with such products. Also 1000w gold is somewhat of a no no for me. If I am going big I rather get the 12years warranty and a titanium rating. I mean it's good for the low budget but if you need a 850w-1000w PSU you are probably getting top of the line GPU or CPU... maybe it's because you have to spend the majority of the budget on the GPU and have to save on the PSU... I dont know.
