Z590 FTW and Corsair 5000d Airflow front I/O audio pop
yavorsky
Tuesday, July 27, 2021 7:26 AM (permalink)
Hi all!
It's been a while since I've posted but I finally got my hands on some new parts! I put together the build in the Corsair 5000d case (boy was that a pain to build in; I would not suggest it with the z590 FTW board) and I wanted to see if anyone else experiences an audio pop when booting to windows through their front I/O headers. I guess I'm a bit worried that I may have damaged the case cable as there is literally zero clearance from the board to the power supply shroud.
All in all, the audio works and sounds great when all booted up but boy when I restart does my heart skip a beat when that audio pops.
Thanks for reading and looking forward to reading the replies!
9 Replies Related Threads
    random_matt
    Re: Z590 FTW and Corsair 5000d Airflow front I/O audio pop Tuesday, July 27, 2021 10:05 AM (permalink)
    What's wrong with the mobo/case combo? That's what I was going for.
    Corsair 5000D Airflow | EVGA 1000 G6 | EVGA X570 FTW | Ryzen 5800X | EVGA 360 CLC | Corsair 4000MHz 32GB|
    Corsair MP600 2TB | EVGA 3080 Ti FTW Hybrid | Alienware AW2721D | Windows 11
    • Ribbons : 86
    Re: Z590 FTW and Corsair 5000d Airflow front I/O audio pop Tuesday, July 27, 2021 11:08 AM (permalink)
    First check and see if you pinched an audio connection cable during the build process.
    B0baganoosh
    • Ribbons : 42
    Re: Z590 FTW and Corsair 5000d Airflow front I/O audio pop Tuesday, July 27, 2021 1:55 PM (permalink)
    Check this thread (and maybe a couple others from Nereus and Frank3d) for pictures of the issue as they've already been talking about this case's problems with this board.
    6Q6CPFHPBPCU691 is a discount code anyone can use.
    i9 13900k - EVGA Z690 Classy - Nvidia RTX 4090 FE - G.Skill 64GB DDR5-6000CL30  - WD SN850 2TB NVMe Gen4 - Be Quiet! Straight Power 12 1200W - Be Quiet! Dark Base 900 Pro. MO-RA3 420 Pro. Dark Palimpsest MODS RIGS post for build notes.
    appleripper
    Re: Z590 FTW and Corsair 5000d Airflow front I/O audio pop Tuesday, July 27, 2021 4:15 PM (permalink)
    I run the audio IN/OUT directly out of the motherboard back so I never bother to hook up the front audio and mic. Surprised to see so many people hooking up and/or using the front case audio ports.
    frankd3
    • Ribbons : 14
    Re: Z590 FTW and Corsair 5000d Airflow front I/O audio pop Tuesday, July 27, 2021 5:49 PM (permalink)
    You really can't avoid pinching it. See my picture.
    https://forums.evga.com/FindPost/3431020
    Although, I didn't pinch it on the shielded part of the cable.
    But I won't know what or if I damaged anything until I get a graphics card.
    Edit: Nereus was smart not to try.
    post edited by frankd3 - Tuesday, July 27, 2021 6:11 PM
    yavorsky
    Re: Z590 FTW and Corsair 5000d Airflow front I/O audio pop Tuesday, July 27, 2021 7:22 PM (permalink)
    Yeah, I looked at your image @frankd3 and it caused me to order a front panel replacement, haha. I think I pinched my cables too hard for the audio. In the end I'm going to be returning to my 750d airflow. I called corsair to get a USB 3.1 upgrade kit for the case so wish me luck on getting my hands on one!
    In general this case is just too tight for this mobo. Not only that, to answer random_matt's question, there is a SERIOUS order of operations when you're building in this case. A few things I recommend with the z590 FTW, plug in your audio and CPU power BEFORE installing anything else in the case (fans, AIO, etc). After that make sure to install the cable shroud (if you want it) before the AIO because oh my goodness it does not go back if you have the AIO installed. Last, plan out your PSU cables because it's impossible to plug anything in once it's set in the case.
    Other than that, I freakin' love the look of it but it just needs to be like a half inch longer on the top and bottom.
    Keep me updated if anyone experiences audio pops! I'm curious if it's the case or something that just happens with this board.
    post edited by yavorsky - Tuesday, July 27, 2021 7:25 PM
    kalsim
    Re: Z590 FTW and Corsair 5000d Airflow front I/O audio pop Tuesday, July 27, 2021 8:04 PM (permalink)
    I've got zero audio issues.
    11700K 5.0 2C / 4.9 8C | EVGA Z590 FTW 1.08 | EVGA RTX 3080Ti FTW3 Ultra | EVGA 750 G2 | 2x16GB DR G.Skill TridentZ 3600 CL16 @ 4266 CL16 Gear 2 | Samsung 980 Pro NVMe 1TB | Phanteks Evolv ATX | Alienware 34" AW3418DW
    frankd3
    • Ribbons : 14
    Re: Z590 FTW and Corsair 5000d Airflow front I/O audio pop Tuesday, July 27, 2021 9:01 PM (permalink)
    yavorsky
    I remember the cursing when I had to temporarily remove the cable shroud and the radiator was already in. Just couldn't get enough clearance for that little thing that helped locate the shroud. Had to take out all but two radiator screws and loosen those two and hold the radiator up in one hand while the other took out the shroud.
    Yep, one stinkin half in on that motherboard tray would have made all the difference.
    yavorsky
    Re: Z590 FTW and Corsair 5000d Airflow front I/O audio pop Wednesday, July 28, 2021 8:05 AM (permalink)
    Well, I just switched back to the Corsair 750d Airflow and Corsair found me an upgrade kit to enable the USB 3.1 mobo header! I'm happy to be back in a case with plenty of room. Though my audio pops are still there during the boot z590 splash screen. I'll keep an ear on it and see if it gets better or worse over time. Worse case scenario I'll RMA the board (it's much easier to pull it out of 750d case!). Thanks all for the feedback!
