Z390 Dark post code 7F after system freeze
dallemon
2019/02/23 09:39:45 (permalink)
Hi. :)
I have been running my new system with the Z390 Dark for a few weeks now.
9900K is delidded (direct die with der8auer OC-Frame) and running at 5,2@1,38 (-25 vdroop) but I felt temp could be better.
So I sanded the CPU die slightly with some very high grit paper (2500) and after a little while temps finally were reasonable (3 rounds of sanding and testing).
After the final round of sanding and testing I ran the CPU for a couple of hours gaming and running some benchmarks (3Dmark, Cinebench and so on) and the temps were much better.
Then I decided to check what max temps would be so I wanted to run Prime95.
As soon as i started running the small FFT test the system froze and upon reboot it will stop at post code 7F with no image on screen and then reboot after a few minutes.
When looking in the manual it just states that 7F is reserved for future use (not that helpful)
23 Replies Related Threads
    • Ribbons : 282
    Re: Z390 Dark post code 7F after system freeze 2019/02/23 11:00:08 (permalink)
    "7F after system freeze " OC to high or vCore to Low
     Memory Lock, what is your BCLK set to?
    Is the XMP Profile changing the BCLK Setting?
    post edited by bcavnaugh - 2019/02/23 11:02:15
    dallemon
    Re: Z390 Dark post code 7F after system freeze 2019/02/23 11:28:00 (permalink)
    I have tried using safe boot and reset CMOS, also tried using one of the other BIOS, nothing helps :(
    BCLK was left at 100 and XMP was 3200MHz.
    I have also tried leaving system unplugged from the wall for a few minutes.
    Starting to think that sudden CPU load may have killed the CPU, borrowing an i3 from a mate tomorrow to test.
    • Ribbons : 282
    Re: Z390 Dark post code 7F after system freeze 2019/02/23 11:33:58 (permalink)
    Pull the CPU and Check for Bent CPU Socket Pins.
    Re: Z390 Dark post code 7F after system freeze 2019/02/23 12:52:09 (permalink)
    Either your cpu is dead, or your os has corrupt files.
    wwxww
    Re: Z390 Dark post code 7F after system freeze 2019/02/23 13:46:23 (permalink)
    Unplug the system from the wall and remove your on board battery. The Dark holds power for a good while, so try that for 30-45min. Then plug in the system, insert the battery, and turn your power suppl on. After that, press the red clear cmos button and press the start button on the board. If that does not get you running, switch the bios toggle in the middle of the board to the middle position and repeat the clear cmos button and press the start button on the board. Should get you back up and running.
    post edited by wwxww - 2019/02/23 13:50:09
    mron0903
    Re: Z390 Dark post code 7F after system freeze 2019/02/23 14:06:01 (permalink)
    I ran into an issue where the direct die was not putting enough pressure on the socket. Try swapping back to the standard clamp socket and put your IHS back on. Hopefully that is your issue.
    dallemon
    Re: Z390 Dark post code 7F after system freeze 2019/02/23 14:42:51 (permalink)
    bcavnaugh: I will be sure to triple check the socket when I try a different CPU tomorrow, but I'm pretty sure that would have given issues immediately.
    Sajin: Not the OS as system doesn't even finish post. :)
    mron0903: I've already been into contact with EKWB previously when I was troubleshooting my bad temps, they confirmed that pressure should not be an issue.
    Thanks for all the suggestions, I'll continue looking into what is up with my system and will make sure to post back. I forgot the clamp socket at the office so I will have to go there and pick it up tomorrow.
    mron0903
    Re: Z390 Dark post code 7F after system freeze 2019/02/23 14:50:03 (permalink)
    We'll, putting back the stock socket is easy and definitely worth a shot. I was having an issue where my system would not post anything over 3200mhz on my RAM, no matter what I did. Luckily, someone posted on Reddit once they installed the direct die their system would no longer post at the same RAM profile as before. So I switched back and low and behold, I was able to post at my 3600 XMP.
    dallemon
    Re: Z390 Dark post code 7F after system freeze 2019/02/23 15:24:30 (permalink)
    I'll give it a try, have a nice copper IHS that I could put on it. But still need my stock socket which is at the office. :)
    I might also get some compatible screws to replace the stock ones on the waterblock.
    Re: Z390 Dark post code 7F after system freeze 2019/02/23 17:20:21 (permalink)
    dallemon
    Oh, so then how did you try safe boot?
    dallemon
    Re: Z390 Dark post code 7F after system freeze 2019/02/24 01:52:49 (permalink)
    dallemon
    It's not Windows Safe mode, but the motherboard has a button called safe boot, it's for booting with default settings if an OC is unstable. :)
    upunderdog
    Re: Z390 Dark post code 7F after system freeze 2019/02/24 06:20:49 (permalink)
    Hope your problem get solve
    wwxww
    Re: Z390 Dark post code 7F after system freeze 2019/02/24 10:23:29 (permalink)
    Fubar
    /thread
    • Ribbons : 282
    Re: Z390 Dark post code 7F after system freeze 2019/02/24 10:47:58 (permalink)
    See Post Below for corrected version https://forums.evga.com/FindPost/2926456
    post edited by bcavnaugh - 2019/02/25 11:23:05
    dallemon
    Re: Z390 Dark post code 7F after system freeze 2019/02/24 11:56:34 (permalink)
    So I remounted the original socket clamp, still gives 7F post code with my CPU.
    If I try with the borrowed CPU (8350K) I get an image, but machine doesn't finish POST, stops with some weird flickering between post codes, but the most visible is 04 which seems to related to CPU microcode.
    So pretty sure my CPU is dead, but will have to test in a different mainboard just to be sure.
    • Ribbons : 282
    Re: Z390 Dark post code 7F after system freeze 2019/02/24 13:49:06 (permalink)
    dallemon
    Let's hope your CPU is OK.
    EVGA_Lee
    Moderator
    • Ribbons : 14
    Re: Z390 Dark post code 7F after system freeze 2019/02/25 03:18:24 (permalink)
    dallemon
    dallemon
    It is a Small Red Button on our EVGA Motherboards sometimes called "BIOS Safeboot Button"
    Another reason why I like EVGA Motherboards, but some of the Lower End Motherboards do not have this Little Red Button.
    Like the Old Jumper that you would Short Out to reset the Bios back to the Defaults.
    Some have this on the Back I/O Panel as well
    Someone is not researching before Posting
    The same as the Clear CMOS Button & Clear CMOS Jumper
    Actually, you're confusing the Safeboot button with the Clear CMOS Button.  The Z390 DARK has one of each (technically, two Clear CMOS buttons).
    First EVGA board to have one.  The Safeboot button is black.
    • Ribbons : 282
    Re: Z390 Dark post code 7F after system freeze 2019/02/25 11:05:53 (permalink)
    EVGATech_LeeM
    dallemon
    dallemon
    It is a Small Black Button on Some EVGA Motherboards BIOS Safeboot Button" (Corrected)
    Some also have this on the Back I/O Panel as well but it is a Clear CMOS Button and is Red. (Corrected)
    Thank you for the update and correction, I was in a hurry due to another posters lack of knowledge of EVGA Motherboards
    Corrected Image, kind of hard to see the Color of the Button in the image.
    post edited by bcavnaugh - 2019/02/25 11:22:00
    dallemon
    Re: Z390 Dark post code 7F after system freeze 2019/02/26 12:16:54 (permalink)
    So after further testing, my CPU is dead.
    But I got my board to boot with the borrowed CPU, I did another remount of the clamp socket and after this it booted fine with the 8350K, no weird flickering post code :)
    Going to buy a new 9900K on the 28th and try again :)
    I'm so happy I didn't have to RMA my board that I have waited so long for. :)
    • Ribbons : 282
    Re: Z390 Dark post code 7F after system freeze 2019/02/26 12:50:21 (permalink)
    dallemon
    But Bummer about the CPU
    Re: Z390 Dark post code 7F after system freeze 2019/02/26 13:08:11 (permalink)
    dallemon
    Delirious
    • Ribbons : 61
    Re: Z390 Dark post code 7F after system freeze 2019/02/26 15:55:39 (permalink)
    you think it possible particulate matter got to the underside of the cpu and caused a short?  From all that sanding?  Has to be some fine dust around somewhere.
    "Be quick to listen, slow to speak and slow to anger"
    Affiliate Code XZUMV9TJW5
    Associate Code: 7PM43CU71IB2IAP
    education may be expensive but wait until you get the bill for ignorance
    A wise man once said that we can't make anyone feel or do anything. We can throw things into the wind, but it's up to each person to decide how they want to react, where they want to stand when things fall.
    #23
    dallemon
    Re: Z390 Dark post code 7F after system freeze 2019/02/27 02:04:59 (permalink)
    Delirious
    It's definitely not impossible, but I did make sure to wipe it thoroughly with isopropyl alcohol and wash my hands afterwards, also I did the lapping in a different room.
    So I'm quite sure I just messed up and slightly overdid the lapping.
    #24
