geremymsantos
Hello! Had a few questions as a first time builder. I recently completed my build and loving it so far, but I noticed 2 things that are strange to me. 1. When the power supply switch is turned on, the Red LED light near the CPU and 8 pin remains on until I actually turn the PC on using the front I/O on the case. Is it normal for the Red LED light to remain on when the PC is turned off? I worry because that light is meant to indicate a warning according to the manual. I spoke to an EVGA representative and told me the latest BIOS should turn this off but it hasn't. 2. When the power supply switch is turned on and I power the pc using the front I/O, the PC turns on for about ~2 seconds, turns off for about ~2 seconds, then boots normally. This only happens if I turn the power supply switch off and then on. If I leave the power supply switch on, this doesn't happen. Is this normal? Any insight would be great. I'm hoping these are both normal things and I'm just being a little paranoid as a first time builder. My parts: i7 8700k (no overclock) evga z370 ftw mobo g skill ripjaws v series ddr 3000 with XMP profile 1 turned on evga gtx 1080 ftw samsung 860 evo ssd 2.5" evga 650 g3 noctua u12 cpu cooler s340 elite case BIOS up to date Thanks!
whisperingshadow
Re: Z370 FTW - Boot and CPU Red LED Issues
2018/05/23 10:40:25
Finished my similar build last night. I will have to check these. #2 for sure i will have to check geremymsantos Hello! Had a few questions as a first time builder. I recently completed my build and loving it so far, but I noticed 2 things that are strange to me. 1. When the power supply switch is turned on, the Red LED light near the CPU and 8 pin remains on until I actually turn the PC on using the front I/O on the case. Is it normal for the Red LED light to remain on when the PC is turned off? I worry because that light is meant to indicate a warning according to the manual. I spoke to an EVGA representative and told me the latest BIOS should turn this off but it hasn't. 2. When the power supply switch is turned on and I power the pc using the front I/O, the PC turns on for about ~2 seconds, turns off for about ~2 seconds, then boots normally. This only happens if I turn the power supply switch off and then on. If I leave the power supply switch on, this doesn't happen. Is this normal? Any insight would be great. I'm hoping these are both normal things and I'm just being a little paranoid as a first time builder. My parts: i7 8700k (no overclock) evga z370 ftw mobo g skill ripjaws v series ddr 3000 with XMP profile 1 turned on evga gtx 1080 ftw samsung 860 evo ssd 2.5" evga 650 g3 noctua u12 cpu cooler s340 elite case BIOS up to date Thanks!
i7 8700k,z370 FTW, Ballistix 32gb ddr4, 3080 Hybrid ftw ultra, 2x-512gb 970 evo, Lian Li o11 Dynamixc XL, clc 280, 850 G3, z370 FTW, 27" Predator IPS Gsync https://www.3dmark.com/3dm/57041776? Associate code for a discount for you BGEX2DBF0D (old/rebuilt)"RE-VGA" i7 8700k,z370 FTW, Ballistix 32gb ddr4, 1080 Hybrid, 2x-512gb 970 evo, DG77, clc 280, 850 G3, z370 FTW, 27" Predator IPS Gsync (old Pc)q6600 @ 3ghz Evga 680sli win10 with 8gb Ram,60gb ssd(OS), 74gb raptor(game), 320gb sata (storage)Evga GTX 980 sc,750w PSU
2018/05/23 10:42:28
1. Wouldn't worry about it as long as your pc is working normally. 2. Yes, that is normal on some motherboards.
remisuxx
2018/05/23 12:31:35
Hi, for the LED "issue" i got the same, but its ok, i think its just because you have your power supply connected to the electrecity. For the second "issue" that normal, when you turn off your power supply, the "memory" (i don t really know if its the memory or something else) who take the bios configuration , loose this information, when you switch on your power supply, the bios send to the "memory" is own configuration so you got an other boot to boot normally.
KenMcC
- Ribbons : 21
2018/05/23 14:36:28
KenMcC Z170 Classy K; i7-6700 CPU, Corsair CMK16GX4M2A2400C14 Seasonic SSR-360GP 360W; Samsung 950 Pro M.2 256 GB Samsung 850 Evo 500 GB SATA Samsung 850 Evo 256 GB SATA Samsung SSD 840 Series 250 GB SATA Samsung 860 EVO 1 TB SATA Windows 10 x64 Prof.
Cordorb
2018/05/23 17:48:37
There is off and then there is OFF :-) Some power supplies and BIOS have that EU option which may cause some items to be different. --- As a young kid I wondered how the TV knew I picked up the remote and pushed the on button if it was OFF. ours was an Ultrasonic remote controls with no batteries and used air blowing on an air tube ie a dog whistle ---
cjsquirrel
2018/05/23 18:22:29
geremymsantos 1. When the power supply switch is turned on, the Red LED light near the CPU and 8 pin remains on until I actually turn the PC on using the front I/O on the case. Is it normal for the Red LED light to remain on when the PC is turned off? I worry because that light is meant to indicate a warning according to the manual. I spoke to an EVGA representative and told me the latest BIOS should turn this off but it hasn't. 2. When the power supply switch is turned on and I power the pc using the front I/O, the PC turns on for about ~2 seconds, turns off for about ~2 seconds, then boots normally. This only happens if I turn the power supply switch off and then on. If I leave the power supply switch on, this doesn't happen. Is this normal? Any insight would be great. I'm hoping these are both normal things and I'm just being a little paranoid as a first time builder.
1) I have the Z370 Classified with the same red led lit with computer off. No issues whatsoever. 2) Had a Z270 Classified that did the boot then off then boot again if I had the power supply unplugged first. Had the board for a year and always ran like a champ! Only sold it to do a new build. Your system is fine so no worries.
geremymsantos
2018/05/23 19:00:54
First of all- wow! Didn't expect to see these many replies. Makes me confident and glad in my decision to go Team EVGA. Great experience as my first post. Second- Thanks for the answers and for reassuring me. Easily worried about my pc as a first builder, so now I can perhaps sleep a little easier. :P
stockjunkee84
2018/06/10 15:27:23
Had a z370 ftw die one me and got a replacement from EVGA. The old board did do the on for a second.. Off then back on. But now I have the same red led 12v error and my boot time on m.2 is very slow as well as my 8700k not boosting to 4.7 like it used to. Been with evga a long time but this is seriously annoying.
OGCrescent
2018/11/02 02:46:20
Weil, I ve completed my System yesterday and after pressing the on button my mainboard started to blink red, showing (30,53,FF) does someone have any Advice?
- Ribbons : 282
2018/11/02 10:15:33
OGCrescent Weil, I ve completed my System yesterday and after pressing the on button my mainboard started to blink red, showing (30,53,FF) does someone have any Advice?
Create your own Thread and list all of your Hardware by Make and Model/Part Number and so on. You should do this to not derail or highjack this thread from the Original Creator. Is my Z370 Broken?
