Hello
History . The keyboard works with the setting 6 month. Then suddenly yesterday the keyboard light went off. I sat in front of the keyboard the hole time. I changed the Profile with "FN + 1- 9" to an other configured Profile, but no keycap light.
Settings now ,i cant remeber the old on because i have reset the settings.
TOF = "on or off", Time = 0S , None
Leaving = Time = 10s , dark
Distance = 120 cm
These setting should do in TOF = on ." after leaving the 120cm area the led lights for 10sec and then they go dark. or?
If i have "TOF = 0ff" = i have light. If i change to "TOF = on" and push the "Apply Button", i have immediately no light
Can i use TOF only in the mode "Lighting Effect - Preset" and not in the mode "Lighting Effect - Custom"?
post edited by freeasabird - 2021/11/09 06:20:33
