TheAverageJoe93
This wasn't an issue for me, but my buddy had recently bought an EVGA Power Supply (750 G2) and had his old Sata Power Cables still connected to his HDDs. Although they have the same 6-pin connector, the layout of the wires are different between EVGA and Corsair (his old PSU). So it bricked his HDDs. (I'm not tracking if any other components were harmed.) My question is, why isn't power cables/psu connectors standardized? This seems like a HUGE issue for someone who has never don't a computer build before, and a buddy gave him some power cables and they aren't compatible. This is especially concerning, considering all these proprietary cables look IDENTICAL. I know for some manufacturers, they have a label printed on their cables stating what PSU they're compatible with, but I think this is completely unnecessary, just make all the cables the same?
NZXT S340 White Case / i7 6700k 4.6GHz / EVGA GeForce GTX 1080 Ti (Watercooled NZXT Kraken G12 w/ Corsair H50) / Corsair H60 / CORSAIR Vengeance LPX 16GB / ASRock Z170 Extreme4+ Motherboard / Corsair CX-M Series CX650M PSU / NZXT HUE+ / 500GB Samsung 750 EVO / 1TB WD Blue HDD / 2TB WD Blue HDD Firestrike Ultra=7,265 www.3dmark.com/fs/12822036 Firestrike=21,550 www.3dmark.com/fs/12822078
loveha
- Ribbons : 65
Re: Why aren't all modular power supply cables standardized?
Monday, April 10, 2017 6:32 PM
I have been wondering the same thing. It's incredibly stupid that they are not. Everything else pretty much is.
Case - Phanteks Enthoo Evolv XMobo - EVGA X570 FTWCPU - AMD Ryzen 9 5900XRAM - 32GB Trident Z Royal 3600MHz 14-14-14-34GPU - EVGA RTX 3080 Ti FTW3 Ultra GamingPSU - Seasonic Prime TX-1000Heatkiller IV CPU Waterblock / Heatkiller V GPU WaterblockHeatkiller V EBC Active Backplate / Two Heatkiller Rad 360 L Six Noctua NF-A12x25 / Heatkiller D5 Pump
TheAverageJoe93
Monday, April 10, 2017 6:40 PM
loveha I have been wondering the same thing. It's incredibly stupid that they are not. Everything else pretty much is.
Maybe if the connectors were substantially different from each other, but they aren't. I was so sure that companies wouldn't try to intentionally differ from each other in this regard, but they don't. I was totally shocked, especially since they look IDENTICAL! lol
- Ribbons : 123
Monday, April 10, 2017 7:01 PM
The PSU outputs (pinouts) are where the differences are MFG continue to make power supplies that have different positions for the different voltages and grounds on their pinouts The cables correct /adapt the PSU pinout to fit the Standards used on the hardware end of the cables I am willing to bet that mfg all use the standard modular plugs for their PSU outputs for the economy of standard parts - that is why they fit even if they are not wired correctly for the PSU. Always Only use the wires that came with your PSU ----> or confirm they are compatible FIRST
TheAverageJoe93
Monday, April 10, 2017 7:13 PM
Cool GTX The PSU outputs (pinouts) are where the differences are  MFG continue to make power supplies that have different positions for the different voltages and grounds on their pinouts The cables correct /adapt the PSU pinout to fit the Standards used on the hardware end of the cables  I am willing to bet that mfg all use the standard modular plugs for their PSU outputs for the economy of standard parts - that is why they fit even if they are not wired correctly for the PSU. Always Only use the wires that came with your PSU ----> or confirm they are compatible FIRST
I know, I agree, I do the same thing. I'm just worried about the people who have never built a computer before. As far as they are concerned the 6-pin/8-pin connectors all look the same. I just don't understand why MFG cannot come to some standardization to help consumers. The thing about building computers nowadays is that they are essentially plug and play, this defeats that notion by saying that the same plugs aren't the same, and they aren't that distinguishable in nature (to someone who is new). Idk, seems rather stupid to me. That's all.
20213763057143
Monday, April 10, 2017 11:53 PM
Hmmm. I got that same PSU but used the new cables instead of anything old. Didn't knew about the compatibility part though!
MonkJayn
Monday, April 17, 2017 3:37 AM
That is a nasty trap to fall into
Mrquick92
Monday, April 17, 2017 3:57 AM
While the cable connectors are almost identical, the internal wiring within the power supplies are not. Some cables from PSU brands even have resistors inside of the cables to reduce noise to the components.
May our framerates be high and our temperatures low. Case: Corsair Obsidian 750D | MoBo: ASUS Maximus VI Hero | CPU: Intel i7 4770k @4.3GHz | Memory: Corsair Vengeance Pro 16GB @ 2133 | GPU: EVGA GTX 1080Ti FTW3 | Storage: SAMSUNG 850 EVO 500GB, WD Black 2TB | PSU: Corsair HX850i 850W | Cooler: Corsair H110i GTX Cooler | Monitor: ASUS ROG Swift PG279Q 1440p @144hz | KB: CM Storm QuickFire Pro | Mouse: Logitech G403 Prodigy Wireless | Headphones: Beyerdynamic DT 770 PRO My Affiliate Code: 3DE52OR4ZM
TheAverageJoe93
Monday, April 17, 2017 1:38 PM
Mrquick92 While the cable connectors are almost identical, the internal wiring within the power supplies are not. Some cables from PSU brands even have resistors inside of the cables to reduce noise to the components.
Right, I understand. Just seems odd that they would do that, that's all.
MonkJayn
Tuesday, April 18, 2017 7:05 AM
would make alot of sense to have them standardised and it would make swapping out psu's a hell of alot easier if need be lol
Mrquick92
Tuesday, April 18, 2017 8:42 AM
MonkJayn would make alot of sense to have them standardised and it would make swapping out psu's a hell of alot easier if need be lol
Just had to do a RMA on a PSU and it would have been nice if just the main PSU was needed. MonkJayn, Are you using any aftermarket cables such as cablemod? I was thinking of replacing the cables once I get a 1080ti.
MonkJayn
Tuesday, April 18, 2017 8:48 AM
Not yet, i keep looking at all the different options, full sets, extensions and brands, right now i have a g2 850, and i think, it'll just about be ok for the 2 ti's i have ordered, but i know it won't be up to the job of my next upgrade to skylake x, more ram and watercooling, so I'm holding off on buying any cables until i am set on the PSU I'll be running, I'm just gutted a couldn't get one of the anniversary Corsair white 1000w ones, would of made life easier. Right now though, a full set from evga along with a 1200w g2 PSU is looking to be the front runner option (i keep seeing people with issues with the g3's while my g2 has worked perfectly this whole time)
robkent2002
Wednesday, April 19, 2017 11:26 PM
If I had to guess I would most definitely say that it's so you buy whatever manufacturers product. Like Apple and their stupid idiotic USB adapters, why not use industry standard USB connections? So you have to buy their product with a markup of 200% or whatever over what it takes to manufacture and warehouse that particular product. Or Dell and HP power adapters for laptops. A PC power supply outputs very specific voltages, why do the connectors have to be pinned differently? Because they want to be different so you have to buy their proprietary product. I don't like paying $300 for a premium product only to have it cause compatibility issues. Maybe I'm just ranting, but I would expect a certain amount of latitude from manufacturers that produce products for industry standard components.
Hoggle
Monday, April 24, 2017 5:41 AM
The problem is Corsair has failed to meet the EVGA standard for power supply cables.  Really it would be great but the problem is someone would want to make money off the standard. It's always best I feel to replace the cables otherwise you can bet that some company would want a nickel for every cable using the standard which gets passed onto the end user.
veganfanatic
Wednesday, March 11, 2020 2:55 AM
I use Corsair and I have 2 styles of cable, one are braided sleeved, the other is a banded style. Corsair cables are pretty much interchangeable. Now what I do not know is how the EVGA pinout varies compared to Corsair?
 Corsair Obsidian 750D Airflow Edition + Corsair AX1600i PSUMy desktop uses the ThinkVision 31.5 inch P32p-20 Monitor.My sound system is the Edifier B1700BT
Dukman
- Ribbons : 6
Wednesday, March 11, 2020 2:24 PM
veganfanatic I use Corsair and I have 2 styles of cable, one are braided sleeved, the other is a banded style. Corsair cables are pretty much interchangeable. Now what I do not know is how the EVGA pinout varies compared to Corsair?
Compare the 24 pin pin out at the PSU side of things. Or as the OP stated, the 5 wire pin out of the SATA cables at the PSU side. I would bet that you see wires crossing to different pins from one brand to the other. IIRC, the SATA's on the EVGA are 1 to 1.
- Ribbons : 123
Wednesday, March 11, 2020 4:05 PM
transdogmifier
- Ribbons : 18
Wednesday, March 11, 2020 4:15 PM
- Ribbons : 271
Wednesday, March 11, 2020 9:35 PM
Not resistors. Capacitors.
Hillguy
- Ribbons : 10
Thursday, March 12, 2020 10:24 PM
Duckman is right veganfanatic be very careful mixing cables even from the SAME manufacturer. Personally I would NEVER MIX CABLES unless the psu's are identical. New PSU , use the new cables and toss the old ones out with the old psu , it's not worth the risk , if the psu gave out the cables are old and may also be damaged , toss em  . I attached a couple of photos to illustrate ... they are both Corsair flat sata cables but are very different at the pin out , and you can also see they are marked from the factory what psu they belong to.
post edited by Hillguy - Thursday, March 12, 2020 10:26 PM
eVGA RTX 3090 Kingpin Hydrocopper | eVGA X299 Dark | Intel i9 10980XE | Heatkiller IV CPU Block | 32 GB GSkill Trident Z 3200 | 500GB Samsung 860 Evo | Dual Corsair AX1200i PSU's | Dual Koolance RP-1000 Pumps | Dual Koolance EHX-1320 4x120mm Rads | W10 | Asus PB278Q | Acer 20" | Razer Death Stalker | Razer Death Adder | Thermaltake Armor+
veganfanatic
Hillguy
- Ribbons : 10
Thursday, March 12, 2020 10:39 PM
veganfanatic
Thursday, March 12, 2020 10:50 PM
Hillguy https://www.evga.com/supp...AQdetails.aspx?f=59698
by the look of it, unlike Corsair, EVGA does not want to come clean with cable differences my AX860i croaked and Corsair gave me an HX1000i as a replacement, all cables are interchangeable, only the oldest PSUs are a worry for Corsair. The Corsair chart is published on their form as well as on their website. This means I have an abundance of cables, which is not a problem as I use Corsair because they are straight shooters. My old TX850V2 lasted for 10 years before I retired it.
post edited by veganfanatic - Thursday, March 12, 2020 10:53 PM
NeoCrisis
Thursday, March 12, 2020 11:22 PM
veganfanatic
What are you talking about. The EVGA B3/B5/GA/G2/G3/G5/GP/GM/P2/PQ/T2 all have compatible cables. That is basically their whole current line of modular power supplies, minus maybe 1 or 2.
veganfanatic
Thursday, March 12, 2020 11:44 PM
I could not determine that from the page. Maybe a clearer page would be better.
- Ribbons : 115
Tuesday, February 23, 2021 5:09 AM
Because that limits the freedom of the engineers in how they design the pin outs on PSU's, and the industry only requires that one end be standardized. The part of the cable that plugs into the components. Different model PSU's need different cables with different resistors/caps etc.
EVGA_Lee
Moderator
- Ribbons : 14
Tuesday, February 23, 2021 9:59 PM
Man, way to necro a thread like a pro, Xray. I can't really tell you why there's no industry standard for power supplies. If I had to guess, it's because companies still want to be a bit more careful and have full control over the actual power-side of a power supply; you know, the component that handles a lot of power that converts and puts power into your rig. I can't imagine a pin-out standard would affect the engineering by any real measure, but companies might want to experiment with options to improve efficiency, compatibility, and ease of use over time. For example, you can see how the ATX 24pin connector on our power supplies went from 24pin -> 24+4 pin -> 18+10pin over several generations. That's not including our G2L power supplies with the completely universal connectors which eliminates this problem entirely. More than a few people here have a soft spot for that arrangement. Regardless, after G3 rolled out, we decided that all new modular and semi-modular power supplies would use the same pinout. This still leaves a few compatibility issues with older power supplies, but over the long-term, it will become easier to point out the power supplies that are not compatible with the master pinout than the need to post 15 different series that are compatible with each other.
