yandt
Hello, In the past week or so the fan over the PCH on my x299 dark started doing so much noise i can't be in the room with the computer powered on and I'm starting to go crazy. Please help me resolve the issue i tried everything setting different settings in the bios for the fan, set it back to default, pressing the center of the fan to align it, i also tried to gently pull it, i tried to use a whole compressed air duster can on it, but nothing helped. Where can i buy a fan like this or maybe replace the cooling mechanism to a water block as i am water cooling the whole system. Thank in advance I can upload an audio file I recorded of the noise if it will help, just let me know where
Re: Very annoying noise from pch fan X299 dark
2020/05/12 17:56:57
☄ Helpfulby yandt 2020/05/13 01:19:34
The fan doesn't have a part # on it?
jasoncodispoti
- Ribbons : 14
2020/05/12 18:11:28
I would reach out to EVGA.. Pretty sure they are 30mm fans, which I dont think is standard... typically 40mm is what is used and can be purchased from places like Nocuta for example.
post edited by jasoncodispoti - 2020/05/12 18:14:15
Intel Core i7-9800x | EVGA X299 Dark| EVGA RTX 2080ti FTW3 Ultra HydroCopper | 32GB Corsair Dominator Platinum | EKWB Liquid Cooled Loop | Phanteks Enthoo Primo SE | EVGA SuperNOVA 1000 P2
jasoncodispoti
- Ribbons : 14
2020/05/12 18:17:02
☄ Helpfulby yandt 2020/05/13 01:19:44
I didnt read your post correctly... Sorry. I would still reach out to EVGA, I am not sure of the exact size of the PCH fan, but Noctua may stock a replacement for it.
yandt
2020/05/13 01:22:59
Thanks for the replays Sajin The fan doesn't have a part # on it?
I don't think so, but i didn't really tear down the whole mechanism yet. jasoncodispoti I didnt read your post correctly... Sorry. I would still reach out to EVGA, I am not sure of the exact size of the PCH fan, but Noctua may stock a replacement for it.
Yes, you're right, thanks, i will contact EVGA.
xuqi99
2020/05/13 01:25:52
FunktasticLucky
2020/06/05 11:10:38
I feel you. My pch can too has started making anoyingly loud clicky buzzing noise. I'm going to contact EVGA to see if they can just send me a replacement. I'll swap it out the next time i clean out my water loop. I hope for now it's alright to just leave it off.
DEJ915
- Ribbons : 11
2020/06/06 15:53:55
FunktasticLucky I feel you. My pch can too has started making anoyingly loud clicky buzzing noise. I'm going to contact EVGA to see if they can just send me a replacement. I'll swap it out the next time i clean out my water loop. I hope for now it's alright to just leave it off.
Yeah it doesn't need it, the fan is mainly for the M.2 cooling feature. If you unplug the fan though you can take off the plastic shield so it has better air flow around the metal part though.
ZoranC
- Ribbons : 16
2020/06/07 14:34:21
xuqi99 Somewhat annoying they decided to go with a 30mm fan, as the smallest Noctua make a 40mm. https://noctua.at/en/products/fan
Agreed. I keep looking at that fan as something seems to be creating noise in that area and I keep constantly wishing I could replace it with Noctua 40mm.
Leok6
2020/06/15 11:54:21
Raptorius84
2021/06/22 18:44:04
Has anyone had any luck resolving this issue or finding a replacement? I just bought a used board on eBay indicated to be in working condition and this fan is going crazy.
Krazy_K
2021/06/23 07:50:55
i have the exact same problem.
brazil
2021/06/24 05:07:26
I had a similar problem, removed the cover from the motherboard and dropped oil on the fan axis and the noise disappeared
cdigan
2021/06/30 11:03:35
brazil I had a similar problem, removed the cover from the motherboard and dropped oil on the fan axis and the noise disappeared
Which screw(s) did you remove in order to get at the fan to do this? There's a small screw on the shroud near the fan and it looks like there might be someone on the back of the board holding it on as well (I really don't want to unmount my MB if possible if I can remove a screw from the front). Like the OP, the noise is driving me crazy as well with my x299 Dark MB.
brazil
2021/06/30 12:41:17
cdigan
you need to remove the cover, then unscrew the three screws to remove the fan
cdigan
2021/07/01 07:52:17
brazil
cdigan
How did you remove the shroud though? I can see the three screws that hold the fan down itself, the problem is getting the shroud off to be able to get to the fan.
brazil
2021/07/01 08:23:35
cdigan
brazil
cdigan
how to remove the cover, see the manual, page 43. After removing the cover, you will need to carefully disconnect the fan power from the motherboard. Then you can unscrew the fan
brazil
2021/07/03 03:58:22
cdigan
brazil
cdigan
Update After you remove the shroud from the motherboard, you will see a fan. The fan can now be removed by hand.
markedpk
2021/07/24 13:34:18
Any luck with the fixing part?
Leok6
2021/07/26 07:12:09
ZoranC
- Ribbons : 16
2021/07/30 12:21:45
Today I too started getting grating noise from PCH fan on motherboard that has been in use for less than few months. This is VERY upsetting as part is not designed to be serviceable without completely tearing whole system apart. That to me is extremely poor design.
Raptorius84
2021/10/04 17:03:19
Can anyone confirm if the above link to the fan on ebay is the correct size? I may get it just to have a back up since the fan seems so unreliable.
ZoranC
- Ribbons : 16
2021/10/04 17:26:59
Raptorius84 Can anyone confirm if the above link to the fan on ebay is the correct size? I may get it just to have a back up since the fan seems so unreliable.
Part number on eBay fan is exactly same one as on fan that is on my X299 Dark.
Captain Sternn
2024/08/25 01:48:28
So my x299 Dark Mother board fan has been really loud lately for the past couple months, I found a fix, I taped a toothpick next to the fan, the end of the toothpick lightly brushes against the center of the fan somehow cancelling the noise, it's as quiet as it was for the 6 or so years I had it.
