Unable to control fan speed with either of my gtx 480
alanwest09872
2012/08/02 05:46:54 (permalink)
Ok so on my gtx 480's I have 0 control over fan speed on either one. I just did a fresh install of windows 7 64bit. Ive tried installing both the newest and the beta drivers from nvidia. I tried to control the fan speed with msi afterburn, evga precision, and nvidia system tools.
All the software says that the fans arnt spinning at all but I can put my hand in and feel it spinning? So what exactly is going on here I dont understand what is wrong with this.
My current relevent hardware is
1 evga 760 motherboard
2 Core I7 something processor
3 2 gtx 480 gpus
4 1500watt thermaltake psu
Core I7 965
Evga 760
Intel x25-m 80g, 2 veloraptor 300gig raid
2 x 480gtx
Corsair Dominator 12g Triple channel
1500watt thermaltake powersupply
Pioneer Burner sata
H50 Liquid Cooling
Thermaltake Xaser case
45 Replies Related Threads
    ransan309
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 09:07:27 (permalink)
    Do you currently have both Afterburner and Precision installed? If so....You should try unistalling both, then re- install just one. I prefer Afterburner ,over the new PrecisionX, because it was creating some issues with my cards. If not. I`d still try re-installing the monitoring software, and see if that helps.
    Go back in and see if you can set-up a fan profile.
    Do the cards appear to be functioning properly aside from this issue?
    Gigabyte GA-Z97X-Gaming GT. 4790k at 4.4Ghz. W/ XSPC Raystorm Block
    G Skill ARES PC3-19200 16GIG. @ 2400Mhz
    EVGA 980TI Classified/ w. EK-FC780 Classy Block EVGA GTX 780ti REF. W/ EK-FC780ti Copper/Plexi
    Block (Physics)        (Single Loop) EK-Coolstream 360
    Encrypted_God
    • Ribbons : 7
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 09:12:12 (permalink)
    MSI GTX-480+MSI Afterburn=OK
    MSI GTX-480+EVGA Precision=Not OK
    Correct me if I'm wrong but I don't think the Precision X isn't compatible with ANY other brand than EVGA. So that's probably why you're not seeing any fan speed reports via Precision X.
    As far as the MSI Afterburn? Hm...I can't touch on that. I'm a die hard fan of EVGA Products. But let's try and get it fixed anyways shall we? Have you tried just one program at a time? Or are you trying to use them all to see results
    • EVGA X99 Classy
    • EVGA GeForce RTX 3070
    • EVGA Supernova 1000G3
    • EVGA X17 Mouse
    • EVGA X12 KB
    • Samsung 850 Pro SSD Win.10 Dedicated
    • Cooled with Koolance LIQ-702
    ...and all kinds of goodies
    ransan309
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 09:21:42 (permalink)
    My understanding is that both are designed by the same person, and should work on any reference GTX 480. However; For some reason PrecisionX really conflicts with my clocks, even though I am running 2 EVGA GTX480 SC cards. This is just my own personal issues, and wouldn`t reflect the same results for all users.
    Does sound like there may be a conflict with trying to run multiple monitoring programs.
    Encrypted_God
    • Ribbons : 7
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 09:46:02 (permalink)
    ransan309
    Agreed. So try ONE at a time. I would first uninstall Precision X
    • EVGA X99 Classy
    • EVGA X17 Mouse
    • EVGA X12 KB
    alanwest09872
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 09:57:52 (permalink)
    guys i only have precision installed i dont have both. I will try to delete precision and install afterburn to see if that helps anything
    Core I7 965
    Evga 760
    2 x 480gtx
    Pioneer Burner sata
    H50 Liquid Cooling
    Encrypted_God
    • Ribbons : 7
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 10:04:38 (permalink)
    Maybe uninstall the nVidia tools too. But I'm hoping a Mod or Jacob can jump in here and confirm that the afterburn is not compatible with a evga card.
    • EVGA X99 Classy
    • EVGA X17 Mouse
    • EVGA X12 KB
    alanwest09872
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 10:21:23 (permalink)
    OK sorry I should have been clear. I had precision installed first. After that didn't work I installed nvidia tools. Which didn't work either. I am able to change clock speed and stuff just not the fan speed. And it won't show me gpu temp. Sorry I hope I made that clear
    Core I7 965
    Evga 760
    2 x 480gtx
    Pioneer Burner sata
    H50 Liquid Cooling
    Encrypted_God
    • Ribbons : 7
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 11:19:27 (permalink)
    Can you please list your full specs. While you're at it, Use it as your sig as well.
    • EVGA X99 Classy
    • EVGA X17 Mouse
    • EVGA X12 KB
    ransan309
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 11:33:37 (permalink)
    Encrypted_God
    Just for clarification: Afterburner WILL work with EVGA, because I have been using it with 2xEVGA GTX480SC cards for several months with very few issues. I am definitely no expert on anything.But! I do know it works
    Encrypted_God
    • Ribbons : 7
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 12:14:04 (permalink)
    ransan309
    ah..ok.
    • EVGA X99 Classy
    • EVGA X17 Mouse
    • EVGA X12 KB
    alanwest09872
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 12:28:00 (permalink)
    ok my full specs are
    Core I7 965
    Evga 760
      2 x 480gtx
    Pioneer Burner sata
    H50 Liquid Cooling
    Core I7 965
    Evga 760
    2 x 480gtx
    Pioneer Burner sata
    H50 Liquid Cooling
    alanwest09872
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 12:39:50 (permalink)
    FYI i just tried afterburner and same issue. It will not allow me to increase the fan speed. Its kind of greyed out. Is there any setting in windows that would account for this. Did I accidently turn off something I shouldnt have
    I'm really hoping someone can help. I'm dieing to play dayz
    post edited by alanwest09872 - 2012/08/02 12:47:47
    Core I7 965
    Evga 760
    2 x 480gtx
    Pioneer Burner sata
    H50 Liquid Cooling
    Encrypted_God
    • Ribbons : 7
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 13:04:42 (permalink)
    Hm. Not that this will help but the 500 series cards has a Firmware updater that will unlock the fan speeds in some cards. Anyways...No, I do think it's windows that's preventing it. Let me investigate further and I'll get back to ya.
    • EVGA X99 Classy
    • EVGA X17 Mouse
    • EVGA X12 KB
    ransan309
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 13:07:25 (permalink)
    Did you click on the Auto button(Next to Fan Speed%) and hit apply. This should disable Auto Fan and allow you to go into the fan setting and set-up a User Defined Fan Profile. (User Define button located directly to the right of the Auto button)
    You should also be able to adjust the fan speed by simply moving the slider from side to side. This should show a corresponding increase or decrease in fan speed %.
    It shouldn`t matter that the setting is greyed out. On mine. I can still manipulate the setting even though it is greyed out.
    This might help as well
    http://event.msi.com/vga/afterburner/images/Afterburner%20User%20Manual.pdf
    post edited by ransan309 - 2012/08/02 13:33:15
    Encrypted_God
    • Ribbons : 7
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 13:18:01 (permalink)
    Look HERE for some tips too
    • EVGA X99 Classy
    • EVGA X17 Mouse
    • EVGA X12 KB
    alanwest09872
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 13:34:12 (permalink)
    Thanks for al your help I really appreciate it
    Core I7 965
    Evga 760
    2 x 480gtx
    Pioneer Burner sata
    H50 Liquid Cooling
    ransan309
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 13:45:39 (permalink)
    Your welcome. Just remember to hit apply after you make changes so the changes will stick
    alanwest09872
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 14:06:04 (permalink)
    See that's the thing I can change all the options except the fans. It is greyed out. And its the only one that's greyed out its really weird and agrovating
    Core I7 965
    Evga 760
    2 x 480gtx
    Pioneer Burner sata
    H50 Liquid Cooling
    Encrypted_God
    • Ribbons : 7
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 14:32:42 (permalink)
    Just to confirm; You have a EVGA 480gtx. Correct? or is it MSI. Sorry, I got confused
    • EVGA X99 Classy
    • EVGA X17 Mouse
    • EVGA X12 KB
    alanwest09872
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 14:43:05 (permalink)
    100 percent sure its evga why does msi have this problem
    Core I7 965
    Evga 760
    2 x 480gtx
    Pioneer Burner sata
    H50 Liquid Cooling
    Encrypted_God
    • Ribbons : 7
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 14:47:11 (permalink)
    I don't know about MSI. With all due respect; I'm more concerned with your EVGA product. How long ago did you get those cards. Were they purchased at the same time? or were they purchased at different times.
    Check the Bios of both cards. They should match.
    • EVGA X99 Classy
    • EVGA X17 Mouse
    • EVGA X12 KB
    alanwest09872
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 14:50:17 (permalink)
    Well since I was concerened that the cards were over heating I took one out. So now I'm working with only one. And I bought them at different times and there about 1.5 years old
    Core I7 965
    Evga 760
    2 x 480gtx
    Pioneer Burner sata
    H50 Liquid Cooling
    #23
    Encrypted_God
    • Ribbons : 7
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 15:01:10 (permalink)
    Ok, so now that you have one of your cards out; Check the bios version and write it down. Do the same with the other one. Hopefully they will match. If not, you may need to flash them both or one to the same bios version.
    I am thinking that maybe that's the reason why you can't change or manipulate the fan speed(s). The fan's are "locked".
    Anybody else have an input on this?
    • EVGA X99 Classy
    • EVGA X17 Mouse
    • EVGA X12 KB
    #24
    alanwest09872
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 15:25:01 (permalink)
    I will do that but since I only have one card in now shouldn't I be able to change the fan speed. I was always able to before. Well this started about a week ago
    Core I7 965
    Evga 760
    2 x 480gtx
    Pioneer Burner sata
    H50 Liquid Cooling
    #25
    alanwest09872
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 15:29:52 (permalink)
    Bios of card one is 70.00.21.00.82
    Core I7 965
    Evga 760
    2 x 480gtx
    Pioneer Burner sata
    H50 Liquid Cooling
    #26
    Encrypted_God
    • Ribbons : 7
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 15:30:49 (permalink)
    OH! well if it just happened then damn...What the hell? I will assume that it worked prior the fresh install.
    Have you tried uninstall the nVidia drivers then using the driver sweeper to remove all the remnants of the drivers?
    • EVGA X99 Classy
    • EVGA X17 Mouse
    • EVGA X12 KB
    #27
    alanwest09872
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 15:43:57 (permalink)
    It happened before the fresh install. Because of this problem I did a fresh install last nite. It just doesn't make any sense to me why this is happening that's why I thought some setting in windows is wrong
    Core I7 965
    Evga 760
    2 x 480gtx
    Pioneer Burner sata
    H50 Liquid Cooling
    #28
    alanwest09872
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 15:45:41 (permalink)
    Bare with me I'm typing all this on a tablet PC. I'm a bit sick so I only get up when u guys tell me to try something
    Core I7 965
    Evga 760
    2 x 480gtx
    Pioneer Burner sata
    H50 Liquid Cooling
    #29
    Encrypted_God
    • Ribbons : 7
    Re:Unable to control fan speed with either of my gtx 480 2012/08/02 15:46:06 (permalink)
    • EVGA X99 Classy
    • EVGA X17 Mouse
    • EVGA X12 KB
    #30
