Not the best idea to wiggle your power cables with the Power On.
You need only the Power Cable for the PSU in the Computer and put the Monitor on the Serge Side only and not the UPS side.
500 Watt UPS is really Small, what Hardware is inside your Computer?
I use APC UPS Battery Backup & Surge Protector with AVR, 1500VA, APC Back-UPS Pro (BX1500M) (900W) for a Computer with 2 GPU's.
or the APC UPS Battery Backup & Surge Protector with AVR, 1350VA, APC Back-UPS Pro (BX1350M) (810W) for a Computer with a Single GPU.
You should be using at the Low End the APC UPS Battery Backup & Surge Protector with AVR, 1000VA, APC Back-UPS Pro (BX1000M) (600W)
A small one like the APC UPS Battery Backup & Surge Protector with USB Charger, 850VA, APC Back-UPS (BE850M2) (450W) is to small for todays high end computers. Good for Routers and Hubs small stuff like Modems.
post edited by bcavnaugh - 2018/12/28 14:26:54
