Re: Single 8 pin power vs 8+8 pin power
2018/03/07 10:30:45
Cuddles1101
so on the regular FE gtx 1080 it only has a single 8 pin power connector, but on the FTW gtx 1080 they have an 8+8 pin power config. Will this config pull more power even if it is not needed and if so how much?
It won't pull any more power than needed. They never do...well, unless they short out or something else spectacular.
