- Ribbons : 81
https://www.tomshardware.com/news/samsung-980-pro-ssd-failures-firmware-update?utm_campaign=socialflow&utm_content=tomsguide&utm_source=facebook.com&utm_medium=social&fbclid=IwAR2VGXDde2zFN_A3lGle6M2WhlhTI4h-XNgZg4BbcuJTj3MpWco2Kj6dCIM Over the past few months, there have been numerous reports of Samsung 980 Pro SSD failures, with many complaints originating from China. We never heard an official statement from Samsung on the matter, but custom PC builder Puget Systems definitely took notice after it "received a surprising number of reports of failing Samsung drives." Puget worked with Samsung to identify the problem, and now Samsung has issued new firmware for affected 980 Pro SSDs. According to Puget, the failures traced back to the 3B2QGXA7 firmware and primarily affect 2TB versions of the 980 Pro (although lower capacities are not entirely immune). Puget doesn't detail the cause of the failures, but Reddit user reports suggest that the SSDs report a S.M.A.R.T. value of 0E (media and integrity error) or greater in CrystalMark or AIDA64. In addition, an 03 value (available spare) lower than 100 percent may also be reported. It's recommended to use the Samsung SSD Magician software to scan the drive for errors if the 03 or 0E value is out of spec. "The newest one is one of the 2TB ones. Over 2000 errors already," reported user RaXelliX on Reddit. "And the middle one 2TB has already failed with over 32,000 errors and is locked to read only mode. I fully expect the two others to fail soon too." "Bought a 2TB 980 Pro in February of this year and installed it a few months later in May. Manufactured August 2021," added Meme_Attack in a separate Reddit thread. "Lasted a grand total of 4 months before I noticed Media Errors ballooning from 300 to 6,000+ after a full Samsung Magician scan. Also found 9 red blocks through the same scan. Lost 5% of available spare, drive's at 95% as I speak. 4.1 TB written. Super careful and light use." So, what happens if your drive reports abnormal 0E or 03 values? Well, it usually means that your 980 Pro is on a one-way ticket to an early death. According to Puget, the most common issue that users face is that the SSD goes into read-only mode. Given that most users have their OS installed on the SSD, read-only access makes the boot drive unusable. Unfortunately, once your 980 Pro goes into this failure state, there is no way to recover your data, even with the firmware update. However, the new firmware update from Samsung will prevent the failures from occurring in the first place if your drive is still functioning. So, if you have a 980 Pro running the 3B2QGXA7 firmware, you'll want to update to the newest firmware (5B2QGXA7) using the Samsung SSD Magician software(opens in new tab) ASAP. It should be noted that 980 Pro SSDs running the 4B2QGXA7 or 5B2QGXA7 firmware are not affected by this issue. Puget Systems customers who have already experienced a Samsung 980 Pro SSD failure or have problems using the Samsung SSD Magician software can contact the company for guidance. All other 980 Pro users would need to reach out to their respective system builder or contact Samsung directly(opens in new tab) if the SSD was bought from a third party. Anyone with a Samsung 980 Pro should take action ASAP in my personal opinion.
Re: Samsung Issues Fix for Dying 980 Pro SSDs
2023/01/31 11:27:35
good to see Samsung was able to make a firmware fix - still should not have happened
Learn your way around the EVGA Forums, Rules & limits on new accounts Ultimate Self-Starter Thread For New Members I am a Volunteer Moderator - not an EVGA employee https://foldingathome.org -->become a citizen scientist and contribute your compute power to help fight global health threats
RTX Project EVGA X99 FTWK Nibbler EVGA X99 Classified EVGA 3080Ti FTW3 Ultra Saves 3%-10% @EVGA.com use Anyone's Associate code -->https://www.evga.com/associates
oldfresh
2023/01/31 15:03:29
I find this to be a bit suspicious. Either there was some sort of sabotage, or a cost cutting venture going on with either Samsung, Puget or the supplier/manufacturing in CNY. Every single one of my 980 Pro drives ordered directly from Newegg was Made In Korea. Good to know, send any of the CNY mfg chips back immediately.
yaymz
2023/01/31 15:26:35
oldfresh I find this to be a bit suspicious. Either there was some sort of sabotage, or a cost cutting venture going on with either Samsung, Puget or the supplier/manufacturing in CNY. Every single one of my 980 Pro drives ordered directly from Newegg was Made In Korea. Good to know, send any of the CNY mfg chips back immediately.
I'm not sure that the affected SSD's were necessarily MFG'd in China. The article just says that reports initially came from China. Best to probably just check the firmware version and update if needed.
oldfresh
2023/01/31 19:16:44
yaymz
It looks like the impacted batches were VN and CNY origin during 8/21 dates. The first drives I got were on the 4B2QGXA7 firmware, but everything after the 8/21 date on the KR batch was on the 5B2QGXA7 firmware so there was no need to update since then. I would also not be surprised if Puget users were not aware of the Samsung Magician software to update their firmware. I'll check the firmware on the 990 Pro when that comes in in the Magician software, but would just return them if they were a batch from a known origin with mfg issues.
Nereus
Captain Goodvibes
- Ribbons : 58
2023/01/31 21:00:30
I have several 980 Pro m.2 drives, although only 500GB or 1TB versions, but zero issues with any of them. Also a 990 Pro 1TB which I have not used yet. I'll check for firmware updates to be sure. 32,000 reports is a lot, although relative to the many millions of these drives they sell, it's a small percentage (not trying to make excuses though). edit: I have the 3B2QGXA7 firmware  ..updating now.
post edited by Nereus - 2023/01/31 21:05:40
oldfresh
2023/01/31 21:13:53
Nereus I have several 980 Pro m.2 drives, although only 500GB or 1TB versions, but zero issues with any of them. Also a 990 Pro 1TB which I have not used yet. I'll check for firmware updates to be sure. 32,000 reports is a lot, although relative to the many millions of these drives they sell, it's a small percentage (not trying to make excuses though). edit: I have the 3B2QGXA7 firmware ..updating now.
That is frightening lol. I think I would turn ice cold if I saw the drive was on the botched firmware. You seem to be handling it well  Can you run a diagnostic scan after the update? Do you have any info on the impacted drive mfg origin and date?
Hoggle
Nereus
Captain Goodvibes
- Ribbons : 58
2023/01/31 23:45:25
Hoggle
When it comes to my data one failure is too many. It’s scary for me since I often try to pick the same brand on drives but now I am wondering if I shouldn’t mix things up in case a firmware issue was to instead of one line effect multiple products from a brand. I would have thought two 980’s with one mirroring would be an effective data backup but this really makes me question that.
Yup same concerns. My usual setup is a primary o/s drive (usually 500GB m.2), larger second m.2 drive for games / scratch disc etc., then 2 drives in raid1 for data and files I don't want to lose. I also do manual backups of that data drive every few weeks on an external drive. My new build will have a 1TB primary drive (990 Pro m.2) which will include games - hoping that will be enough space, and then 2 x 2.5" 870 EVO SSDs in raid1 for data. I'm still considering having a 2nd m.2 drive for games instead of all of it on the 990 Pro, since I'll have a spare 980 Pro m.2... I've used a number of different brands over the years, but Samsung have proven most reliable SSDs, and WD Blacks for mech drives, although I don't use mechanical drives anymore. I've only had one WD drive fail on me - it was a 2TB WD Black.
kswildman
2023/02/01 05:50:22
2 of the 3 drives I have had the 3B2QGXA7 firmware! (One 500GB and one 2TB) Luckily both of them reported no errors. Thanks for posting this RJ.
AMD Ryzen 7 5800X3d ASUS Strix X570-E Gaming 32GB G.SKILL Trident Z Neo CL16 3600 Corsair iCUE H170i Elite Capellix 420mm AIO SAMSUNG 980 PRO SSD 2TB - PCIe 4.0 NVMe SSD EVGA SuperNOVA 1200 p2 80+ Platinum EVGA 3080ti FTW3 Ultra Hybrid Lian Li Lancool Mesh III RGB
bdary
- Ribbons : 111
2023/02/01 07:56:19
Luckily for me both my Samsung 980 Pro's were already using the 5B2QGXA7 firmware. A 500GB and a 1TB models.
frankd3
- Ribbons : 14
2023/02/02 16:59:43
I have 3 2TB 980 Pros. Never had a problem. All 3 are still at 100% with no errors. I updated the firmware a long time ago, months ago, and have the 5B2QGXA7 firmware. I think it was middle of last year. That firmware is far from new.
post edited by frankd3 - 2023/02/02 17:03:36
tsmooth
2023/02/03 09:34:37
☄ Helpfulby Cool GTX 2023/02/03 10:41:20
BEWARE: I have a 980 Pro 2TB and I did the firmware update last night which claimed to work successfully and I used the computer a bit after installing and rebooting. Came home from work this afternoon to a bricked "readonly" drive. The firmware is not fully fixing the issue or perhaps once some threshold of the issue is hit, even though it's working, it will still fail. Can't wait to have fun getting this replaced :( Good luck to the rest of you with these drives.
2023/02/03 10:41:14
tsmooth BEWARE: I have a 980 Pro 2TB and I did the firmware update last night which claimed to work successfully and I used the computer a bit after installing and rebooting. Came home from work this afternoon to a bricked "readonly" drive. The firmware is not fully fixing the issue or perhaps once some threshold of the issue is hit, even though it's working, it will still fail. Can't wait to have fun getting this replaced :( Good luck to the rest of you with these drives.
dang, not a good outcome please give any update once you get answers from Samsung
frankd3
- Ribbons : 14
2023/02/05 04:50:24
Articles are saying that a new firmware has been released to fix this problem. I finally figured out that I updated to version 5B2QGXA7 February of 2022 with a new version of Samsung Magician. I even found Reddit posts where others said they did the same thing a year ago and wanted to know what was new. WTH is going on? This firmware is a year old.
RAVENEVGA
2023/02/26 12:23:59
Has there been any updates? Last post was 3 weeks ago. I saw this error reported on a Youtube channel I sometimes watch. I checked my 2GB NvME and it had all the marks for the potential "read only". I downloaded Samsung Magician and did a check on it. No red boxes. I updated to the latest firmware anyway. I hope that actually does fix the error!! :-/
> Windows 11 Pro> PSU: EVGA SuperNOVA 1000 G5> Mainboard: EVGA Z690 CLASSIFIED (BIOS v1.10 6/21/2022)> CPU: Intel Core i7-12700K> Cooling: Noctua NH-U12A> Physical Memory: Corsair Dominator Platinum RGB DDR5, 32 GB [2x16GB], 5600MhHz> Physical Memory Model#: CMT32GX5M2B5600C36W> Main Monitor: LG UHD 4K 32" [Model:32UN500-W.AUS] > Second Monitor: Samsung C27F591 [Model:LC27F591FDN]> Video Card: EVGA 3080 Ti FTW3 ULTRA> Case: Lian Li O11 Dynamic XL
Hoggle
2023/02/26 14:49:23
Hopefully this is not a widespread phenomenon since going read only would not many anyone happy. Samsung has always been a great SSD brand but now I am starting to consider other brands more not just because of the price difference but because of the fear of reliability.
