Helpful ReplyRTX 3080 FTW3 Ultra - Mining settings, power consumption
103JL
Re: RTX 3080 FTW3 Ultra - Mining settings, power consumption 2021/06/14 15:03:33 (permalink)
do make sure you undervolt it. 330 is a ton
#31
tigermike74
Re: RTX 3080 FTW3 Ultra - Mining settings, power consumption 2021/07/30 17:32:43 (permalink)
I just picked up a 3080FTW3 Ultra and get about 82-95MH/s. I have my Precision set to 1500 memory, -200 GPU and 70% power. GPU temp hits 60°.
I'm hitting 205-209W with 430kH/J efficiency.
Seems to swing pretty wild. But I am still on the fence if it's economically sound since it's only producing about $1 of bitcoin every 4 hours.
I have another 3090 (different brand I won't name here) that is still in the box. I'm not sure if putting that in will be worth it.
EVGA 3090 FTW3 Ultra, Asus ROG Z590-V
#32
Nozler
Re: RTX 3080 FTW3 Ultra - Mining settings, power consumption 2021/07/30 20:37:16 (permalink)
Suddenly I feel nauseous. My issue and mine alone.
Like Walter Cronkite used to say "And that's the way it is"
heatware
#33
tigermike74
Re: RTX 3080 FTW3 Ultra - Mining settings, power consumption 2021/08/01 10:35:28 (permalink)
What's wrong with your rig?
#34
tigermike74
Re: RTX 3080 FTW3 Ultra - Mining settings, power consumption 2021/08/02 21:27:30 (permalink)
This isn't too bad no?
#35
Allmtrcrx
Re: RTX 3080 FTW3 Ultra - Mining settings, power consumption 2021/09/02 12:53:00 (permalink)
Put the core back to 0 and let me know
#36
telefonista06
Re: RTX 3080 FTW3 Ultra - Mining settings, power consumption 2022/04/07 13:33:49 (permalink)
pclausen
I'm running these settings when mining with my 3080 FTW3 Ultra:
Power 60%
Core - 150
Memory + 1200
That gets me right at 100 MH/s @ 227 watts.  My efficiency is typically around 445 kH/W, which blows away my 5700 XT farm (16 cards all BIOS modded to do roughly 57.5MH/s each), which get about 385 kH/W.  Still way way better than my 1080Ti farm (~40 EVGA 1080Ti SC2s) that got around 260 kH/W.  I sold those last month @ $500 a pop since prices were crazy high.  Way more than I expected to get for them after riding them hard for 3+ years.
I did load the beta BIOS into both Normal and OC and currently running with the switch on OC.  Doesn't make a difference for mining, but trying to get some decent Port Royal scores with power @ 118% when not mining or gaming.  :)
My power, core and memory are being controlled by Awesome miner, but I suspect I would see the exact same values if using AB or PX1.
Hi,  you mention only 227w how do achieve this? im using px1 and T-rex.. do you have a t-rex file that controls all settings for card, if you do can you post the .bat file you can remove your address ;)
#37
