jrbugbee
I received the RTX 2080 XC Black Edition after RMAing my faulty GTX 1080 SC. The 1080 card had only an 8pin power connector. This 2080 has a 8pin and a 6pin. Do I need to run power to both?
flyinion
- Ribbons : 9
Re: RTX 2080 XC Black - 8pin and 6pin power connector?
2020/03/11 16:59:50
jrbugbee I received the RTX 2080 XC Black Edition after RMAing my faulty GTX 1080 SC. The 1080 card had only an 8pin power connector. This 2080 has a 8pin and a 6pin. Do I need to run power to both?
Yes
AMD Ryzen 5950X | Asus Crosshair VIII Hero | Gigabyte Gaming OC 4090 w/EK Vector2 | GSkill Trident Z Neo 2x16GB DDR4-3600 | WD SN850 2TB | Samsung 970 EVO Plus 500GB & 860 Evo 2TB | Phanteks Enthoo 719 | Seasonic Prime Ultra Gold 1000W | Steelseries M750 TKL | SteelSeries Prime Wireless | SteelSeries Arctis Pro + GameDAC | Kanto YU2 + Yamaha sub | Schiit Magni 2 Uber & Modi 2 Uber | LG 34GN850 | Asus PG279Q | Win 11 Pro | Custom water loop
bob16314
- Ribbons : 761
2020/03/11 17:06:59
Yes, unless you want to see this every time you start your PC..You can try it just for kicks, won't hurt anything.
jrbugbee
2020/03/11 17:12:15
Obviously, this replacement card did not include cables. Luckily, I have this cable from an older card, will this work? I use this 8 pin connector with the breakway 2 pins to use in the 6pin connector?
bob16314
- Ribbons : 761
2020/03/11 17:19:13
That'll work in a pinch for the time being..But you should run two seperate 6-pin and 8-pin (or 6+2 pin like the one you show there) cables to the card. What power supply do you have?
jrbugbee
2020/03/11 17:28:44
Sorry if I wasn't clear. My current plan is to use a dedicated 8 pin cable (that was going to my old 1080) and also use that dedicated 6(+2) cable as well. My power supply is a EVGA SuperNOVA 650 G1
bob16314
- Ribbons : 761
2020/03/11 17:33:09
Yep, that's the ticket..You're good. I thought maybe you were talking about a 'Y' cable before.
- Ribbons : 123
2020/03/11 17:46:27
jrbugbee Sorry if I wasn't clear. My current plan is to use a dedicated 8 pin cable (that was going to my old 1080) and also use that dedicated 6(+2) cable as well. My power supply is a EVGA SuperNOVA 650 G1
That "other cable" can With your PSU ?
jrbugbee
2020/03/11 18:10:37
Cool GTX That "other cable" can With your PSU ?
I'll be honest: I don't remember. I bought the EVGA 1080 2 years ago and it came with extra cables I threw in a box. The EVGA powersupply also came with spare cables, and I threw them in the same box. This powercable, as seen in the photo above, says EVGA, so it could be from either my EVGA 1080 or my EVGA PSU. One thing though, is the cable that was going to my 1080 looks almost identical to this 6+2 cable (aka: the writing) so I'm leaning towards this cable coming with my 1080. Though my 1080 did not use a 6+2 cable, only the 8 pin.
GTXJackBauer
- Ribbons : 48
2020/03/11 20:24:44
Make sure you're using the PSU's cables ONLY and not someone else's. Have seen some issues when cables are mixed. Grats on your RMA upgrade!
jrbugbee
2020/03/11 20:41:32
I used the cable and everything appears to be in working order. Just realized the 2070 doesn't have a DVI output so I'll be needing to find a HDMI cable for my 2ndary monitor. No big deal. Thanks for your help everyone!
DeadlyMercury
- Ribbons : 14
2020/03/12 02:26:54
jrbugbee I'll be honest: I don't remember. I bought the EVGA 1080 2 years ago and it came with extra cables I threw in a box. The EVGA powersupply also came with spare cables, and I threw them in the same box. This powercable, as seen in the photo above, says EVGA, so it could be from either my EVGA 1080 or my EVGA PSU. One thing though, is the cable that was going to my 1080 looks almost identical to this 6+2 cable (aka: the writing) so I'm leaning towards this cable coming with my 1080. Though my 1080 did not use a 6+2 cable, only the 8 pin.
well, i think you are safe there: I doubt that you can get some cable for "some" psu with your gpu, so it should be something like 2x SATA -> PCIE x6 or 2x Molex -> PCIE x6 or something like that - but not something like PSU -> PCIE x6+2.
"An original idea. That can't be too hard. The library must be full of them." Stephen Fry
