wapcrazut
Tuesday, February 09, 2021 0:12 PM
Hello, I just got the Rtx 3080 XC3 Ultra Gaming card. I was testing everything when I noticed that the LED on the backplate won't turn on. I installed PX1 and after an firmware update the problem persist. Changing the led settings on PX1 only affects to the side LED. Fresh install, updated drivers and everything new. Using an Asus TUF X570 Pro Wifi Any advice? Should I send a RMA? Thanks
post edited by wapcrazut - Thursday, February 11, 2021 8:55 PM
wapcrazut
Re: RGB LED Issue - EVGA RTX 3080 XC3 Ultra Gaming
Thursday, February 11, 2021 8:54 PM
Riggerw8
Wednesday, February 17, 2021 5:18 PM
I have this Exact same issue, I have tried several versions of PX1 software and none of them work. the only RGB lighting that comes on is exactly yours, EVGA
mech9t5
Wednesday, February 17, 2021 5:53 PM
wapcrazut Hello,
Thanks
If it were me, wouldn’t RMA just for the rgb issues. The card works fine.
Associate Code: P7JUX093GU7RID0
moadib2k
Wednesday, February 17, 2021 6:04 PM
Funny, I just posted a similar thread. My issue is the side LED of a 3090 RGB. It was working and now only has one. I would say performance is unaffected but I seem to have the uneven power draw issue as well. I am wondering if I am at the beginning of a long slow failure cycle. I added the 10 year warranty to mine :)
Video Card: 24G-P5-3987-KR - RTX 3090 FTW MB: ASUS Rog Crosshair Hero VIII Memory: 64GB Corsair Vengeance DDR4 3600 PSU: Corsair HX850
wapcrazut
Wednesday, February 17, 2021 11:17 PM
moadib2k Funny, I just posted a similar thread. My issue is the side LED of a 3090 RGB. It was working and now only has one. I would say performance is unaffected but I seem to have the uneven power draw issue as well. I am wondering if I am at the beginning of a long slow failure cycle. I added the 10 year warranty to mine :)
Exactly, this isn't a good sign. In my case it didn't work from the start, so maybe you can check something related to power. Maybe checking you PCI-E cables from the PSU and making shure you're using two outlets and not one with a split cable. And don't allow PX1 to load with the system, just to check if is messing with the card profile.
wapcrazut
Wednesday, February 17, 2021 11:19 PM
mech9t5
wapcrazut Hello,
Thanks
I get your point but come on, I'm paying for an overpriced card. It should work as intended. This is a red alert for me. Quality control? None...
wapcrazut
Wednesday, February 17, 2021 11:23 PM
Riggerw8 I have this Exact same issue, I have tried several versions of PX1 software and none of them work. the only RGB lighting that comes on is exactly yours, EVGA
If the LEDs don't turn on after shutting down everything, disconnecting your PSU and turning back on I'm very sure this is not software related since I did a firmware update and everything should work. Like I said before, quality control here is almost none.
post edited by wapcrazut - Thursday, February 18, 2021 8:27 AM
mech9t5
Wednesday, February 17, 2021 11:31 PM
wapcrazut If the LEDs don't turn on after shutting down everything, disconnecting your PSU and turning back on I'm very sure this is not software related since I did a firmware update and everything should work. Like I said before, quality control here is almost none.
Well I guess you have answered your own question then. No arguments here.
wapcrazut
Thursday, February 18, 2021 8:31 AM
mech9t5
I'm sorry if that last thing is offensive to you, but coming from big company like EVGA this shouldn't happen. I know there are stock issues, but selling faulty cards is not ideal. But hey, that's just a comment.
mech9t5
Thursday, February 18, 2021 12:28 AM
wapcrazut
No worries. I did not take any offence. You have your opinion and I respect it. Good luck in what ever decision you decide upon.
TheAManOW
Wednesday, September 14, 2022 3:37 AM
Hi @wapcrazut, long term update? mine is doing the same thing now.
iscipioni
Wednesday, September 14, 2022 4:09 PM
hi , did you test with openrgb ?(close px1)
post edited by iscipioni - Wednesday, September 14, 2022 4:10 PM
Phanteks p500a i7 12700k asus rog strix z690 f thor 1200w ryujin ll 360 evga rtx 3080ti xc3 ultra fury 32go ddr5 6000mhz
EVGATech_MatthewC
EVGA Tech Support
Wednesday, September 14, 2022 6:03 PM
Have you tried reseating the card in the PCIE slot, or reseating the power connectors? Can you check and see if any of the wires on the card might be loose or possibly pinched? Checking after taking the card out, before reseating, would be a good idea.
GameOverMan
Thursday, September 15, 2022 1:05 PM
wait, that card has back rgb? I am rmaing my 2nd one due to fan issue, but it never had back rgb, and I have x1 with the led lights software installed. Only the EVGA ever lit up on 2 cards. Part Number: 12G-P5-4861-KL Part Desc: EVGA GeForce RTX 3080 12GB XC3 BLACK GAMING, 12G-P Not sure how different the Ultra model is.
eVGA RTX 3080 FTW Ultra Gaming i7 13700K w/ 360mm AIO 32GB Gskill 6000mhz DDR5 1TB M.2 NVME SSD 850watt PSU Phanteks P500a case
Duke62
Friday, October 14, 2022 12:42 AM
I just got the Rtx 3080 ti XC3 Ultra Gaming card, and I also have a TUF X570 Pro Wifi motherboard I was testing everything when I noticed that the LED on the backplate won't turn on. I installed PX1 and after a firmware update, the problem persist. Also changing the led settings on PX1 only affects the side LED. Any advice? Thanks
post edited by Duke62 - Friday, October 14, 2022 5:52 PM
