Drerex
- Ribbons : 31
It's time for my next small form factor build. This ought to be a fun one! Build log starting soon. Case: Motherboard: Video Card: CPU: 4670k CPU Cooling Block: GPU Cooling Block: Radiator 1: Radiator 2: Reservoir: Pump: Pump Top? TBD. Might just stick with the Swiftech Coolant: Tubing: Rigid Tubing Fittings: & Fans:
post edited by Drerex - 2015/06/09 13:06:45
Chaos_21
- Ribbons : 10
Re: Project Ice Bolt
2014/05/21 17:07:30
Nice start! Looking forward to the finished build.
ASUS TUF Gaming Z690-Intel Core i9-12900K- EVGA 360 CLC Cooler-Corsair Vengeance 4 x 16GB 3200mhz-2TB Solidigm P41 Plus M.2 SSD--Three 1TB 970 EVO SSD's-EVGA GeForce RTX 3080 XC3 ULTRA-Corsair HX1000i-Windows 11 64bit-Corsair iCUE 5000X RGB Case. Steam Twitter: https://twitter.com/Chaos_21 Use my associate code: JBGVM12HDYDJPIM to get 5%-10% discount on EVGA purchases.
drake187
2014/05/21 17:10:03
Indeed I really like the case and parts subd.
- Ribbons : 115
2014/05/21 21:18:35
I want to see some good eye candy. ;)
Drerex
- Ribbons : 31
2014/05/22 04:31:56
I will try my best! :) Hopefully it will come out like I imagine it. A lot to put into a small case but Digital Storm did a good job on the design of the case so it shouldn't be that hard.
- Ribbons : 86
2014/05/22 06:26:04
Should be a great looking build when finished
bdary
- Ribbons : 118
2014/05/22 10:17:57
Looking forward to seeing the finished product...
LCRava
- Ribbons : 8
2014/05/22 11:40:01
Nice Drerex. Can't wait to see what you do this time. I'm a fan.
MY AFFILIATE CODE: X6EXZ64PSH "I don't always GAME in 4K, but when I do, I prefer 4 TITANS"
Drerex
- Ribbons : 31
2014/05/23 09:00:25
Thanks! Still in planning process. Trying to figure out which pump that I am going to use. It needs to be low profile but solid. Currently looking at the Laing DDC series. I would use a D5 but not enough room for that. Edit: Went with the Swiftech MCP35x
post edited by Drerex - 2014/06/03 04:26:30
Drerex
- Ribbons : 31
2014/05/23 12:26:09
I have narrowed the powder coat color down to two colors. Crystal Grey w/Clear Vision and EVO Grey:
fsuwade
- Ribbons : 6
2014/05/23 16:44:34
Looks like a sweet looking start to a great rig
Sleinous
- Ribbons : 32
2014/05/27 03:59:33
I'm hooked, anything involving the Stinger gets my attention :D
Drerex
- Ribbons : 31
2014/05/27 06:03:21
:) More pictures to come soon.
Drerex
- Ribbons : 31
2014/05/30 07:25:52
bdary
- Ribbons : 118
2014/05/31 14:13:06
Looking good bud... BTW, my vote is for the crystal grey...
~KAT~
2014/06/02 15:02:21
Like the case.... I swear i have seen it somewhere before ;L
Drerex
- Ribbons : 31
2014/06/02 18:00:10
You know you are not suppose to see this KAT!
post edited by Drerex - 2014/06/03 04:27:31
Drerex
- Ribbons : 31
2014/06/12 14:34:02
After getting some other things taken care of, I now can get back onto designing this build. Today I was able to make some progress on designing a front panel assembly that will sport a new look and give me a place to mount the Res and the pump. BTW, going to use a different res. I am using the one that FrozenQ designed for the ncase M1 enclosure. Had to model a XSPC DDC Top so I can do the proper layout. Also was able to have the guys over at FrozenQ send me a model file of the Reservoir. Why model it when it has already been done? Here is a prototype assembly animation I did to show how it is going to come together.
Drerex
- Ribbons : 31
2014/07/19 20:39:56
Drerex
- Ribbons : 31
2014/07/30 18:49:11
Drerex
- Ribbons : 31
2014/08/06 05:53:46
bdary
- Ribbons : 118
2014/08/06 07:40:58
Looking good bud...
nikkocortez
- Ribbons : 14
2014/08/06 22:54:49
This is a very interesting build. Keep it up!
Drerex
- Ribbons : 31
jingiko
- Ribbons : 5
2014/09/24 10:31:04
Thats pretty awesome lighting. super bright tho. how did you get a DigitalStorm case? Im very curious, I always wanted that case
- Ribbons : 86
2014/09/24 10:38:58
I was wondering what happened to this project. Glad to see you're back on it!
donta1979
Primarch
- Ribbons : 73
2014/12/06 19:37:52
wow man your stuff you build just keeps getting cooler and cooler looking!
Heatware Retired from AAA Game Industry Jeep Wranglers, English Bulldog Rescue USAF, USANG, US ARMY Combat Veteran My Build 14900k, z790 Apex Encore, EK Nucleus Direct Die, T-Force EXTREEM 8000mhz cl38 2x24 Stable"24hr Karhu" XMP, Rog Strix OC RTX 4090, Rog Hyperion GR701 Case, Rog Thor II 1200w, Rog Centra True Wireless Speednova, 35" Rog Swift PG35VQ + Acer EI342CKR Pbmiippx 34", EK Link FPT 140mm D-RGB Fans. Rog Claymore II, Rog Harpe Ace Aimlabs Edition, Cyberpunk 2077 Xbox One Controller, WD Black SN850x/Samsung 980+990 PRO/Samsung 980. Honeywell PTM7950 pad on CPU+GPU
EVGATech_GabrielT
EVGA Tech Support
2014/12/06 23:07:46
Nice. keep the pics coming.
Drerex
- Ribbons : 31
2015/06/09 13:04:42
notfordman
- Ribbons : 28
2015/06/12 10:31:36
Such a nice build, component selection and placement is very good. I'm wondering where the Stinger block came from? +1 for a great looking build! :)
