virus69200
Hi, i have some problem after scan with precision x1 on rtx 2070 xc he set voltage on 1044 mV. I want to lower the frequency (remove all overclock) but i can't, even with default if someone can help me thx.
post edited by virus69200 - 2018/12/03 13:14:49
Re: Problem overclock with precision x1
2018/12/03 19:26:34
#1 Uninstall px1. #2 Delete the evga folder in c:\program files #3 Restart pc. #4 Reinstall px1. Hopefully that will fix it.
post edited by Sajin - 2018/12/03 19:38:35
2018/12/04 07:58:28
Under "GPU Clock" in your photo.... click on the "20" change it to "0" (zero) - then click Apply button - then click on the Save button to save it to your current (open) Profile number
virus69200
2018/12/04 11:32:41
I follow your step but it doesn't work
2018/12/04 11:34:14
☼ Best Answerby virus69200 2018/12/04 11:39:05
virus69200 I follow your step but it doesn't work
Which step?
virus69200
2018/12/04 11:41:05
uninstall px1 delete evga folder restart pc and reinstall px1
2018/12/04 11:50:13
Give Cool's suggestion a try.
virus69200
2018/12/04 11:52:56
no it dosen't work i can't reduce the voltage
2018/12/04 12:01:21
If you want to lower the voltage you can follow my oc guide listed here, but instead of increasing the voltage you can lower it.
2018/12/04 12:16:36
virus69200 no it dosen't work i can't reduce the voltage
Your Voltage is at +0 .... you have not added any Voltage Nvidia Boost 3.0 will use the voltage it thinks best, based on: Load, Amps, Temps to allow the best performance for the user Sounds like your interested in under clocking & under Volting the card What happens if you Lower the Power Target below 100% ? Did you already run the automatic OC tool ?
virus69200
2018/12/04 12:49:23
1044 mv is the default voltage for an rtx 2070 xc ?
2018/12/04 12:56:36
virus69200 1044 mv is the default voltage for an rtx 2070 xc ?
Yep.
virus69200
2018/12/04 13:03:03
Ok thx for help and sorry for my ignorance you can close this thread.
