Power supply ok after rough shipment?
mclan
2021/07/12 17:43:15 (permalink)
I just received my EVGA 650 GT from Amazon and it was shipped in one of those grey plastic envelopes instead of a box and it got kind of beat up. The box was smushed and it looks like it was shaken so much that the interior of the box and the small plastic bags were badly chewed up.  My question is if this could also cause damage to the power supply?  I'm not sure how much vibration PSUs are designed to handle beyond what happens during normal shipping.  What would you do?  Attached are pictures to show my concerns. TIA
3 Replies Related Threads
    Hoggle
    Re: Power supply ok after rough shipment? 2021/07/12 18:29:27 (permalink)
    It’s probably fine really since EVGA well packages PSU. I would though contact Amazon and let them know about the damage to the box. They might give a refund on part o the cost. Also if the product has physical damage I would get a replacement.
    post edited by Hoggle - 2021/07/12 18:31:16
    aka_STEVE_b
    EGC Admin
    • Ribbons : 69
    Re: Power supply ok after rough shipment? 2021/07/14 05:09:55 (permalink)
    Who knows how much internal damage could have occurred..( knocked of caps, insulators, inductors )..
    If it was me,  I'd get it replaced and not take the chance .
    Amazon should send you a new one fairly fast if you show them those pictures .
    AMD RYZEN 9 5900X  12-core cpu~ ASUS ROG Crosshair VIII Dark Hero ~ EVGA RTX 3080 Ti FTW3~ G.SKILL Trident Z NEO 32GB DDR4-3600 ~ Phanteks Eclipse P400s red case ~ EVGA SuperNOVA 1000 G+ PSU ~ Intel 660p M.2 drive~ Crucial MX300 275 GB SSD ~WD 2TB SSD ~CORSAIR H115i RGB Pro XT 280mm cooler ~ CORSAIR Dark Core RGB Pro mouse ~ CORSAIR K68 Mech keyboard ~ HGST 4TB Hd.~ AOC AGON 32" monitor 1440p @ 144Hz ~ Win 10 x64
    • Ribbons : 123
    Re: Power supply ok after rough shipment? 2021/07/14 09:06:23 (permalink)
    I would make Amazon replace it
