Power management mode.
vainpop1317
2017/12/30 16:22:58 (permalink)
Guys which of this 3 option would be best and why? i don't care much about power saving.
GPU 1080ti FTW3
8 Replies Related Threads
    • Ribbons : 271
    Re: Power management mode. 2017/12/30 17:35:15 (permalink)
    AHowes
    • Ribbons : 27
    Re: Power management mode. 2017/12/30 17:41:35 (permalink)
    Link does nothing.
    Asus Z390 ROG Extreme XI MB
    • Ribbons : 271
    Re: Power management mode. 2017/12/30 17:45:19 (permalink)
    The link should take you to search results from 200 similar posts. For example, from 3 weeks ago, the same question:
    https://forums.evga.com/P...=power+management+mode
    AHowes
    • Ribbons : 27
    Re: Power management mode. 2017/12/30 18:16:26 (permalink)
    I see thst but unable to select anything afterwards.. if I do it just pulls up the same first screen to your link. Can't see any of the posts.
    • Ribbons : 123
    Re: Power management mode. 2017/12/30 18:27:07 (permalink)
    The search results do Not Look like they are links, but if you hover over the Title, the link works --> at least it does for me
    AHowes
    • Ribbons : 27
    Re: Power management mode. 2017/12/30 19:10:18 (permalink)
    Its prob a chrome thing cause I'm on the pbone.
    Re: Power management mode. 2017/12/30 19:11:53 (permalink)
    vainpop1317
    GPU 1080ti FTW3
    Sounds like prefer maximum performance is what you want.
    • Ribbons : 135
    Re: Power management mode. 2017/12/31 01:03:39 (permalink)
    vainpop1317
    GPU 1080ti FTW3
    Well, that depends upon your use. Most people leave the desktop at default and a few go into the Nvidia control panel and  make per game changes. Frankly the only thing 'Prefer Max Perf' was good for was for older games that didn't load the GPU enough to raise the GPU clocks and you'd get stuttering. Otherwise I don't think I've noticed anything beyond the placebo effect in games for the most part. You're kinda asking us 'what color should I paint my car'.
