Helpful ReplyPower fan control on 1080 Ti SC2 HYBRID?
mobidutch
Thursday, June 22, 2017 2:45 PM (permalink)
Hi all,
I replaced the radiator fan of my 1080 Ti SC2 HYBRID by a Noctua NF-F12 iPPC fan and plugged that into a motherboard header, controlled by a fan curve in SpeedFan.
I am not into overclocking, and don't have a need for the information provided by Precision XOC (apart from the fact that I find the UI too busy and complicated). So I would prefer to not have Precision XOC installed at all.
My questions are:
- Do I NEED Precision XOC to control the power fan on the card?  (SpeedFan does not seem to have access to it)
- What is the stock fan curve/profile for the power fan on the card, if I choose not to install Precision XOC?
Thanks!
  • Ribbons : 282
Re: Power fan control on 1080 Ti SC2 HYBRID? Thursday, June 22, 2017 6:56 PM (permalink) ☄ Helpfulby mobidutch Thursday, June 22, 2017 7:15 PM
The Blower Fan on the GPU Yes the Radiator Fan No.
You can also use NVIDIA Inspector to set the Blower Fan on the GPU.
As well as MSI AB will set the Blower Fan on the GPU.
post edited by bcavnaugh - Thursday, June 22, 2017 7:00 PM
Re: Power fan control on 1080 Ti SC2 HYBRID? Thursday, June 22, 2017 7:08 PM (permalink)
mobidutch
Thanks!
First question: You only need precision xoc if you want to set a custom fan curve to the power fan.
Second question: Whatever the vbios default is.
mobidutch
Re: Power fan control on 1080 Ti SC2 HYBRID? Thursday, June 22, 2017 7:14 PM (permalink)
Thank you for your reply. Is there a way to find out what that vbios default is?
Re: Power fan control on 1080 Ti SC2 HYBRID? Thursday, June 22, 2017 7:24 PM (permalink) ☄ Helpfulby mobidutch Thursday, June 22, 2017 7:48 PM
mobidutch
Nope.
jerzeeloon
Re: Power fan control on 1080 Ti SC2 HYBRID? Friday, June 23, 2017 1:14 AM (permalink)
I hated when I installed my hybrid sc2 it seemed the blower fan wouldn't spin at all and gpu got real hot so I installed precision x and set fans to auto and the blower fan spins and the card stays cool. Unfortunately today I upgraded to the latest precision x and reboot my system now my games keep crashing within seconds or minutes at best. Gow4 specifically. So I just turned precision x off and o been playing with no problems but i fear my gpu is probably getting real hot.
corsair 350D
Asus Maximus VI Gene
4770k @ 4.2ghz
8gb rip jaws X series 1600 888/24
500gb crucial m4 ssd
1tb wd caviar black
Corsair AX760
Gtx 1080ti
mobidutch
Re: Power fan control on 1080 Ti SC2 HYBRID? Friday, June 23, 2017 3:53 AM (permalink)
jerzeeloon
Perhaps try using MSI Afterburner instead of EVGA Precision X?
jerzeeloon
Re: Power fan control on 1080 Ti SC2 HYBRID? Friday, June 23, 2017 4:14 AM (permalink)
I don't think msi afterburner works with icx
corsair 350D
4770k @ 4.2ghz
1tb wd caviar black
Corsair AX760
Gtx 1080ti
