Power connections for new build/ GEForce RTX 2080
JKWolfe
Sunday, March 10, 2019 4:24 PM (permalink)
I am brand new to the forum and a first time builder of a system. On the  back of the card, there is a 6 pin and an 8 pin power connection. The provided 6+2 pin to 8 pin fits on the 6 pin female connection. How do I connect the 8 pin connection to the 8 pin connection on the EVGA 850 power supply? Are there 8 pin PCIe male to male connectors out there somewhere? Do I use an 8 pin to 6 pin connector for the 6+2 cables supplied?
Thanks in advance for help to a new forum member.
10 Replies Related Threads
    • Ribbons : 282
    Re: Power connections for new build/ GEForce RTX 2080 Sunday, March 10, 2019 4:30 PM (permalink)
    Welcome to the Forum
    "Do I use an 8 pin to 6 pin connector for the 6+2 cables supplied?" NO
    You use Two Cables from your Power Supply to the Graphics Card.
    The End that has VGA or PCI-E on the end goes to the Graphics Card. 6-Pin or 6+2 Pin.
    The Blank or VGA 8-Pin End that is Solid Plugs into the Power Supply.
    Cables that are 6+2 Pins are joined together to create the 8-Pin PCIe Connector for the Graphics Card.
    On Connectors that only need 6-Pin the extra 2-Pins just hangs out and is not used.
    Do not use an EPS/CPU Cable on your Graphics Card or use the PCIe Power Cable on the EPS Connector on the Motherboard.
    Each cable only Plugs in One Way do not Force a Cable that is not meant for the Connector PSU side and GPU Side.
    On the GPU the Clip will Face you as you Plug it in or will Face Down in Standard Computer Cases.
    or
    or
    post edited by bcavnaugh - Sunday, March 10, 2019 5:00 PM
    • Ribbons : 123
    Re: Power connections for new build/ GEForce RTX 2080 Sunday, March 10, 2019 4:35 PM (permalink)
    Welcome to the EVGA Forums JKWolfe
    Congrats on your first post
    Which EVGA 850 power supply ?  (PSU)
    JKWolfe
    Re: Power connections for new build/ GEForce RTX 2080 Sunday, March 10, 2019 5:00 PM (permalink)
    Hello and thanks for your interest.
    EVGA Supernova 850 P2, 80+ Platinum 850W,
    EVGA SuperNOVA 850 P2, 80+ PLATINUM 850W, Fully Modular  10 Year Warranty Power Supply 220-P2-0850-X1
    edit Cool GTX hyperlink PSU
    post edited by Cool GTX - Sunday, March 10, 2019 5:31 PM
    • Ribbons : 123
    Re: Power connections for new build/ GEForce RTX 2080 Sunday, March 10, 2019 5:34 PM (permalink)
    Great choice
    Use the "VGA"cables - as mentioned by bcav above using two separate cable is the best way to do it
    Solid 8-pin Always - goes into the PSU ---> then use the 6+2-pin to make an 8-pin on the GPU end
    Those alignment tabs "capture" the 2-pin to hold it in place --> you can start the 2-pin First, then slide 6-pin on
    Push on the Wires till the little plastic locking latch is full seated --> Support the GPU while assembling
    JKWolfe
    Re: Power connections for new build/ GEForce RTX 2080 Sunday, March 10, 2019 5:41 PM (permalink)
    Are the alignment tabs the little L shaped fittings on the 2 portion of the 6+2 cable? Does the 6+2 really fit in the 8 pin female of the graphics card? Do I even have the correct 6+2 in the gozillion cables that came in the case kit, etc.?
    Thanks for the help.
    • Ribbons : 123
    Re: Power connections for new build/ GEForce RTX 2080 Sunday, March 10, 2019 5:44 PM (permalink)
    JKWolfe
    I updated my post above yours - was working on it when you replied
    Yes "L" shaped
    You will notice that the sockets are also of Various shapes for individual pins in a pattern  (Not all round or all square or all beveled)
    JKWolfe
    Re: Power connections for new build/ GEForce RTX 2080 Sunday, March 10, 2019 6:00 PM (permalink)
    Thanks a lot. That really helps! Simple answers are always best.
    I will post a photo when it's all together. The build has the EVGA power supply, the 2080 graphics card and the EVGA monster CPU cooling fan/ radiator. Guess it's an EVGA system after all.
    Regards;
    Jeff
    • Ribbons : 123
    Re: Power connections for new build/ GEForce RTX 2080 Sunday, March 10, 2019 6:04 PM (permalink)
    Happy to Help
    AHowes
    • Ribbons : 27
    Re: Power connections for new build/ GEForce RTX 2080 Sunday, March 10, 2019 6:31 PM (permalink)
    Good luck and may the pc gods bless you with that magical first post beep sound! Haha
    Asus Z390 ROG Extreme XI MB
    • Ribbons : 123
    Re: Power connections for new build/ GEForce RTX 2080 Sunday, March 10, 2019 6:45 PM (permalink)
    Forgot to mention - as you say this is your First PC build
    Always unplug your PC before adding or removing hardware, even when "PC is Off" there is Power to the MB & damage can happen
