Power Supply Replacement
lancelotbridge
2024/12/02 19:08:33 (permalink)
I need to replace my 1000 GT Supernova - what are my options that allow my to reuse the existing cables?  I really don't want to have to re-run them all.  I looked at the cable compatibility FAQ but didn't see the GT in there anywhere
1 Reply Related Threads
    • Ribbons : 123
    Re: Power Supply Replacement 2024/12/02 20:05:17 (permalink)
    lancelotbridge
    Welcome to the EVGA Forum
    Is this the PSU?  https://www.evga.com/prod...aspx?pn=220-GT-1000-X1
    Please email EVGA at Support@EVGA.com so they can help you
