GTXJackBauer
- Ribbons : 48
Re: EVGA PSU Discount Codes and Much More!
2020/03/14 01:43:26
Nereus
Captain Goodvibes
- Ribbons : 58
2020/03/16 00:51:08
^ Yes good idea - associate codes give you 5-10% off many items through the EVGA store! You'll find codes in the signature of many members here.
GTXJackBauer
- Ribbons : 48
2020/04/10 05:09:33
rsabatino
- Ribbons : 6
2020/04/10 07:34:36
if I only knew before I bought it
Operation System Microsoft Windows 11 Pro Processor AMD Ryzen 9 5950X 16-Core Processor Memory 24.2 GB Free (31.9 GB Total) Graphics Card NVIDIA GeForce RTX 3070 Ti (8.0 GB) Monitor HP 32 Display (1920 x 1080 @ 60 Hz) Disk Storage 5240.5 GB Free of 6542.2 GB Audio NVIDIA High Definition Audio Motherboard ASUSTeK COMPUTER INC. (ROG CROSSHAIR VIII HERO (WI-FI)) Mouse Razer BlackWidow V3 Tenkeyless Keyboard Razer Viper
Hoggle
2020/04/10 09:56:28
rsabatino if I only knew before I bought it
The associate codes are a great way to save extra and the forums are a great way to find a code to use. Often times people will post about deals going on and the codes can save additional on top of that. Just keep in mind you can't sign up to be an associate rewards member and use someone else's code. The options are to not be a member and be able to use a code or to sign up to refer people to EVGA products and then earn rewards.
GTXJackBauer
- Ribbons : 48
2020/05/04 19:49:58
GTXJackBauer
- Ribbons : 48
2020/06/03 06:38:26
nhgv2c
2020/06/07 08:56:06
Nereus
Captain Goodvibes
- Ribbons : 58
2020/06/07 10:05:18
GTXJackBauer
- Ribbons : 48
2020/06/24 23:38:17
GTXJackBauer
- Ribbons : 48
2020/07/15 02:03:23
GTXJackBauer
- Ribbons : 48
2020/08/12 22:05:08
2020/08/13 12:49:14
gravedigger78
2020/09/11 08:18:16
What would you recommend the 1000w G5 or G+?
GTXJackBauer
- Ribbons : 48
2020/09/11 12:22:44
gravedigger78 What would you recommend the 1000w G5 or G+?
All depends. They both look the same internally but the G5 I believe is newer, has a shorter base and a eco mode which means less audibles from it's fan.
