Re: Possible RMA Situation - Fan Problems with 3080 FTW3 Ultra
2021/12/07 10:25:09
I guess if it's not doing it now then you're probably better off running it. If it happens again, though, I'd just go ahead and send it back. I'd put money on that fan being the first thing to fail on that card long term even if you don't notice the issue again for a while.
I'd take the protective plastic off the fan center hub. It could potentially cause balance issues and it's not intended to remain on during use.
