Phanteks Unveils Mesh Front Panels for Eclipse P400A Chassis
  • Ribbons : 86
2019/09/19 22:19:02 (permalink)
https://www.techpowerup.com/259382/phanteks-unveils-mesh-front-panels-for-eclipse-p400a-chassis
Phanteks today announced the release of the P400A's high performance, all-metal mesh front panel. Due to the high demand for this panel from our original P400(S) customers, we have decided to have this available for purchase.
The panel will be a great upgrade to all original P400(S) owners looking to boost airflow and maximize cooling performance of their case. The P400A high airflow front panel is compatible with all P400(S) models and will be available in Black and White. Because of the slight difference between the P400A and P400(S) chassis, the front fan alignment is slightly off-center by 8 mm with the P400(S) chassis. Keep in mind that this only impacts the lighting effects when using RGB fans but not airflow performance.
Personally I think the mesh front provides far more airflow and also allows you to show off the front fans especially if they have RGB capability.
3 Replies Related Threads
    • Ribbons : 123
    Re: Phanteks Unveils Mesh Front Panels for Eclipse P400A Chassis 2019/09/21 12:34:36 (permalink)
    Nice looking way to improve airflow
    GTXJackBauer
    • Ribbons : 48
    Re: Phanteks Unveils Mesh Front Panels for Eclipse P400A Chassis 2019/09/21 14:12:28 (permalink)
    LMD3DNZM9LGK8GJ
    aka_STEVE_b
    EGC Admin
    • Ribbons : 69
    Re: Phanteks Unveils Mesh Front Panels for Eclipse P400A Chassis 2019/09/21 14:35:22 (permalink)
    I'll think about maybe getting one later - since I had the exact type of idea , so I drilled holes & made 4 slots most of the way up my front myself .... and put screening behind it.
    AMD RYZEN 9 5900X  12-core cpu~ ASUS ROG Crosshair VIII Dark Hero ~ EVGA RTX 3080 Ti FTW3~ G.SKILL Trident Z NEO 32GB DDR4-3600 ~ Phanteks Eclipse P400s red case ~ EVGA SuperNOVA 1000 G+ PSU ~ Intel 660p M.2 drive~ Crucial MX300 275 GB SSD ~WD 2TB SSD ~CORSAIR H115i RGB Pro XT 280mm cooler ~ CORSAIR Dark Core RGB Pro mouse ~ CORSAIR K68 Mech keyboard ~ HGST 4TB Hd.~ AOC AGON 32" monitor 1440p @ 144Hz ~ Win 10 x64
