PCI Slot power draw
the_Scarlet_one
formerly Scarlet-tech
  • Ribbons : 79
Wednesday, November 09, 2022 9:02 PM (permalink)
4090 owners, could you please run GPU-z sensor tab, and look at your PCI slot power draw, and post what GPU you have with the PCI power draw? So far I have seen between 7w at 17w at full load on 600w bios, but nothing more than 17w so far.
I do not have a 4090, and I am just super curious if NVidia and AIB’s are strictly pulling the 600w power limit off of the 12 pin, or if there is any AIB leveraging the PCIe slot 75w availability to remove some of the load off of the 12 pin.
I watched JayzTwoCents latest “EVGA not 4090” video, and he has 7.5 watts max power draw with the 600w bios for the power me two second clip where he shows the 600w bios at load. I won’t link the video because it is just 15 minutes of JayzTwoCentsless (spelled that way on purpose) rambling. It’s not worth sacrificing your ears, the bios doesn’t net higher scores on the pre-production GPU core.
22 Replies Related Threads
    Re: PCI Slot power draw Wednesday, November 09, 2022 11:13 PM (permalink)
    Gigabyte Gaming OC with Cyberpunk 2077 ray tracing load...
    CraptacularOne
    • Ribbons : 222
    Re: PCI Slot power draw Thursday, November 10, 2022 0:00 PM (permalink)
    Same for me, the card draws very minimal power from the PCIe slot. GN also mentioned how the cards sip power from the PCIe slot.
    Did the same as above in Cyberpunk 2077 max setting with psycho RT enabled at 5120x1440 resolution. Though mine is a bit higher at about 31w PCIe slot power draw. RTX 4090 Gaming Trio with 520w MSI Suprim BIOS flashed.
    Intel i9 14900K ...............................Ryzen 9 7950X3D
    MSI RTX 4090 Gaming Trio................ASRock Phantom RX 7900 XTX
    Samsung Odyssey G9.......................PiMax 5K Super/Meta Quest 3
    ASUS ROG Strix Z690-F Gaming........ASUS TUF Gaming X670E Plus WiFi
    64GB G.Skill Trident Z5 6800Mhz.......64GB Kingston Fury RGB 6000Mhz
    MSI MPG A1000G 1000w..................EVGA G3 SuperNova 1000w
    the_Scarlet_one
    • Ribbons : 79
    Re: PCI Slot power draw Thursday, November 10, 2022 1:40 AM (permalink)
    I am super curious why NVidia wouldn’t put more power usage on the pci slot to reduce the power pulled on the 12 pin as a way to slightly reduce heat for those experiencing issues.
    I would assume that if they did that, it would be seen as admitting there is a problem, which is why they likely won’t do anything.
    CraptacularOne
    • Ribbons : 222
    Re: PCI Slot power draw Thursday, November 10, 2022 2:32 AM (permalink)
    the_Scarlet_one
    The whole thing is getting blown WAY WAY out of proportion. There have now been numerous tests by people intentionally trying to compromise these cables and get them to melt yet no matter what they do they haven't been able to recreate it. I'm not saying it doesn't or can't happen because clearly it did but It's not because of a poor design of the cable and more than likely user error and them not fully inserting the plug into the socket that's causing the small number of issues.
    https://overclock3d.net/news/power_supply/psu_guru_chimes_in_on_12vhpwr_cable_controversy_-_insert_your_cables_fully/1
    These people that have the damaged cables are not going to outright say "yeah maybe I didn't fully insert the cable" and potentially void their warranty even though the issue is more than likely user error. They of course don't want to be on the hook and admit user error and be out $1600.
    This whole thing is just another "POScap" overreaction just like when 30 series first launched and it ended up being a driver bug and nothing actually wrong with the GPUs. These cases of burned cables are user error I'm almost certain at this point. What will be interesting is how the various GPU vendors handle these warranty claims. I've had my card for about a month now and no issue. My card is run at a daily overclock of 2850Mhz core and 22Ghz memory from basically day one for many a long gaming session.
    Nvidia didn't pull more power from the PCIe slot because they really don't need to and regardless the 66w that they could have got from the PCIe slot wouldn't have made really any difference at all in terms of heat or power draw from the card. .
    post edited by CraptacularOne - Thursday, November 10, 2022 2:35 AM
    kougar
    • Ribbons : 22
    Re: PCI Slot power draw Thursday, November 10, 2022 10:11 AM (permalink)
    the_Scarlet_one
    The slot is maxed at 75w so in the total scheme of things leaving 40w on the table isn't much. A tiny bump in clocks and putting the power target to 120% will cause the card to consume more than that easily. As AMD cards have demonstrated in the past, it's very easy to overdraw the PCIe slot and that's a very bad thing to do. There's only so many ways to use or interface the slot power, so GPUs often only use the slot power for separate circuitry that doesn't tie into the main rails because of this.
    CraptacularOne
    Blown out of proportion? Honestly that's probably true, ~30 crisped cards out of thousands isn't much. But it's still 100% unacceptable.
    Also, as quick as JonnyGuru and some others are to blame the victims, that they haven't been able to recreate the burned up cables by not fully inserting the connector themselves means they're still guessing. If it's SO SIMPLE to be a not fully-inserted cable, then why can't they recreate it themselves eh? More than just Jonny have tried. There are still other theories and probable causes in play.
    post edited by kougar - Thursday, November 10, 2022 10:15 AM
    Have water, will cool.
    the_Scarlet_one
    • Ribbons : 79
    Re: PCI Slot power draw Thursday, November 10, 2022 11:00 AM (permalink)
    CraptacularOne
    Funny you quote JonnyGuru as the source of blaming end users… Real stand up guy to follow through his lies after he keeps sticking his foot further down his own throat. Keep in mind, he said that the quad 8 pin didn’t have any way to tell there was four cables connected because he didn’t actually look into, just shoved that foot in his mouth and then got defense because he got caught. He was a great reviewer, but now that his name rides on the manufacturing of the product, he is vehemently defending it while deflecting blame. He has walked back too many topic for me to care what he says at this point.
    Most of these reviewers testing these scenarios have all been doing it for 1 to 2 hours, some more than that, but they haven’t been using most of the cards as much or as long as most end users would run them. More of them are looking at the probability now, but it doesn’t stop the fact that end users have received 12+4 with plastic molded directly into the actual pin. While there isn't a lot of cards experiencing the issue currently, how many people are not even paying attention to this topic right now? JayzTwoCentsless and JonnyGuru are not my two go to people at this point, because one knee jerk reacts to everything on reddit and the other is seemingly defending his own manufacturing at this point.
    And why is it with the cables that have melted, why is it only the outside pins melting, typically on both sides at once, not the center pins? If all of the pins are loose because the end user didn’t fully seat them, then all pins should be generating heat and melting more area that just the outside edges.
    post edited by the_Scarlet_one - Thursday, November 10, 2022 11:10 AM
    the_Scarlet_one
    • Ribbons : 79
    Re: PCI Slot power draw Thursday, November 10, 2022 11:18 AM (permalink)
    kougar
    AMD doesn't report PCIe Slot power draw through GPU-z only Voltage, and prior to the 3090ti, most GPU's from NVidia leveraged up to the 75w with no problem.  It was even reported that the 3090FTW3 was drawing up to 85w on some cards from the PCI slot, and users RMA's and needed new BIOS' to get it lowered.  So, the use of the PCI slot power only recently went down with GPU's, as far as can be tracked.
    A perfect example was the 3070 Founders that I just sold. It only used one 8 pin and had a 225w bios. 150w from the 8 pin and 75 from the PCI slot. It is far more uncommon for the PCIe 75 w to go completely unused at this time, as only two product have not made use of it.
    post edited by the_Scarlet_one - Thursday, November 10, 2022 11:24 AM
    CraptacularOne
    • Ribbons : 222
    Re: PCI Slot power draw Thursday, November 10, 2022 3:04 PM (permalink)
    the_Scarlet_one
    CraptacularOne
    You seem very angry about something you don’t own yet. Opinions of JonnyGuru aside the fact remains that no one has been able to recreate the melting issue in a controlled setting. They have nearly destroyed these cables trying to get them to fail and overheat and they can’t make it happen. So the only other logical assumption is user error. And that seems plausible at this point as we don’t really have any other reasonable conclusion. At last estimate there have been 100K RTX 4090s sold and only a minuscule amount of people (roughly 30 or so cases) have had their cable melt. While I agree that is not acceptable you also must agree that failure rate is very very low. I’m not trying to make excuses but look at the bigger picture here.
    They can’t recreate the melting in a lab and have no way to verify in what condition the users are installing their cards. If this was a massive issue there would be a lot more reports than the handful we have considering there are 100K cards out in the wild. I’m speaking from a perspective of experience here with this and my card is fine, no signs of melting or other damage and I’ve gamed heavily on it quite regularly with an increased power target and a flashed BIOS.
    Like I said, you don’t have to like the guy that’s not the point. The point is we don’t have any other more plausible cause for these isolated issues.
    post edited by CraptacularOne - Thursday, November 10, 2022 3:06 PM
    tresnugget
    Re: PCI Slot power draw Thursday, November 10, 2022 5:32 PM (permalink)
    CraptacularOne
    the_Scarlet_one
    CraptacularOne
    The closest I've seen to an adapter melting in a controlled setting was Ronaldo from Teclab hitting nearly 120c on the adapter with it not all the way plugged in with a 450w load. If he left it in I think it would've kept rising. He hit almost the same temps with it 100% plugged with a 1500w load.
    the_Scarlet_one
    • Ribbons : 79
    Re: PCI Slot power draw Thursday, November 10, 2022 8:08 PM (permalink)
    Why does someone have to own something to have an opinion? Why does someone have to own something to wonder what the root cause of an issue is?
    Why do people feel the need to say “my works fine”? Great. Thumbs up and congratulations. People loved saying that as users were having issues with their 3090FTW3’s, as if it somehow negates the fact something is happening. My brain can’t comprehend that thought process.
    When I bought my car, there was a consumer report that showed the tires used on an SUV were meant for a much lighter car, so the rubber would be destroyed at an unreasonably low usage. I contacted ford and they said “it’s only a few instances, you have nothing to worry about” until I was paying $1300 for new tires at 30,000 miles, when they were rated for 70,000. But hey, other peoples were fine, so why worry?
    When I spend the money on a new GPU, I prefer to know for a fact it isnt going to have a strange issue that more than a couple of people are reporting. The bigger thing to remember is 1: not everyone is checking their connector. 2: not everyone is reporting on Reddit that they have had an issue.
    It is entirely reasonable for people to be curious before making a purchase. It should be expected, rather than being shrugged off or condemned.
    As for JonnyGuru, I’ve only formed an opinion based on his public conduct. When he wasn’t making claims like he has recently, I didn’t have any issues with him, and actually enjoyed his website. Just not a fan right now.
    CraptacularOne
    • Ribbons : 222
    Re: PCI Slot power draw Thursday, November 10, 2022 8:29 PM (permalink)
    the_Scarlet_one
    Your brain can't comprehend that there are about 100k RTX 4090s out in the wild and only about 30 of them are experiencing an issue?
    I'm stating that my card is fine not as a way to counter anything happing, I'm stating is a matter of fact, nothing more nothing less. You seem to be caught up the mass paranoia that roughly 30 cards have experienced when by and large the vast majority of owners are having no issue what so ever. You are ignoring the fact that they are largely issue free. These things happen, things fail all the time it's part of a normal product's expected variance. There isn't a product mass released in the history of the planet that doesn't have a failure rate. It's commonly accepted that a failure rate of about 1% is acceptable. Do you know what the failure rate is for 30 bad cards out of 100,000? It's 0.03%. This whole thing is just drama and you and most others are eating it up.
    • Ribbons : 271
    Re: PCI Slot power draw Thursday, November 10, 2022 9:40 PM (permalink)
    The claimed 30 may be a small percentage, but it is abnormal and abnormally rapid. We have seen a handful in the past, but it was sporadic and usually way late in the product's life.
    It may be a small number, but it is a significant indicator of something abnormal.
    frankd3
    • Ribbons : 14
    Re: PCI Slot power draw Thursday, November 10, 2022 9:53 PM (permalink)
    I've heard over and over that 100k 4090s have been sold and are out there being used.
    I thought that info was being misinterpreted and that it was only the chips that Nvidia sent to AIBs.
    I was right. Here's a quote from Guru3D:  https://www.guru3d.com/news-story/nvidia-produced-over-100000-rtx-4090-units-thus-far,4.html
    Note that 100,000 units do not equal the total number of GPUs made or sold. Instead, it is the number of chips that were sent to partners so they could make RTX 4090 models.
    As far as I can tell we don't know how many built 4090s have been sold. At least, I can't find the data.
    EVGA Z590 FTW, i9-11900K, EK-AIO Elite 360 D-RGB, GSkill F4-3600C14D-32GTRSA, EVGA RTX 3090 Ti FTW3 Ultra, EVGA SuperNOVA 1600 T2, Corsair 5000D Airflow, BenQ EX2780Q 2560x1440, Windows 10 Pro
    CraptacularOne
    • Ribbons : 222
    Re: PCI Slot power draw Thursday, November 10, 2022 10:00 PM (permalink)
    While I agree this is abnormal, there really isn't a time table on how these things can happen especially when the issue can't be recreated despite many efforts in a controlled setting. They have tried to compromise these cables, they have tried to get them to melt to demonstrate it happening and maybe better understand it or how to prevent it. They cannot, so all we are left with is roughly 30 reports and here-say or anecdotal evidence from the end users. They are definitely not going to own up to doing anything wrong and potentially risk a warranty replacement. However as I've said, if they've intentionally damaged these cables, broken solder joints and overloaded the cables and still cannot get them to melt. The cable most likely isn't the issue. I'm starting to agree this is mostly user error and not plugging in the cable all the way. The way the cable is designed has all but been ruled out as a cause for failure with what these reviewers have subject them to. What else is left really? What reasonable assumption would you make?
    frankd3
    Sure, that's fair but we can assume it's a very large number of cards out in the wild. Even if it were only half of the estimated 100k GPUs that were sold through to users that would only make the 30 cases a 0.06% failure rate. Hell, even if it were only a quarter of the 100k units sold through to user that would make it a 0.12% failure rate.
    post edited by CraptacularOne - Thursday, November 10, 2022 10:09 PM
    the_Scarlet_one
    • Ribbons : 79
    Re: PCI Slot power draw Friday, November 11, 2022 0:35 PM (permalink)
    How many times, in the past, has NVidia told AIB’s to send their own cards back to NVidia for investigation when something comes up with a product?
    You think users wouldn’t admit to having the cable loose, yet we have people come onto the very forums complaining that their Hydrocopper cards were hit 100-105c and shutting down and they couldn’t figure out why, when they had never even realized that the card required external cooling. Yeah, people admit things, usually inadvertently. It’s a little strange that every user reporting the issue swears it wasn’t them, when someone typically would admit their fault even if it was just a slip up, because not everyone is a terrible person.
    Crap, I’m not sure why you are so severely offended by me posting. You seem absolutely hell bent to prove me wrong about something or shut me down for some reason. You do you. Have fun, pour your heart all over the keyboard. Get it all out. Just know that it doesn’t change my curiosity even .01%. It also won’t change my opinion that NVidia could be leveraging the power at the PCI connection either. So far your card is an outlier when looking at 4090 GPU-Z sensor tabs that i can find through google, and you are pulling 2 to 3 times more wattage than most users that have posted screen shots. Most sensor tab screenshots I can find seem to hover between 7w and 17w.
    arestavo
    • Ribbons : 77
    Re: PCI Slot power draw Friday, November 11, 2022 0:41 PM (permalink)
    CraptacularOne
    Hey now, assuming the "30" that were posted about are all the failures is a bit of a stretch, isn't it? That's just the people who bothered to post on reddit about it. Apparently Gamer's Nexus's email opened for this issue had hundreds of submissions, and even then that wouldn't be all of them. Quite a few folks with this issue, maybe even the majority, would just return the card for a refund or RMA and we'd not hear about it. There's even a good chance there are quite a few folks out there with melted adapters that aren't even aware of it.
    Too many unknowns to be certain.
    And it's very interesting that these 4090s have such a low PCIE slot power draw - coming from someone who had a 3090 FTW3 Ultra that drew over 93W on the PCIE slot.
    post edited by arestavo - Friday, November 11, 2022 0:43 PM
    CraptacularOne
    • Ribbons : 222
    Re: PCI Slot power draw Friday, November 11, 2022 1:05 AM (permalink)
    the_Scarlet_one
    I'm not at all offended by your posts, everyone is entitled to their own opinion. I'm looking at this from a numbers point of view and in that respect things are certainly not anywhere near as bleak as you or others are making it out to be. As for this being the first time Nvidia requested cards to be sent back no, Nvidia did in also request early samples of 30 series cards to be returned to them for inspection when the whole POScap hysteria was running rampant in the beginning, same thing when some GPUs were dying while playing New World and that was EVGA and Nvidia wanting them back for an autopsy. So Nvidia wanting a closer look isn't really anything new.
    As for the cards PCIe power draw we just don't have a big enough sample size to make any determination, but I think this is largely irrelevant too. In comparison the theoretical max is a drop in the bucket and wouldn't really alleviate any real strain when we are talking about a connector that can deliver 600w.
    arestavo
    CraptacularOne
    We don't know we can only go by what has been claimed or posted about. We have no way of knowing otherwise and must go with what we know and really that's all that we know as of now. Also if your RTX 3090 was drawing 93w from thew PCIe slot you need to RMA it, something is not right with it's power delivery and load balancing. It should never draw that much from a slot that is only rated for a theoretical max of 75w. Of all the cards that I own (and believe me I own quite a few) I haven't seen any of them pull more than 66-70w at max and only for a few seconds.
    frankd3
    • Ribbons : 14
    Re: PCI Slot power draw Friday, November 11, 2022 12:22 AM (permalink)
    I don't think the low slot power readings are all that unusual.
    With my 3090Ti, as I kept pushing the overclock higher (clock, memory and voltage) to get a better Timespy score I noticed that the board power went up and the slot power went down with each adjustment.
    Then I ended up with my second best Timespy record:
    and the slot power was at it's all time lowest 8.1W and board power at it's highest 506.3W (using the XOC bios)
    However, normal non-oc gaming the slot power is always in the 50's.
    I didn't know what to make of that so I never said anything.
    But maybe the 4090 overclocks have something to do with the low slot power?
    post edited by frankd3 - Friday, November 11, 2022 12:27 AM
    emmett
    Re: PCI Slot power draw Friday, November 11, 2022 10:31 PM (permalink)
    Interesting
    4090 Asus TUF. all stock, GPUZ shows its drawing 1.050 max I guess I need another bios for 1.1?
    PCIE Slot Power
    At IDLE 6.4
    Just setting fans 90% it goes to 10
    I have yet to see it go over 16 at all. This was with 450 watts total draw in GPUZ and +175 core. Porte royal.
    post edited by emmett - Friday, November 11, 2022 10:35 PM
    Currently using
    Gigabyte Z370 Aorus Gaming 7
    EVGA 2080 TI KingPin
    Intel 9900K
    GSkill 3200
    EVGA G2 1300
    kougar
    • Ribbons : 22
    Re: PCI Slot power draw Friday, November 11, 2022 11:41 PM (permalink)
    the_Scarlet_oneAMD doesn't report PCIe Slot power draw through GPU-z only Voltage, and prior to the 3090ti, most GPU's from NVidia leveraged up to the 75w with no problem.
    They don't, but THG and Buildzoid built rigs that measured it when proving AMD's RX 480 cards were overdrawing the 75W slot limit by ~15w. Can confirm my 1080 Ti is drawing around 40-60w from the PCIe slot depending on Folding project.
    blaise
    Re: PCI Slot power draw Saturday, November 12, 2022 4:51 PM (permalink)
    ASUS TUF 4090 OC here and the most I've seen for PCI slot draw is around 12~14W in Port Royal using the updated BIOS V95.02.18.80.AS05. I haven't tweaked voltages yet (and it appears I can) but I have the power target slider set to 133% and +120 GPU, +1400 Memory.
    the_Scarlet_one
    • Ribbons : 79
    Re: PCI Slot power draw Wednesday, November 16, 2022 7:20 PM (permalink)
    Posted this in its own thread with more details, but GN has made a more in depth video about the 12VHPWR cables.
    #23
