PC building freshman ask the difference between CHA_FAN and RAD_FAN from ASUS z690 extreme
Harrypotterrrr
2022/01/31 12:17:30 (permalink)
Hi everyone, I am the freshman of DIY PC builder. Recently, I bought Asus z690 extreme motherboard, and prepared up to 13 fans for the Lian-li o11 evo case (of course I am still waiting for the evo case which is being shipped from CA Newegg). I am now reading the manual of the motherboard z690, preparing for the approaching desktop case
I am a little confused about the difference between these two IO port on Asus motherboard: CHA_FAN and RAD_FAN. Besides the ASUS HYDRANODE as the manual pointed out, is there any other differences between this two?
Specifically, I bought 4 x LL120 and 6 x QL120 chassis fan together with NZXT z73 AIO 3 fans, summing up to 13 fans for cooling my case.
To gather them and synchronize them, I bought 2 x corsair Commander core XT. All accessories are shown as below.
I wonder how I could connect all of these fans to the motherboard to get the best synchronized performance, including power control and RGB control.
Further, I wonder what is ASUS HYDRANODE for, is this function used to synchronize all fans connected to one Corsair commander core XT?
I am a novice regarding building PC, so I sincerely hope to receive your previous suggestions and help. Appreciate in advance.
post edited by Harrypotterrrr - 2022/01/31 12:23:56
6 Replies Related Threads
    • Ribbons : 115
    Re: PC building freshman ask the difference between CHA_FAN and RAD_FAN from ASUS z690 ext 2022/01/31 18:51:42 (permalink)
    Moved to Hardware.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
    Harrypotterrrr
    Re: PC building freshman ask the difference between CHA_FAN and RAD_FAN from ASUS z690 ext 2022/01/31 20:20:42 (permalink)
     Thank you!
    Moved to Hardware.
    nomoss
    • Ribbons : 7
    Re: PC building freshman ask the difference between CHA_FAN and RAD_FAN from ASUS z690 ext 2022/02/01 06:38:10 (permalink)
    HydraNode Asus makes it so that multiple fans connected to one header using a splitter can still be individually controlled and monitored.
    The fans must be compatible.  I don't think you could connect the Core to it.
    Probably better to look for Core XT/fan setups at https://forum.corsair.com/ or check out https://rog.asus.com/forum/search.php
    Associates code:  9OYA1P1FRHQ3SGN
    Imgur    modsrigs:  Chemical X   RedWing   Utonium   TY for the +1s!
    • Ribbons : 123
    Re: PC building freshman ask the difference between CHA_FAN and RAD_FAN from ASUS z690 ext 2022/02/01 07:13:12 (permalink)
    I like to use a fan hub - take the load off the MB with the separate power connection on the hub & use only one MB header to connect many fans
    You Must use - one CPU fan header
    All other fan headers are optional ... just do not exceed the rated load
    RGB & ARGB ..... do not mix ..... one is 5V the other is 12V .... always check that the items used have the same pin layout - not as universal as one might expect
    Getting many brands of software & hardware to "sync" RGB ... that is always a challenge ... hope all your parts are advertised to work together
    Sometimes ARBG & RGB utility software can cause issues with other software
    Harrypotterrrr
    Re: PC building freshman ask the difference between CHA_FAN and RAD_FAN from ASUS z690 ext 2022/02/01 19:43:13 (permalink)
    That is useful thank you!
    nomoss
    Probably better to look for Core XT/fan setups at  or check out
    Harrypotterrrr
    Re: PC building freshman ask the difference between CHA_FAN and RAD_FAN from ASUS z690 ext 2022/02/01 19:46:44 (permalink)
    Thankyou for your information, hope i could handle all fans well. I will get down to build them after I receive my case.
