Zadolbator
Hi I got a new sound card Nu audio pro 2.0 and after installing the latest drivers there is no Hi-Res Mode in the panel. How can I repair it?
coolmistry
- Ribbons : 45
Re: No Hi-Res Mode in Nu audio pro card
2020/02/17 03:12:44
Hello and Welcome to the Forum Have you try restart your Windows?
Windows 11 Home 64bits up to Dated i9 11900K 5,275 MHz (3,500 MHz) || EVGA Z590 FTW WIFI || 2 x Nvidia RTX 2080 Ti FE || 32Gb Dominator Platinum DDR3 3600mhz XMP OC 3800mhz || 500gb Samsung 980 Pro NVMe || 500gb Samsung 970 EVO and Sata M.2 (1 x SSD and 1xHHD) || EVGA CLCx 360 Cooler || EVGA Supernova 1300w X3 || EVGA Z10 Keyboard || EVGA TORQ X10 mouse ||EVGA DG 77 case || Acer Predator X35 35" 200Hz G-Sync || Logitech Z906 5.1 system sounds SPDIF|| Kaspersky Internet Security
Zadolbator
2020/02/17 03:19:21
Hi Of course I restarted windows))
coolmistry
- Ribbons : 45
2020/02/17 03:24:33
Can we please have your full spec of your PC and What OS are you using? it help all member will review your pc and try help you You can put your PC Spec in your Mod rigs save you time
Zadolbator
2020/02/17 03:39:14
Hi. My specs Windows 10 Pro 64bit v1909 Intel Core I7 9700k , Asus Z390 Hero XI Wi-Fi, Asus Geforce GTX1070, 32GB RAM Corsair RGB PRO 3600Mhz, 1TB SSD WD Black, EVGA Nu audio PRO sound card, Be Quiet Silent Loop 240 cooler.
coolmistry
- Ribbons : 45
2020/02/17 03:43:27
Thanks for you PC Spec Is your Windows Sound Setting Default to NU Audio not Windows Audio?
Zadolbator
2020/02/17 03:46:08
Sorry, dont understand what does it means..
belmont1
2020/02/17 03:46:15
same as me i dont have the High res button
Zadolbator
2020/02/17 03:48:56
belmont1 same as me i dont have the High res button
What cofiguration of sound card do you have, 2.0 or 7.1?
belmont1
2020/02/17 03:49:30
i use 2.0 as sound configuration
Zadolbator
2020/02/17 03:52:05
May be only EVGA NU Audio Pro 7.1, 712-P1-AN21-KR, 7.1 Surround, has High res button?
coolmistry
- Ribbons : 45
2020/02/17 03:52:41
Zadolbator Sorry, dont understand what does it means..
Sorry let me show you picture! Please ignore my Sound Core 3Di that where my default. Maybe your NU Audio is not default? Have a look in your Sound Control panel?
coolmistry
- Ribbons : 45
2020/02/17 03:53:45
Zadolbator May be only EVGA NU Audio Pro 7.1, 712-P1-AN21-KR, 7.1 Surround, has High res button?
I not sure but I don't have NU Audio thought but try help you all
Zadolbator
2020/02/17 03:54:31
I will check little bit later at home.
coolmistry
- Ribbons : 45
2020/02/17 03:55:51
Zadolbator I will check little bit later at home.
No problem and post us back and members who know more and will look at your post and try helping you all
Zadolbator
2020/02/17 07:25:09
Nu is a default for audio
belmont1
2020/02/17 07:26:57
Zadolbator Nu is a default for audio
what you mean?
Zadolbator
2020/02/17 09:09:36
I mean, that NU audio sound card is a default device in sound control panel.
EVGA_Lee
Moderator
- Ribbons : 14
2020/02/17 09:21:57
☼ Best Answerby Zadolbator 2020/02/17 09:49:48
I believe you'll only see this with NU Audio Pro in a 7.1 configuration (i.e. Pro + Surround connected, regardless of whether you're using 7.1, 5.1, etc.). The reason for the Hi-Res mode is that multi-channel will not work higher than 192kHz, so this required a way to toggle between higher resolution or the multi-channel mode. Since this isn't a concern for stereo output on these cards, you shouldn't need or see the Hi-Res Mode box on the Pro (2 ch) only. On the other hand, if you can't set the sample rate higher than 192kHz (or don't have the option to), that's a different matter, and I'll need to look into that.
Zadolbator
2020/02/17 10:01:13
EVGATech_LeeM I believe you'll only see this with NU Audio Pro in a 7.1 configuration (i.e. Pro + Surround connected, regardless of whether you're using 7.1, 5.1, etc.). The reason for the Hi-Res mode is that multi-channel will not work higher than 192kHz, so this required a way to toggle between higher resolution or the multi-channel mode. Since this isn't a concern for stereo output on these cards, you shouldn't need or see the Hi-Res Mode box on the Pro (2 ch) only. On the other hand, if you can't set the sample rate higher than 192kHz (or don't have the option to), that's a different matter, and I'll need to look into that.
Hi Thank you very much! The reason was only about Hi res toggle in the panel, and I can set the sample rate higher than 192KHz, there is no problem with it. The only reason that I mentioned that there is no Hi res toggle is that this option is marked on the web page with the Nu audio pro 2.0 sound card in the software manual, I think there must be some marking that there will be no Hi res toggle in the panel if you don't use additional surround card. Sorry for my English)
