Re: Need help with my card gtx 980 ti sc acx 2.0
2018/11/02 16:18:25
Hello noexist and welcome to the EVGA forums! 75 degrees is a good temperature under load but would be considered abnormally high if the system is idling.
Since this is a factory overclocked card, there is an option in Nvidia control Panel called "Debug mode", enable it and then let us know if this helps to stop the black screen problem.
