NVIDIA GeForce RTX 5070 Ti Leak Tips More VRAM, Cores, and Power Draw
  • Ribbons : 86
2024/12/15 02:53:34 (permalink)
https://www.techpowerup.com/329873/nvidia-geforce-rtx-5070-ti-leak-tips-more-vram-cores-and-power-draw
It's an open secret by now that NVIDIA's GeForce RTX 5000 series GPUs are on the way, with an early 2025 launch on the cards. Now, preliminary details about the RTX 5070 Ti have leaked, revealing an increase in both VRAM and TDP and suggesting that the new upper mid-range GPU will finally address the increased VRAM demand from modern games. According to the leak from Wccftech, the RTX 5070 Ti will have 16 GB of GDDR7 VRAM, up from 12 GB on the RTX 4070 Ti, as we previously speculated. Also confirming previous leaks, the new sources confirm that the 5070 Ti will use the cut-down GB203 chip, although the new leak points to a significantly higher TBP of 350 W. The new memory configuration will supposedly run on a 256-bit memory bus and run at 28 Gbps for a total memory bandwidth of 896 GB/s, which is a significant boost over the RTX 4070 Ti.
Supposedly, the RTX 5070 Ti will also see a bump in total CUDA cores, from 8448 in the RTX 4070 Ti to 8960 in the RTX 5070 Ti. The new RTX 5070 Ti will also switch to the 12V-2x6 power connector, compared to the 16-pin connector from the 4070 Ti. NVIDIA is expected to announce the RTX 5000 series graphics cards at CES 2025 in early January, but the RTX 5070 Ti will supposedly be the third card in the 5000-series launch cycle. That said, leaks suggest that the 5070 Ti will still launch in Q1 2025, meaning we may see an indication of specs at CES 2025, although pricing is still unclear.
CES 2025 is fast approaching so hopefully the release is coming soon.
0 Replies Related Threads
