Hi guys,
I have just installed a replacement NU A. Pro card which I got through via RMA. (Just the main card, no 7.1)
On installing this card...it showed basically the same issue as the previous card. The sound, when it does output sound, is 'choppy' and cuts in and out for about 30 seconds or so, then completely cuts out and there is no sound output. This happens on the Windows or EVGA sound test screen, youtube, games, MP3 etc...any sound output is affected in the same way.
I have had one bit of luck though - the only way I can reliably get the card to output sound is when I leave the bitrate at 24-bit 96kHz. Not the best for a card like this. As soon as I change that value, either in Windows or using the EVGA utlility, the sound cuts out again...and the only way I can get it back is to perform a driver re-install. If I change any value in the EVGA software, same issue...the sound cuts out.
This sounds bonkers I know. Has anyone else seen this behaviour before?
I've got 1.01 installed with firmware 1.4.
