crash087
Re: Low FPS with low usage
2017/05/27 10:04:14
arestavo
crash087
Sajin Download 3dmark, run the fire strike benchmark, post the hyperlink to your score here.
http://www.3dmark.com/3dm/20161505
Those scores look about right to me - especially the GPU tests as they are bang on.
yea, i have a feeling its not an issue with the card itself, physically, I'm thinking theres some setting somewhere , its not an issue most of the time because it sits around 90 fps, but when it drops down below 60 during shootouts and stuff, and the usage is sitting at 40% i get pissed cuz you would think it would up the usage whenever it drops, especially when its got that much head room
- Ribbons : 282
2017/05/27 11:35:42
arestavo
- Ribbons : 77
2017/05/27 12:54:42
crash087
arestavo
crash087
Shootouts it drops GPU usage? That's a CPU bottleneck. The CPU actually does most of the heavy lifting when it comes to calculating shadows, and during a shootout with explosions going off (firearms, grenades, etc.) the CPU gets hit up hard for those calculations. When a CPU can't keep up, GPU usage drops because the GPU is waiting on those CPU calculations. Turning down shadows, or turning them off entirely, may help with your low GPU usage in games where that happens. Or you can just start playing DX12 games as they aren't as heavily single threaded, spreading the load across multiple threads instead of one primary thread.
2017/05/27 13:26:56
Yep. Score looks good. Time to start adjusting settings.
crash087
2017/05/28 10:32:07
I have a hard time believing its the CPU, if it were constantly at 100% usage then sure, but it never goes above 35% when playing SC2, or 80% in Andromeda
ipkha
- Ribbons : 6
2017/05/28 10:40:44
crash087 I have a hard time believing its the CPU, if it were constantly at 100% usage then sure, but it never goes above 35% when playing SC2, or 80% in Andromeda
Each core maxing out reports 25% on a 4 core system. So if a single thread of the game maxes s core it will hold up any other thread that relies on it.
- Ribbons : 282
2017/05/28 11:31:26
Retest with HT Disabled in the Bios.
MonkJayn
2017/05/28 12:39:32
Huh, I thought that score looked a little a low, I get http://www.3dmark.com/fs/12413719 , with a pair of 980's, I know benchmarks are a best case scenario with sli, but I've generally seen a single 1080ti beat them, still waiting for my ftw3's to ship so can't do any direct comparison myself just yet, but isn't your memory running a little slow?
- Ribbons : 282
2017/05/28 12:48:19
MonkJayn
2017/05/28 12:58:39
Does 3dmark just report the memory speed wrong for ddr5x, or, half what it would for ddr5? As that memory speed is literally half what I would expect it to be, at 5500GHz Vs the 11GHz the 1080ti should be running at. And I was referring to the GPU score not overall/ combined, unless I've got myself mixed up that is, in which case, my bad.
post edited by MonkJayn - 2017/05/28 13:00:43
- Ribbons : 282
2017/05/28 13:03:04
MonkJayn Does 3dmark just report the memory speed wrong for ddr5x, or, half what it would for ddr5? As that memory speed is literally half what I would expect it to be, at 5500GHz Vs the 11GHz the 1080ti should be running at. And I was referring to the GPU score not overall/ combined, unless I've got myself mixed up that is, in which case, my bad.
It is more that the OP is thinking that his CPU not an holding his scores back. But then I am not sure.
MonkJayn
2017/05/28 13:07:34
Yeah I get the CPU is having an impact, it was just the memory speed looked off, but someone elses comparison also showed it at the same rate, so I guess it's just an oddity of ddr5x to x8 for the total not x4 as is the case for ddr5. Strange.
arestavo
- Ribbons : 77
2017/05/28 13:18:51
MonkJayn Yeah I get the CPU is having an impact, it was just the memory speed looked off, but someone elses comparison also showed it at the same rate, so I guess it's just an oddity of ddr5x to x8 for the total not x4 as is the case for ddr5. Strange.
Depends on the program. Some report the full speed 11GBps, and some report 5.5GBps, and yet others report 2.75GBps - it's all in how the software was written.
MonkJayn
2017/05/28 13:34:12
Yeah, I was expecting to see 2750 or there about a, hence why when I saw 1375 I thought something was wrong there initially, odd, then I've no idea why his FPS is so low, is it low in any other games? Or just ME:a and sc2?
