PCDesignerRyan
Hi, I have a GeForce GTX 780 by Asus and I have a desire to get a second of the same card and attach water blocks to both of them why two-way SLI-ing. I was wondering if you can provide me with a known reputable means of liquid cooling for this particular GPU with cost not being an issue at this time. I am looking for a full system liquid cooling system from the CPU to the GPU to the RAM but for now, the GPU is the main focus. Thank you, and please feel free to visit and like my page on Facebook. Just look for PC Designer. PC Designer Ryan
post edited by PCDesignerRyan - 2014/04/07 04:49:36
Gomez99
- Ribbons : 14
Re: Liquid Cooling a GPU Help
2014/04/07 13:11:37
Is it reference design or cu2?
notfordman
- Ribbons : 28
2014/04/07 15:06:48
Just an FYI , I have seen many reply by saying that the RAM cooling is not really needed. Are you starting from scratch on w/c or do you have any parts yet? Oh, and welcome to the forums!!
- Ribbons : 115
2014/04/07 19:05:47
Moving to General Hardware.
PCDesignerRyan
2014/04/07 19:51:31
So far I don't have anything, but I haven't really found any place that deals in a full system liquid cooling system, other than Frozen CPU. It seems like they have EVERYTHING I need as far as all parts concerned go, but I still don't know the tricks of the trade concerning building a properly liquid cooled system. What works and what should I avoid using? What size tubing? What Reservoir? What are some neat tricks concerning building out of the CM Cosmos II case? Thanks for the assists! :)
PCDesignerRyan
2014/04/08 08:39:36
notfordman Just an FYI , I have seen many reply by saying that the RAM cooling is not really needed. Are you starting from scratch on w/c or do you have any parts yet? Oh, and welcome to the forums!!
True about the RAM cooling but I figure if I am going to do it I may as well go all out and cool everything. Frozen CPU even has water blocks for HDDs. I don't have any parts yet but I am looking to put some together. I could really use some pointers on a really reputable setup.
PCDesignerRyan
2014/04/08 12:06:21
Hey so I figured out exactly what I need to know. So, I need a map, of sorts, of what is needed for a liquid cooling system. While I have the general idea of it down, I need a bit more of the specifics side. I know that you need a pump, fittings, a resirvoir, tubing, the water blocks for CPU and GPU or whatever else you are cooling, and that they need to make a loop. So, with that being said, from the pump back to the resirvoir again, how does this go? The tube starts from the resirvoir? How does a fitting play in, I know it attaches to the tube but is there anything more involved than putting it on? Tubing goes from the resirvoir to the forst waterblock, and between the end of the tube and the waterblock itself, does a fitting hold the tube to the waterblock? Basically, how do the tubes attach? Is this the purpose of the fitting? How does the pump attach to the resirvoir? What about power consumption? Right now I am using a CM V1000. Do I need something with more power? Also, about the loop. Is there a minimum or maximum amount of range for the loop before the pump is no longer strong enough to pump the coolant all the way through the loop? I guess we can start with that. Thanks.
notfordman
- Ribbons : 28
2014/04/09 11:34:25
Here's a thread with some sound advice from one of our great water cooling guys. http://forums.evga.com/tm.aspx?m=2120637 Basically you want [at least] 120mm rad for each component, for your 2 GPU's I would use a 360 rad if possible. Try to avoid the colored coolants, instead use colored tubing if that's your thing. And the most used coolant is distilled water with either a silver kill coil or a biocide to prevent mold and nasties. http://www.frozencpu.com/products/11441/ex-tub-705/IandH_Silver_KillCoils_-_Antimicrobial_999_Fine_Silver_Tubing_Reservoir_Strip.html?tl=g30c103s186 http://www.frozencpu.com/products/11744/ex-liq-154/IandH_Dead-Water_Copper_Sulfate_Biocidal_PC_Coolant_Additive_-_15_mL.html?tl=g30c103s186#blank Loop order I have read really doesn't matter, because it will eventually equalize temps. When you build your loop take into account a way to drain the system, this can be done with a simple T fitting and plug. A popular choice to use : http://koolance.com/drain-valve-for-id-13mm-1-2in DO not mix Aluminum with copper, ect. It can cause corrosion and other issues. There are lots of choices on reservoir's you can go with an all in one where the pump is in the res. , or you can go separate. On your case I might choose an all in one, BUT it could be done many different ways. Here's an example of a pump/res combo : http://www.frozencpu.com/products/16259/ex-pmp-197/XSPC_Dual_525_Bay_Reservoir_Pump_Combo_-_D5_Vario_Included.html?tl=g30c97s152Love that case BTW. As far as fittings it is personal choice. You can go with the simplest barbs where the hose just pushes on, or compression fittings the fitting is the barb and clamp in one. The barb fittings use a clamp, on the compression the tightening of the nut is the clamp and gives the cleanest look IMO. Then again it's personal choice. Make sure w/e size tubing you go with to buy matching fittings. A popular choice is 1/2x3/4 When you have everything assembled don't be tempted to power on PC. Matter of fact don't plug in motherboard until after leak test. Leak test is performed by either using a premade jumper plug, or jumping the green pin [on 24 pin plug] to any black pin to power up PSU. http://www.frozencpu.com/products/5141/psu-218/FrozenCPU_24-pin_Power_Supply_Jump_Start_Connector.html And one thing I recommend are quick disconnect fittings. This enables you to take out each component without having a huge mess. It is a convenience when you have a failure which may or may not happen. It does of course add to the cost. http://koolance.com/help-quick-disconnect-shutoff-couplings All the choices I have listed are just options to show what is available, you are free to choose w/e direction . You might take a look in the marketplace for some of your components. I have seen fittings, ,reservoir , pumps and rads for sale. Could help save some $$. Unfortunately you need 50 post's to be able to see/use it. Hope that helps. Enjoy your build!!
BF3PRO
2014/04/09 13:25:59
From your posts you need to go read stickies at other sites. Performance-PCs.com is superior to FrozenCPU by a long shot. http://lifehacker.com/594...ng-your-computerttp://www.overclockers.com/forums/showthread.php?t=628092ttp:// www.overclockers.com/forums/showthread.php?p=7620273#post7620273
My Affiliate Code: OEESSSDNZV
MovieMike
2014/04/12 17:55:01
Gary @ SideWinderComputers was a pleasure to deal with when I was building my first water cooled setup, hes quick to answer emails and can help if you have any questions/need advice. If you're located in the USA you may have a MicroCenter near you, they have a lot of parts in stock with some pretty decent prices.
PCDesignerRyan
2014/04/13 19:39:27
Thanks guys! This really really helps a ton and i really appreciate it! T keep track of our progress check us out on Facebook. Search PCDesigner or PC Designer Ryan and you will find us or for a direct link to the sire just PM me. I really appreciate it. :)
PCDesignerRyan
2014/04/15 07:34:40
So if I am ordering: 7/16" ID / 5/8" OD XSPC HighFlex tube, what size compression fitting do I need? I guess... is there a tubing to fitting ratio sizing chart or something? Can anyone recommend a waterblock for the Asus GeForce GTX 780 GPU? Thank you for the help. :)
post edited by PCDesignerRyan - 2014/04/15 09:32:31
PCDesignerRyan
2014/04/15 07:35:41
MovieMike Gary @ SideWinderComputers was a pleasure to deal with when I was building my first water cooled setup, hes quick to answer emails and can help if you have any questions/need advice. If you're located in the USA you may have a MicroCenter near you, they have a lot of parts in stock with some pretty decent prices.
What is his email? Is it ?
notfordman
- Ribbons : 28
2014/04/15 12:58:04
Link to sidewinder with contact links. http://www.sidewindercomputers.com/info.htmlYou should also post a build log in the mod rigs section here. We always like to see cool projects and hardware. It doesn't have to be EVGA for that matter. Good luck on your build. Some people buy the 7/16 tube to fit on a 1/2 barb for a really tight fit. If your going with compressions you will need the appropriate size. They do offer the cleanest look in a build.
infinitist
2014/04/22 02:12:21
this is my rig i just finished with liquid cooling ... i built my own tank and plumbed it myself ... she won't leak. X79 Dark 4930k i7 gtx770 hydro copper 1000w evga power supply 1/2" tubing and brass plumbing fittings right from the home depot
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
2014/04/22 03:17:55
PCDesignerRyan So if I am ordering: 7/16" ID / 5/8" OD XSPC HighFlex tube, what size compression fitting do I need? I guess... is there a tubing to fitting ratio sizing chart or something? Can anyone recommend a waterblock for the Asus GeForce GTX 780 GPU? Thank you for the help. :)
EKWB seems to make pretty good Waterblocks all around. It may not be the look you are going for though. XSPC makes some nice looking black, but never seen the reviews for one. About the 7/16x5/8 tube, you answered your own question.. get 7/16x5/8 compression fittings... .... ... The compression fitting it advertised as what size hose it fits... so, if you were getting 1/2x3/4 hose, you would get the same compression fitting. it's a game of match the numbers.
