LED Sync delay between devices, and no sync on NU Audio card
Tweaked
  • Ribbons : 29
2020/11/25 09:39:35 (permalink)
Subject says it all basically. I have a DG-7, CLC-280, and NU Audio sound card. The LED Sync seems to work between the case and the CLC, but the CLC is a little delayed, so it gets out of sync after a short while. Also, the NU Audio card doesn't appear to sync at all. Any suggestions?
P.S. I also have the EVGA Z10 RGB, and UnleashRGB software doesn't seem to have LED Sync. Is there a way to get my KB to also Sync?
EVGA DG-77/ EVGA 750 G2/ Gigabyte B450/ AMD Ryzen 5 3600/ 16gb Crucial Ballistix DDR4-3600/ RTX-2080 XC/ Dell S2716DG / Windows 11 64
3 Replies Related Threads
    Traaaaan
    Re: LED Sync delay between devices, and no sync on NU Audio card 2020/12/09 05:30:44 (permalink)
    After the most recent nu audio driver my sound card no longer starts with the static color I set it in the nu audio software. It's just rainbow and I have to go in and set it again whenever I turn on my pc
    Tweaked
    • Ribbons : 29
    Re: LED Sync delay between devices, and no sync on NU Audio card 2020/12/17 06:58:25 (permalink)
    Traaaaan
    I'm not having that issue.
    I'm surprised no one else is having the same problem I'm having. Surely, I can't be the only one.
    mattsb84
    Re: LED Sync delay between devices, and no sync on NU Audio card 2021/01/06 08:08:16 (permalink)
    Having the same issue between the EVGA Nu Audio Card and EVGA RTX 2070. I'm not seeing a way to get them sync'd up in Precision X1 at all.
