Cancel077
For those that have been waiting for the hybrid kit, the FTW3 kit is finally in stock Get it while you can! As of 1735 EST time. EVGA HYBRID Kit for EVGA GeForce RTX 3090/3080 Ti/3080 FTW3, 400-HY-1988-B1, ARGB https://www.evga.com/prod...tecode=8IT954OVFQ17LN9Associate code: 8IT954OVFQ17LN9 for an additional 10% off. (Product link above already has the associates code linked to it) Cheers!
post edited by Cancel077 - 2022/05/19 14:39:35
Re: IN STOCK - EVGA HYBRID Kit for EVGA GeForce RTX 3090/3080 Ti/3080
2022/05/20 08:16:58
no idea how fast they sold out, but they are not in stock now
yavorsky
2022/05/20 16:30:48
Had my order canceled on me due to them overselling too. Back on the list I go.
VegetaCreeper
- Ribbons : 9
2022/05/20 22:38:07
I have one coming. I'm pumped
Be The change in the World you want to seeUse my associate code if you want to save money on your purchases : DIC39SVDZOR8D11
1stormseekr
2022/05/23 18:53:16
Back in stock now, but i need the one for the xc3....almost tempted to get this one and make it work.
2022/05/24 12:43:09
just got one
Cancel077
2022/05/24 15:59:11
Weird! I wasn't getting notifications on this thread for some reason! My area also had a storm and lost power for 3 days. Either way, it's in stock right now again! 😁
post edited by Cancel077 - 2022/05/24 16:01:27
Cancel077
2022/05/24 16:01:59
Cool GTX just got one
Sweet!! Yeah when I initially posted it, it went out of stock within the hour.
Cancel077
2022/05/24 16:04:27
1stormseekr Back in stock now, but i need the one for the xc3....almost tempted to get this one and make it work.
Just find a schematic of the ftw3 and xc3 if you'll be doing that. You don't want to mess up your card. Plus the pump on these sometimes go pretty quick, so any modifications to the shroud might void your warranty.
firerain
2022/05/25 08:34:46
280 just falls short. I have 4 fans on that thing and it cant cool 3080ti under heavy load. You need at least 360 and coper shims.
Pc0 Legion pre built / 3090Fe / 10900k Pc1 8700k /2x EVGA 3080 TI / EVGA Z375 micro Pc2 EVGA x99 micro / E5 2678 v3 / 3080 / EVGA 3060, EVGA 1660 ti Pc3 EVGA x99 micro / E5 2620 v3 / EVGA 3080, 1650 Pc4 HP pre built AMD R5 3500 / 2060 ko
Cancel077
2022/05/25 08:48:44
firerain 280 just falls short. I have 4 fans on that thing and it cant cool 3080ti under heavy load. You need at least 360 and coper shims.
What do you mean it can't cool it? I have a 3080ti and it cools just fine. If you are referring to the memory temps, then yes I agree. I myself did buy a copper plate for it and now it is how it should be!
firerain
2022/05/26 05:39:48
Cancel077
yah, mem is sad.
MDG73
2022/06/06 13:34:08
Cancel077
Where did you get this copper plate from?
9900k OC 5.0GHz Lian-Li Galahad 360 ASUS Z390-E Gaming MB Corsair Vengeance Pro 32Gb 3200MHz EVGA 3080 Ti FTW3 Ultra 12GB LG 34GP950G-B Monitor Samsung 500GB & 1TB 970 EVO Plus M.2 Drives Samsung 870 EVO 2TB SSD Team Group CX2 2TB SSD EVGA SuperNOVA 1300 P+, 80+ PLATINUM Corsair 5000D Airflow Affiliate Code: U6E1FWAKJI
Cancel077
2022/06/06 13:48:12
MDG73
Cancel077
Coolmygpu https://www.coolmygpu.com...;sbp=false&q=false
post edited by Cancel077 - 2022/06/06 13:49:14
MDG73
2022/06/06 14:19:18
Awesome! Thx Took the dive and getting both.
Cancel077
2022/06/06 14:33:57
MDG73 Awesome! Thx Took the dive and getting both.
Nice! No problem! Just make sure you get decent amount of thermal paste (mx4). You'll want to be generous so you don't have to redo in case there's some uneven spots. I've done mine one time only and my temps are good. So my tip just be generous, don't cheap out! (I've used grizzly kryonaut for the gpu though)
MDG73
2022/06/06 16:24:54
Cancel077
MDG73
Cancel077
Coolmygpu
How big a difference did the new copper plate make with temps for the memory and did you stick with the stock fans? thx
Cancel077
2022/06/06 16:44:34
MDG73
Cancel077
MDG73
Cancel077
Coolmygpu
For me about 15C or so less for mining. I was mining at 90-94C ish, now I mine at around 74-78C. It does depend a lot on ambient temp so about 15C or so. And I did not stick with the stock fans because they are loud, I went with the noctua p12 redux 1700. However, I already switched prior to installing the copper plates. So this is 15C less purely due to the copper plates. (you get two, one to replace the stock one that comes with the pump, the other replaced the pads, and thermal paste is in between the two plates). It goes memory - paste - copper plate - paste - copper plate - paste - water pump.
post edited by Cancel077 - 2022/06/06 18:15:27
MDG73
2022/06/06 18:06:38
Thats awesome. Thanks for the info :)
Cancel077
2022/06/06 18:15:45
MDG73 Thats awesome. Thanks for the info :)
No problem! Good luck!
MDG73
2022/06/20 11:15:53
Cancel077
Well I got both items and I can tell you I am not disappointed. I think the highest I have seen my memory get to is 64C. The hot spot is lower than that by a few degrees. GPU hits around 50c on average. This hybrid cooler is awesome. No noise issue, the only thing I would like to see changed is that the fan connector cable get lengthened a bit so that you can tuck the connectors behind motherboard tray. I do believe the copper replacement from coolmygpu has helped alot. I also think there has been a revision of the cooler itself. The hose connector does not require you to screw it in now.
Cancel077
2022/06/20 12:18:47
MDG73
Cancel077
That's awesome! Your memory temp is better than mine! I think the mod is definitely a good one, I wish it existed on the stock hybrid cooler as is instead of us needing to mod it ourselves (I believe the 3090tis hybrid cooler already has a copper plate but I am not sure, I have just read about it). Interesting to note about the hose, are you talking about where the pump is? I know that for the FTW hybrid kit, you need to screw in the plastic piece to the shroud and it it will hold the bump/hose in place, but for the XC3 hybrid kit you do not have that.
post edited by Cancel077 - 2022/06/20 14:07:08
MDG73
2022/06/20 12:59:41
Cancel077
MDG73
Cancel077
That's awesome! Your memory temp is better than mine! I think the mod is definitely a good one, I wish it exited on the stock hybrid cooler as is instead of us needing to mod it ourselves (I believe the 3090tis hybrid cooler already has a copper plate but I am not sure, I have just read about it). Interesting to note about the hose, are you talking about where the pump is? I know that for the FTW hybrid kit, you need to screw in the plastic piece to the shroud and it it will hold the bump/hose in place, but for the XC3 hybrid kit you do not have that.
I got this hybrid kit: P/N: 400-HY-1988-B1. Ahhh, just noticed the difference between the two. Yes, there are 2 screws that you have to screw into the shroud. I misspoke about that. The first time I mounted the hybrid and tried to play a game the screen went blank and the fans went to 100%. Took me a couple of minutes to figure out that there must be some kind of mounting issue as the hot spot was hitting 106 in no time. And of course when I took it apart again only half the GPU die was in contact with the cooler. Not sure how that happened but repasted with MX4 and it's all good now. Was scared for a bit with that mounting issue.
Oribento96
2022/10/18 22:03:24
Hey , is the EVGA Hybrid void the warranty of the Card? because it screw off the evga label on backplate to installing the AIO Thanks before
Cancel077
2022/10/21 21:59:50
Oribento96 Hey , is the EVGA Hybrid void the warranty of the Card? because it screw off the evga label on backplate to installing the AIO Thanks before
No it does not. Enjoy!
LaterTazor
2022/10/25 12:39:52
Guess this product is dead? cant get it anywhere, I seriously need one, the 3090 gets WARM under load
Cancel077
2022/10/30 11:12:17
LaterTazor Guess this product is dead? cant get it anywhere, I seriously need one, the 3090 gets WARM under load
I think it is. Quality of RMA items for the hybrid are also not that great at all, or not even looked at. Even if you manage to get one, I would avoid it. You would probably be better on getting a 3rd party hybrid kit or put a waterblock on it.
LaterTazor
2022/11/04 10:41:40
yeah tried the Alphacool one and that DID NOT go as planned bit of a shame tbh, but we live and learn
Cancel077
2022/11/04 12:26:30
LaterTazor yeah tried the Alphacool one and that DID NOT go as planned bit of a shame tbh, but we live and learn
What happened?
LaterTazor
2022/11/04 12:30:06
thought I killed my PC my stupid ass didn't connect the pump for my CPU AIO xD I will just get a 4090 in AIO pre built when the go down in price or just get more fans
