Hot!I have a second-hand Evga RTX 3070 xc3 graphics card and I need thermal pads for maintenance. I live in Turkey
CLSTR
2024/09/02 00:31:45 (permalink)
Hello, I have a second-hand Evga RTX 3070 xc3 graphics card and I need thermal pads for maintenance. I live in Turkey and where can I buy it?
[image]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAAngNWGAAABDUlEQVR4AYXRgUZDYRjH4TegFTKgpEqiFJgoWAoMEQGBgBboChaaAKxLKAhAhQqAdAmpBIQolkCFqp2nITvNKXuA7+/Hhzey5OWjE4Nq3rzY1f9/NGHPB549492+8Ww060iCS2XdctZdI3GsECmb+HJoIX6x6EgDm+lURTH+YB7V9nAqE5WNme4YKuOiY6iMe6PaQxUUIuTbswgFVNJwA8sO3Bn6yR6bWZMSNtJwDtuWfHpQxaPx9C9zadil7jrCigbq6UXceNIVKTWUIqypm2ytJdTiNyNeXclF6GttOVfeDEc7qzjR23r3OMFqZKng1kw0mXGLrfibHTScOZWgGv9TdC6ROFeMTgwYiIxvJzMRWQbeGZUAAAAASUVORK5CYII=[/image]
3 Replies Related Threads
    CLSTR
    Re: (ANSWER to) - What are the thermal pad sizes for my 30 series graphics card? 2024/09/02 00:39:37 (permalink)
    Bir sorunum daha var ürünümü siteniza kaydedemedim kartın arka yüzündeki seri numarasını giriyorum kabul etmiyor hata veriyor ne yapmalıyım.? Şimdiden teşekkürler
    Edit by Cool GTX
    Per Google translate:
    I have another problem, I couldn't save my product on your site. I enter the serial number on the back of the card and it doesn't accept it and gives an error. What should I do? Thanks in advance.
    post edited by Cool GTX - 2024/09/03 07:53:55
    CLSTR
    Re: (ANSWER to) - What are the thermal pad sizes for my 30 series graphics card? 2024/09/02 00:46:18 (permalink)
    There is another problem. I could not register my product on your site. I add the serial number on the back of the card. It is not accepted. It gives an error. What should I do? Thanks in advance
    I'm sorry, I sent it in Turkish by mistake. :=((
    • Ribbons : 123
    Re: (ANSWER to) - What are the thermal pad sizes for my 30 series graphics card? 2024/09/03 07:55:30 (permalink)
    CLSTR
    Contact EVGA Customer Service - Support@EVGA.com with the registered serial number
    Welcome to the EVGA Forums
