Cool GTXNo, you would void the warranty id you "open the sealed loop" about - 14.5” tubing on a CLC 280 .... you'll need slack & room for bends in the tubing 120 might work OK if your CPU does not se much action I'd recommend the 240 or larger - depending on CPU & expected load
Cool GTXhttps://www.newegg.ca/p/pl?N=100008007%2050001402 Amazon.ca non RGB EVGA CLC 120
