AnsweredHydro Copper Water Block for 2080 ti FTW3 Ultra
Mr.Gisoid
2020/05/26 12:51:56 (permalink)
Is this water block not being made anymore?
GTXJackBauer
  • Ribbons : 48
Re: Hydro Copper Water Block for 2080 ti FTW3 Ultra 2020/05/26 17:27:35 (permalink)
Mr.Gisoid
Hard to tell as things that looked EOL sometimes make a comeback or just reappear.  I'd look on Ebay for one if you're in desperate need of one or just look at EK and the likes for a full block.
LMD3DNZM9LGK8GJ
  • Ribbons : 270
Re: Hydro Copper Water Block for 2080 ti FTW3 Ultra 2020/05/26 19:19:17 (permalink) ☼ Best Answerby Mr.Gisoid 2020/05/31 18:11:11
These water blocks weren't very good.  It's impossible for me to know, but I suspect that they won't make a return.
I suggest that you take a look at EK's waterblocks.
https://www.ekwb.com/shop/ek-quantum-vector-ftw3-rtx-2080-ti-d-rgb-nickel-plexi
I recommend buying blocks with clear plexiglass tops so that you can see the microchannels inside and see that they aren't plugged up or corroding without having to periodically take the block apart just to see what you could have seen if you had purchased the version with the clear top.  Less maintenance.  Less worry.  Less taking the block apart for no reason and then risking having leaks or damaging o-rings which are hard to find.
Mr.Gisoid
Re: Hydro Copper Water Block for 2080 ti FTW3 Ultra 2020/05/27 10:17:19 (permalink)
Will do, thanks for the helpful advice.
