galvin
churchwin88
Re: How to turn off 1080 led lights
2016/07/01 20:43:46
I7 6700K @ 4.2(1.23v) Gigabyte Gaming 7 EVGA GTX 1070 SC G.Skill TridentZ Series 16GB @ 3000MHz Samsung 850 EVO 1TB SSD EVGA SuperNOVA 850 P2 Rosewill Gaming NIGHTHAWK 117
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
2016/07/01 21:05:46
Without clicking any reddit link, I am guessing you found the LED Visualizer, that is located in the driver since the 700 series at least, that also doesn't require GFE to be installed?
Did I get it right?
Oh, it also controls the LED SLI Bridges.
galvin
2016/07/01 21:37:51
Scarlet-Tech Without clicking any reddit link, I am guessing you found the LED Visualizer, that is located in the driver since the 700 series at least, that also doesn't require GFE to be installed?
Did I get it right?
Yes. it was posted 11 months ago.
RandyRick
2016/07/02 05:07:30
thx. reading the links on reddit led me to Intel QuickSync which I want to try.
the_Scarlet_one
- Ribbons : 79
2016/07/02 08:16:30
galvin Yes. it was posted 11 months ago.
We've been telling people to use LED Visualizer since September/October 2014 when the first led sli bridges came out. It's a great alternative to having bloatware since I comes installed in the driver.
galvin
2016/07/02 16:19:29
Wish nvidia would just offer it stand alone instead of trying to make everyone use their bloatware. Glad I found out how to do this.
the_Scarlet_one
- Ribbons : 79
galvin
2016/07/03 09:57:00
Ok didn't know you could copy them out of the drivers before installing. I had it installed already and just copied from the installed location instead.
chrisdglong
- Ribbons : 7
2016/07/04 13:01:51
Thanks everyone, I have a color theme and green was not supposed to be a part of it.
- Ribbons : 115
2016/09/08 23:11:50
Use Precision X OC, or Geforce Experience to turn off the lights.
capilot22
Re: How to turn off 1080 led lights FROM "the_Scarlet_One"
2018/05/12 00:17:37
To the post from "the_Scarlet_One", dated July 2, 2016. Hi, WOW, THANK YOU for including the images, they really helped, because the CURRENT May 2018 drivers DO NOT include the LED Visualization. Although I have the 397.64-desktip-win 10-64bit-international-whql.exe drivers installed (Driver Date 5/7/2018, Driver Version 24.21.13.9764), I HAD to go back to the folder Local Disk (C:) > NVIDIA > DisplayDriver > 368.81 to find the LED Visualizer. NONE of the drivers since then, that I have, including 376.19, 388.13, 388.43, 390.77 or the newest - 397.31 have it!!! Your IMAGES really helped, even thought I don't have the 368.39, as you have shown in the location bar, I realized I HAD to find something in the driver group of 368.XX or earlier to find the LED Visualizer. Again I really appreciate it. I have 2 ASUS ROG GeForce GTX 1080 cards that do have LED light choices, which I like to set to the card temp. I had 2 EVGA GeForce GTX 1080 FTW2 cards with ACX, where the EVGA Precision OC WOULD let me click on the LED tab and choose what colors and settings I wanted. That was a really GREAT feature, but I just did an EVGA "Step-Up" to on one of the two FTW (For the Win - I asked EVGA what that stood for), to the EVGA GeForce 1080 Ti SC. Even with finding the LED Visualizer, UNFORTUNATELY on a $900.00 graphics card, it ONLY DISPLAYS WHITE. At least with the LED Visualizer that YOU pointed out the location of, I am able to adjust the BRIGHTNESS, TURN IT OFF, or set "patterns" of animations to the WHITE LED. Don't know why on a more expensive GPU from EVGA, they take away the RGB (Red, Green, Blue), and leave you with ONLY WHITE. I USED to LOVE the pulsing settings I had in BLUE on the EVGA 1080 FTW2 GPU. I have seen posts here and elsewhere that say the EVGA 1080 Ti SC comes ONLY in White or Green LED, I wish mine was the Green. The white is a bit too bland, and BEFORE I found the LED Visualizer that YOU pointed out the location of and the driver group of, I was NOT able to DIM the VERY BRIGHT WHITE LED on it. THANK YOU, THANK YOU, THANK YOU!!!
post edited by capilot22 - 2018/05/12 00:24:40
- Ribbons : 135
2018/05/12 01:54:50
capilot22 To the post from "the_Scarlet_One", dated July 2, 2016. Hi, WOW, THANK YOU for including the images, they really helped, because the CURRENT May 2018 drivers DO NOT include the LED Visualization. Although I have the 397.64-desktip-win 10-64bit-international-whql.exe drivers installed (Driver Date 5/7/2018, Driver Version 24.21.13.9764), I HAD to go back to the folder Local Disk (C:) > NVIDIA > DisplayDriver > 368.81 to find the LED Visualizer. NONE of the drivers since then, that I have, including 376.19, 388.13, 388.43, 390.77 or the newest - 397.31 have it!!! Your IMAGES really helped, even thought I don't have the 368.39, as you have shown in the location bar, I realized I HAD to find something in the driver group of 368.XX or earlier to find the LED Visualizer. Again I really appreciate it. I have 2 ASUS ROG GeForce GTX 1080 cards that do have LED light choices, which I like to set to the card temp. I had 2 EVGA GeForce GTX 1080 FTW2 cards with ACX, where the EVGA Precision OC WOULD let me click on the LED tab and choose what colors and settings I wanted. That was a really GREAT feature, but I just did an EVGA "Step-Up" to on one of the two FTW (For the Win - I asked EVGA what that stood for), to the EVGA GeForce 1080 Ti SC. Even with finding the LED Visualizer, UNFORTUNATELY on a $900.00 graphics card, it ONLY DISPLAYS WHITE. At least with the LED Visualizer that YOU pointed out the location of, I am able to adjust the BRIGHTNESS, TURN IT OFF, or set "patterns" of animations to the WHITE LED. Don't know why on a more expensive GPU from EVGA, they take away the RGB (Red, Green, Blue), and leave you with ONLY WHITE. I USED to LOVE the pulsing settings I had in BLUE on the EVGA 1080 FTW2 GPU. I have seen posts here and elsewhere that say the EVGA 1080 Ti SC comes ONLY in White or Green LED, I wish mine was the Green. The white is a bit too bland, and BEFORE I found the LED Visualizer that YOU pointed out the location of and the driver group of, I was NOT able to DIM the VERY BRIGHT WHITE LED on it. THANK YOU, THANK YOU, THANK YOU!!!
Here's the better method direct download to the LED visualizer app from Nvidia. http://international.down...isualizer_v1.1.0.0.exehttp://nvidia.custhelp.co...geforce-experience-3.0
post edited by HeavyHemi - 2018/05/13 10:43:18
2018/05/12 11:40:05
BrandonS
- Ribbons : 5
2018/05/15 06:40:24
@capilot22, Welcome to the forums! You have to remember that this post is almost 2 years old, so the information may not always be accurate. About a year ago NVIDIA made the decision to remove it from the driver and offer it as a standalone program, as HeavyHemi posted.
