Hot!How to obtain modular power supply cables?
Dezmo
Saturday, January 25, 2025 2:40 PM (permalink)
I have a system from an SI. It came with an EVGA 1000 GT. I don't have all the cables. I need an extra 6-pin cable to power one of the Corsair iCue link AIO and fan sets. Is there a way I can just order a compatible cable set for it?
Thanks in advance for any help.
2 Replies Related Threads
    MSim
    • Ribbons : 38
    Re: How to obtain modular power supply cables? Thursday, January 30, 2025 11:21 PM (permalink)
    You could try contacting support see if they have any you could buy. Another option is to buy one from a site that makes custom PSU cables.
    https://store.cablemod.com/configurator/  one of many sites that make custom PSU cables. Shop around to find best deal.
    • Ribbons : 123
    Re: How to obtain modular power supply cables? Friday, January 31, 2025 0:36 PM (permalink)
    Please contact EVGA at Support@EVGA.com with the registered serial number of your PSU for assistance.
