How to enable Speed Shift for Skylake X Processors
deanjwprime
2020/07/04 09:48:26 (permalink)
Mobo X299 Micro, Is speed shift support on the X299 Mobo?
Antec 601 ARGB Case
EVGA X299 Micro 1.24
EVGA RTX 2070 FTW3
32GB DDR4 2666 G.Skill RipJaws 16-16-16-36
Intel i9-9820X Skylake Processor
EVGA CLC 280 Liquid Cooler
M.2 SSD 1TB Gammix Pro S11
EVGA 750 SuperNova GA PS
RazerChroma keyboard, RazerDeathAdder Mouse
Win10 Pro 64Bit 2004
2 Replies Related Threads
    deanjwprime
    Re: How to enable Speed Shift for Skylake X Processors 2020/07/04 10:05:03 (permalink)
    Here is a description, if any one is wondering what SST is?
    "Intel Speed Shift technology also known as HWP (Hardware p-state) or Hardware Controlled Performance delivers quicker responsiveness with short duration performance shifts, by allowing the processor to more quickly select its best operating frequency and voltage for optimal performance and power efficiency. For performance, efficiency and power consumption reasons, modern processors are constantly changing clock frequency and voltage based on the workload."
    Antec 601 ARGB Case
    EVGA RTX 2070 FTW3
    bob16314
    • Ribbons : 582
    Re: How to enable Speed Shift for Skylake X Processors 2020/07/04 11:52:03 (permalink)
    Checking To See If Intel Speed Shift Is Enabled
    "One way to confirm whether Intel Speed Shift is enabled is to use the free HWiNFO64 utility. On the main HWiNFO screen, in the CPU section, there is a Features section that shows various AMD and Intel processor features. They will be green if that feature is enabled on your system, and greyed out if it is not."
    Hope that helps some.
    * Corsair Obsidian 450D Mid-Tower - Airflow Edition * ASUS ROG Maximus X Hero (Wi-Fi AC) * Intel i7-8700K (Delidded, TG Conductonaut) @ 5.2GHz* 16GB G.SKILL Trident Z 4133MHz * Crucial MX500 M.2 1TB * WD Black 500GB (x2) * Seasonic M12 II 750W * Corsair H115i Pro * EVGA GTX 760 SC * Dual-Boot Win7 Home 64-bit/Win10 Home 64-bit (Winver 1909) *
