Hi I wanted to see if anyone has had issues with the EVGA GeForce 2080Ti Black Edition, even after a replacement the card has failed with GPU-Z not reporting any memory present on the card and it will only display in a low resolution?
Did all the software first, display driver uninstaller, reinstalled windows, flashed bios even built another PC to test and confirmed hardware fault. RMA second card lasted a day and same issue with GPU-Z reporting no memory see screenshots. Took all parts out and cleaned motherboard, reinstalled and fitted a brand new PSU using two separate PCI power cables, different monitor, different cables. 3rd card installed and instant fail, stuck on low resolution and no memory detected by GPU-z.
Any ideas/suggestions? There are videos with multiple card failures but 3 in a row? what can even cause that? Its been over two months now and im just lost... any thoughts, constructive help would be massively appreciated..
ASUS X299 Strixx MB, Intel Core i9-9900x, GSkill Trident mem, ASUS ROG 850W PSU, AGON 35" ultrawide monitor,
