Re: HELP: RTX 3090 Ti FTW3 Red Light On. No RGB, Fans are Spinning
2024/07/25 18:10:10
If you swap power cables around to make sure you don't have a bad cable, check that the card is properly seated in the PCI-E slot, and aren't using a riser cable, odds are she's dead. RMA or e-waste.
