cortina69
Didn't have this issue on my previous motherboard. My gpu coil whine seems to be coming through my speakers which are connected to the rear audio jack on my X570 Dark board. Using exactly the same cables and audio system as well as the same gpu. How do I fix this as it's super annoying and never had this problem before on any other motherboard.
Thanks in advance
Jomama22
- Ribbons : 19
Re: Gpu coil whine coming through speakers rear audio jack
2022/04/21 04:35:06
The sound you hear is probably emi. You can buy some cheap ferrite beads for the 6/8 pin pcie cables which should help a bit, if you think it's coming from the gpu.
You can try moving the power cable used for the speakers to a different plug in the room as well.
cortina69
2022/04/22 16:16:34
Jomama22 The sound you hear is probably emi. You can buy some cheap ferrite beads for the 6/8 pin pcie cables which should help a bit, if you think it's coming from the gpu.
Yeah it's a really odd problem I've never experienced before. It changes with the tone of the gpu and when it's under load in a game it comes through the speakers, even moving my mouse changes it, it also sometimes chirps as well. All hardware is the same apart from motherboard and cpu, how does changing a mobo affect this sort of thing. This is my 5th motherboard and pc I've built and first time I've come accross it. Same power supply, same gpu, same speakers etc. The power supply and speakers are on different wall sockets to try eliminate this but hasn't helped. What are ferrite beads, never heard of them before and where would i get them? I'm located in Australia. I think the sound is coming from the gpu as it's consistent when it's under heavy load but weird I've noticed moving the mouse and typing on my keyboard affects it as well.
Jomama22
- Ribbons : 19
2022/04/22 17:54:02
cortina69
You can google ferrite beads, they are pisces of ferrite that fit around cables to create an impedence to prevent EMI from leaking out from a power source (the very short of it). Mouse movements alone will cause the VRMs on the motherboard to active/deactivate because of the load requested by the CPU. If you haven't changed any VRM settings in bios, by default, this is how they will behave. This in and of itself can cause EMI and create the interference you are experiencing. There is also a setting called 'spread spectrum' for VRMs that should be enabled by default as well. This will reduce EMI emissions by varying the switching frequency of the VRM itself. Mouse movements will also cause the GPU VRMs to change their state as well. The isn't all that much you can do besides isolating the speakers as best you can from the EMI source. The ferrite beads my help but it's not likely to resolve the issue completely.
cortina69
2022/04/22 18:02:34
Jomama22
cortina69
I'll have a look for those ferrite pieces. Cpu is overclocked. Spread spectrum, I'll dig through the bios to see if I can find it. I'm still getting my head around Evgas bios (first time Evga and Ryzen user). Didn't know the mouse can be a culprit too that's handy to know cheers. I'll move my speakers and amp further away from the mobo if I can. It's currently set up with the test bench stand it came with until I get the rest of the watercooling gear to put it in it's case so also wondering maybe as the i/o isn't touching a case that's possibly doing it too. I'm still learning alot about the ins and outs of pc's etc
Jomama22
- Ribbons : 19
2022/04/22 18:10:48
cortina69
Jomama22
cortina69
Can you test using headphone out of the amp? Wouldn't be surprised if they work better. Some speakers just have super sensitive inputs (usually rca Jack's especially) and the auto cable acts like an antenna, just grabbing tons of interference is it's around.
cortina69
2022/04/22 19:23:31
Jomama22
cortina69
Jomama22
cortina69
I didn't think of trying headphones. Will try them next time I'm on the pc
_Gir_
2022/04/22 20:01:02
Is the noise connected to frame rate or some other source e.g. moving the mouse? I wonder what EVGA set the default setting for spread spectrum. I don't recall seeing it on the BIOS settings. I've heard of using different cables or ports for power, display etc have helped some folks.
cortina69
2022/04/22 20:01:58
Just got home and tried my headphones and isn't present with my headphones, only with speakers. My amplifier is a DaytonAudio APA150 connected to the rear panel green jack with a stereo rca to 3.5mm cable.
cortina69
2022/04/22 20:05:52
No idea just depends how under load my titan rtx is under in different games and could be related to the frame rate but unsure but mouse does effect it with speakers only not headphones
I've never seen the setting in the bios of my X570 Dark, wonder if it's under cpu configuration or something perhaps
I do have a new stereo rca to 3.5mm cable on the way. I have two separate power boards and have been switching plugs around to see if anything helps but no luck yet. I've got psu separated from the rest of the stuff. Psu is an Evga Supernova 1600 P2, i have a 1000 G5 and 2000G+ on hand as well
cortina69
2022/04/22 20:07:58
Other things that are connected are my Dayton Audio amplifier, Audioengine S8 subwoofer and my Msi Creator PS321QR monitor
_Gir_
2022/04/23 07:16:24
Is your screen, PC, and audio gear on the same power strip? If not, try doing so. Might fix a ground loop of sorts by having connected equipment share the same/common ground. Next would try another mouse or USB port, then after would be to isolate source eg unplugging the screen video cable, check for noise, unplug sub, check for noise etc. After that it's probably addressing VRM speeds or messing with BLCK. What’s your setup and other peripherals?
post edited by _Gir_ - 2022/04/23 14:08:43
cortina69
2022/04/23 17:43:16
Pc is separate from the rest of the gear as I thought ground loop is somewhere but will put it all on the same and see what happens. I'll try all that and see if usb ports make a difference. I'll switch some cables around i have spare display port etc
Not sure about vrm and bclk don't know much about adjusting those.
Setup is 5950x, 32gb g.skill ripjaws, Nvidia rtx titan shunted, keyboard is currently a Logitech g915 wireless and mouse is Logitech g502 lightspeed. Running an ek d5 pump res combo, two 360 rads, fans are Noctua Industrial nf f12 3000rpm on the radiators. Just waiting on the new watercooling gear than will put in my Thermaltake Level 20 XT case. New cpu block should arrive next week.
cortina69
2022/04/26 19:21:17
So it's definitely linked to frame rate as it drastically changes with it. Also left side is louder than the right side despite volume for both sides is identical so this shouldn't be an issue. Definitely something wrong with the audio because of these issues. Yet it's only speakers effected not headphones but i know my audio equipment is fine because it works on my other motherboard no problem. Honestly it's not worth rma but still this shouldn't even be happening. Will try a pci sound card to see if it works properly that way with zero issues. Pretty diasapointing for over $1100 for a high end motherboard to be honest but will see how the sound card goes in a months time when I get it, shouldn't have to spend more and go this route but have no choice since I've tried everything else to no avail, other than this it's a great board despite other minor issues not worth mentioning as they're more of an inconvenience than anything else
_Gir_
2022/04/27 14:36:33
My setup is almost the same: 5950x, 32 GSKILL, D5, 2 360s rads, Logitech G910 and 502 LS, EVGA 1600 T2 PSU I'll see if I can MacGyver a connection to my receiver/speaker setup from the next room over and see if mine does same, may not be until weekend- ?'s What display and what audio port are you using? Can you SPDIF it? All PSU connections (w/OEM PSU cables) to MB filled including PCIE at the bottom left?
post edited by _Gir_ - 2022/04/27 14:39:48
Jomama22
- Ribbons : 19
2022/04/27 15:23:52
cortina69 So it's definitely linked to frame rate as it drastically changes with it. Also left side is louder than the right side despite volume for both sides is identical so this shouldn't be an issue. Definitely something wrong with the audio because of these issues. Yet it's only speakers effected not headphones but i know my audio equipment is fine because it works on my other motherboard no problem. Honestly it's not worth rma but still this shouldn't even be happening. Will try a pci sound card to see if it works properly that way with zero issues. Pretty diasapointing for over $1100 for a high end motherboard to be honest but will see how the sound card goes in a months time when I get it, shouldn't have to spend more and go this route but have no choice since I've tried everything else to no avail, other than this it's a great board despite other minor issues not worth mentioning as they're more of an inconvenience than anything else
TBF, I wouldn't consider any on board audio to be worth much in terms of quality or isolation. You could honestly buy even a decade old used sound card and get much better quality out of it (a creative x-fi titanium hd comes to mind). Though, tbh, if it is only the speakers where the sound is an issue, I wouldn't be putting it on the motherboard.
cortina69
2022/04/27 17:19:46
_Gir_ My setup is almost the same: 5950x, 32 GSKILL, D5, 2 360s rads, Logitech G910 and 502 LS, EVGA 1600 T2 PSU I'll see if I can MacGyver a connection to my receiver/speaker setup from the next room over and see if mine does same, may not be until weekend- ?'s What display and what audio port are you using? Can you SPDIF it? All PSU connections (w/OEM PSU cables) to MB filled including PCIE at the bottom left?
Display is msi ps321qr via display port, audio port I'm using is the green stereo line out with 3.5mm to stereo rca to my amp as my amp only takes rca. All oem cables yes. I switched all cables around and power boards but no luck. Can't do any further changes as my system has refused to post aince yesterday
cortina69
2022/04/27 17:21:51
Jomama22
My setup is exactly the same as it was before with my old motherboard and never had this issue so i do lean to the motherboard
- Ribbons : 135
2022/04/27 23:23:49
The only way I've found to get that advertised ~ -90db SNR is to use outboard USB. X99 FTW K, does it to varying degrees no matter what sound card I put in or using the onboard. There's always some sort of whine or buzz depending upon what you're doing. Not loud, just annoying enough that you wouldn't use the PC for enjoying high fidelity audio. Currently using the ASUS Centurion 7.1 headset. It's dead silent. If I install the Asus Phoebus, I have a buzz/whine varying with load. Same with a half dozen other sound cards I've tried. Some worse than others. I've a 3080Ti in here now pulling ~450 watts and just as quiet as with the 1080 Ti.
