Re: Gefore RTX 2080 super led problem
Tuesday, March 31, 2020 8:39 PM
if it did then how you would control them is to open precisions X1 and where is say precisions X1 on that program to the right of that is where you will see VGA1, LED and HWM from here its pretty obvious that you need to click LED and that will allow you to control the LEDs of the GPU. LED sync is to sync all EVGA products that have LEDs in them with the control from precisions X1.
a good teacher will not give you the answer you seek, they will help you learn as to why you had that problem and will guide you to the solution that works for it so you can pass the knowledge on.
Associate Code: RJVGCE38ZNYRH45
Rewards Program Code is: ISWBJCPO8X
