Geforce GTX 960 SSC Power Cables and Trouble
Mantha065
2017/06/20 10:13:45 (permalink)
There's a post from 2015 similar to this one but it didn't provide me much help.
Here's the situation: I bought this card (GTX 960 SSC) off of a secondhand merchant on Amazon and they gave me just that- ONLY the card, in its anti-static sleeve. I thought that was all I needed, but when me and my friend tried to put it into my computer, we found that the only 8-pin power cable extending from my Power Supply Unit doesn't match up with the GTX 960, the pattern of holes on it are different than that of on the GTX 960.
To describe the pattern of the holes, it goes like this: (the Geforce GTX 960 words are facing upright)
square-rounded-rounded-rounded
rounded-rounded-square-square
I have yet to find any kind of PCIE cable that might fit that. I don't know if the GTX 960 is supposed to have its own unique cable, or if I did something wrong with the 8-pin from my PSU and that one is actually all I need, or what.
I've had this graphics card collecting dust for a couple months because it seems like nobody knows how to fix this. For the love of all things good, please someone end this XD
My computer is a Cybertron Borg-Q  with an MSI AM3 V X16 2D3 M16 GL R MATX motherboard and an LSP 550W ATX power supply.
---I KNOW MY POWER SUPPLY ISN'T VERY GOOD BUT PLEASE DON'T TELL ME TO REPLACE IT, I am not really interested in replacing it because, after all of this GPU stuff, I'm not in the mood for even more of a hassle with computer stuff---
Thanks in advance.
5 Replies Related Threads
    • Ribbons : 282
    Re: Geforce GTX 960 SSC Power Cables and Trouble 2017/06/20 10:15:54 (permalink)
    Welcome to the Forum Mantha065
    You have Two 6-Pin for the PCIe Graphics PCI Express Cables
    For 8-Pin adaptor you need Two 6-Pin to create One 8-Pin
    Dual 6-Pin Female to 8-Pin Male Cable Black
    You may also need a few Computer Molex 4 Pin Power Supply Y Splitter Cable
    post edited by bcavnaugh - 2017/06/20 19:22:34
    • Ribbons : 123
    Re: Geforce GTX 960 SSC Power Cables and Trouble 2017/06/20 10:35:35 (permalink)
    +1
    Sound like a CPU 8-pin - from your PSU
    You need a PCIe - GPU 8-pin (6+2) OR the adapter wire - though most will not use these.
    Your PSU must have enough amperage on the +12V to power the GPU - most would only use the adapter for testing in a pinch
    As you can see below, the adapter requires Two 6-pin PCIe connectors on your PSU
    quadlatte
    • Ribbons : 56
    Re: Geforce GTX 960 SSC Power Cables and Trouble 2017/06/20 18:47:30 (permalink)
    that psu only has two 6 pin pcie connectors and a 8 pin eps connector. you will need adapters as posted above. you will just make the threshold of amps to run that card.
    here is a reference for future use.
                                                 Heatware: http://heatware.com/eval.php?id=72498
    • Ribbons : 282
    Re: Geforce GTX 960 SSC Power Cables and Trouble 2017/06/20 19:05:50 (permalink)
    post edited by bcavnaugh - 2017/06/20 19:20:52
    MetalSaint
    Re: Geforce GTX 960 SSC Power Cables and Trouble 2017/07/01 10:53:11 (permalink)
    I have an issue where if I plug a second monitor using DVI-to-HDMI CPU usage spikes begins and PC becomes laggy..
