GeForce RTX 3090 Ti graphics cards are bundled with 3×8-pin to PCIe Gen5 (16-pin) power
  • Ribbons : 86
2022/03/24 10:18:52 (permalink)
https://videocardz.com/newz/geforce-rtx-3090-ti-graphics-cards-are-bundled-with-3x8-pin-to-pcie-gen5-16-pin-power-adapters
According to the leaks, the NVIDIA GeForce RTX 3090 Ti has a TDP of 450W. With such a high power input, even two 8-pin PCIe power are not sufficient, such configuration can only sustain 300W of power. This is a major difference between the RTX 3090 and RTX 3090 Ti cards. The Founders Edition of the former flagship SKU released in 2020 features a 12-pin connector (basically the same cable but without the ‘sense’ pins). It shipped with dual 8-pin to 12-pin power adapter. This is obviously enough for the 350W TDP because the card still has access to 75W of power through the PCIe interface.
The RTX 3090 Ti with 100W higher TDP will need three 8-pin power cables or a native implementation of the 12VHPWR (12+4 or 16-pin) PCIe Gen5. However, the power supplies with the native cable will not be available in time for RTX 3090 Ti, which launches on March 29th. For this reason, the adapter is required. The adapter will provide 450W of power alone and a total of 525W with the PCIe interface. One should expect a number of custom RTX 3090 TI designs to reach 500W of maximum TDP.
The RTX 3090 Ti features a GA102-350 GPU with all 10752 CUDA cores enabled. This is NVIDIA’s first RTX model with 21 Gbps GDDR6X memory and new power connector. The RTX 3090 Ti should be the last flagship Ampere SKUs to launch before NVIDIA unleashes its Ada GPUs later this year.
That is a lot of power. I think a beefy PSU will also be needed.
13 Replies Related Threads
    Michapolys
    Re: GeForce RTX 3090 Ti graphics cards are bundled with 3×8-pin to PCIe Gen5 (16-pin) powe 2022/03/24 11:24:08 (permalink)
    Here come the burned wires...
    Re: GeForce RTX 3090 Ti graphics cards are bundled with 3×8-pin to PCIe Gen5 (16-pin) powe 2022/03/24 11:25:41 (permalink)
    Three 8-pins can do 600+ watts. I've already done so with a 3090 kingpin. This adapter will allow over 525w since it connects to three 8-pins.
    rzelek506
    Re: GeForce RTX 3090 Ti graphics cards are bundled with 3×8-pin to PCIe Gen5 (16-pin) powe 2022/03/25 00:21:29 (permalink)
    Isn't the Kingpin supposed to have two of the PCIe gen5 power connectors, so then it'll need two of these adapters?
    That'll mean it can take up to six of the 8-pin power cables..  lmao
    Miguell
    Re: GeForce RTX 3090 Ti graphics cards are bundled with 3×8-pin to PCIe Gen5 (16-pin) powe 2022/03/25 02:57:20 (permalink)
    Gonna admit all these new W specs and new  psu connectors are confusing me!
    can already see psus with tons of cables!
    all i know is energy demand is increasing for gfx cards and its ridiculous! electricity is super expensive!
    Case: Cooler Master Stacker 830
    Display: 32" AOC Q3279VWFD8 @2560x1440@75Hz
    Cpu: Intel Core i7-8700
    Cpu Cooler: Cooler Master - MasterLiquid ML120L - RGB
    Mobo: Asus ROG Strix Z390-H Gaming
    Vga: Asus Dual RTX 4060 Ti 16GB Advanced Edition
    Ram: 32GB DDR4  G.SKILL - RIPJAWS V @3200Mhz
    Sound: Hama uRage soundZbar 2.1 Unleashed  - (Optical)
    Storage: 500GB SSD M.2 A2000  NVMe  Kingston (OS) + 8TB (4+4) HDD X300 Toshiba (Data)
    Psu: SeaSonic M12 700W
    Os: W10 Pro 64Bit
    firerain
    Re: GeForce RTX 3090 Ti graphics cards are bundled with 3×8-pin to PCIe Gen5 (16-pin) powe 2022/03/25 04:36:06 (permalink)
    Miguell
    Just by an electric car! That will solve all your problems.
    Pc0 Legion pre built / 3090Fe / 10900k
    Pc1 8700k /2x EVGA 3080 TI / EVGA Z375 micro
    Pc2 EVGA x99 micro / E5 2678 v3 / 3080 / EVGA 3060, EVGA 1660 ti
    Pc3 EVGA x99 micro / E5 2620 v3 / EVGA 3080, 1650
    Pc4 HP pre built AMD R5 3500 / 2060 ko
    Nereus
    Captain Goodvibes
    • Ribbons : 58
    Re: GeForce RTX 3090 Ti graphics cards are bundled with 3×8-pin to PCIe Gen5 (16-pin) powe 2022/03/25 05:33:57 (permalink)
    firerain
    Miguell
    On the plus side, lithium stocks have been fun.
      BUILD 1 2   |   MINI-ITX BUILD   |   MODSRIGS $1K WIN   |   HEATWARE 111-0-0
    Miguell
    Re: GeForce RTX 3090 Ti graphics cards are bundled with 3×8-pin to PCIe Gen5 (16-pin) powe 2022/03/25 07:09:07 (permalink)
    firerain
    Miguell
    why on earth would an eletric car solve my problems? i have Diesel and it will be for as long as i can.
    what has an eletric car TO DO  to do with this  3090Ti  PSU  topic?
    Os: W10 Pro 64Bit
    Nereus
    Captain Goodvibes
    • Ribbons : 58
    Re: GeForce RTX 3090 Ti graphics cards are bundled with 3×8-pin to PCIe Gen5 (16-pin) powe 2022/03/25 07:13:41 (permalink)
    Miguell
    firerain
    Miguell
    I believe it was sarcasm.
    the_Scarlet_one
    formerly Scarlet-tech
    • Ribbons : 79
    Re: GeForce RTX 3090 Ti graphics cards are bundled with 3×8-pin to PCIe Gen5 (16-pin) powe 2022/03/25 08:48:46 (permalink)
    Vince “K|ngp|n Lucido has pulled near 1000w from three 8 pin connectors without the world burning to the ground. These “specs” are just silly at this point.
    I am betting if the adapters are torn down, most of the cables dead end and don’t connect to anything.
    Buying dual 8 pin to 12 pin adapter for the 3070-3090 founders had the sense cables missing from the connector, so it was just two 6 pin cables with two dead end cables next to them.
    Buying a 3070 founders used only a single 8 pin adapter to 12 pin, and only 6 cables were used to the 12 pin, with 6 dead end cables next to them and no pins in the adapter.
    The spec is just to push a better terminal on the GPU, and the wattage is just a safety catch all for when someone burns their house down.
    Nereus
    Captain Goodvibes
    • Ribbons : 58
    Re: GeForce RTX 3090 Ti graphics cards are bundled with 3×8-pin to PCIe Gen5 (16-pin) powe 2022/03/25 09:11:28 (permalink)
    the_Scarlet_one
    It's a little like the 3090 FTW3 Ultra is rated at 1800MHz boost and nothing above that is guaranteed, but it's not unusual to run them at 2200MHz overclock without issue. Same goes for cables; rated at 150W, but you can probably pump a lot more juice through them, just no guarantees. NVidia likely have certain safety tolerances that have been set after discussion between their techs and their lawyers, and they will always err on the side of caution.
    Miguell
    Re: GeForce RTX 3090 Ti graphics cards are bundled with 3×8-pin to PCIe Gen5 (16-pin) powe 2022/03/25 10:23:10 (permalink)
    austin86
    Miguell
    Its a joke. A lot of elite type folks are putting out statements to buy a electric cars if they can't afforded to pay for power/gas and other things.
    yeah... did not find it funny..   i didn't get it actually 1! :D
    here in Portugal there are already creating monthly electric plans (or fees if you will )  just for the purpose of charging cars.. so....
    here electricity is very expensive! i have no clue how much it costs more per month with a regular charging of an electrical car..
    and the gods forbid me if i know how much it will be with these new wattage gpu specs.. cause i run my pc all day long!!
    and sure thing electricity wont be cheaper in the future!
    i feel its all a  trap we are getting into.. electric cars..  more electronics and same time more power hungry electronics... the future is electrical sure.. and costly!
    Os: W10 Pro 64Bit
    firerain
    Re: GeForce RTX 3090 Ti graphics cards are bundled with 3×8-pin to PCIe Gen5 (16-pin) powe 2022/03/25 11:56:49 (permalink)
    Miguell
    austin86
    Miguell
    I always forget this is multi national forum. We have a huge inflation problem here in the USA and with sanctions and other stuff ,our gas which is less expensive then lots of places has gone up. Making people mad, and also further trickling down and increasing prices on other goods. The fatcats in control laugh at the peasants and tell them to buy electric cars. Which is just more salt on the wound.
    Your accurate statement about energy prices  triggered a cognitive connection in the brain that led to some unpleasant thoughts that where turned into sarcasm. Hence my post.
    Michapolys
    Re: GeForce RTX 3090 Ti graphics cards are bundled with 3×8-pin to PCIe Gen5 (16-pin) powe 2022/03/25 12:41:31 (permalink)
    the_Scarlet_one
    The thing is, results can vary greatly depending on the PSU PCI-E cables and terminals. Some can do about 12-13 amps per wire, some can "only" do 8-9 amps. Some have one connector per cable, some have two.
    Two 8-pin connectors on the same cable were not within spec last time I checked the PCI-E documentation either. It was either one connector per cable, or two connectors per cable with only one of them being an 8-pin max (so you had one 6-pin plus one 8-pin, or two 6-pin connectors per cable, but not two 8-pin ones).
    Add to that the wear and tear (loose female terminals, oxidation, etc,) and current capabilities drop even more. You end up with a 20-25% reduction in current capabilities after a few years.
    It is a bit messy as it is. The new connector can make things better, in theory at least.
