Re: GTX1080 FTW Hybrid Instability after I Swap Stock fan to Noctua Chromax f-12 need help
2018/06/14 09:38:36
Might be air bubble now at the pump from you moving the rad yo install the different fan.
Tip the pc case so any air that may be trapped at the GPU can now move up to the rad where any air should be.
That's all I can think of for the temp being higher now.
Asus Z390 ROG Extreme XI MB
