GTX 1080 Hybrid - correct power cables
Eagle Lake Wood
2019/02/01 14:51:32 (permalink)
I bought a EVGA GTX 1080 from a friend and I'm trying to nail down the correct power cables for it. I bought a pair of cables from ebay that I thought would fit and they do not.
PSU is made by Ultra, model HS-650BR and it has two 8 pin power connectors labeled "PCI-E Connector" on it (Pic attached), and the cables I bought are labeled EVGA VGA G3 (also Pic attached). There's an 8 pin on one end and a 6 +2 on the other, and both of these plug into the graphics card nicely.
The problem is on the other end at the PSU. Neither end wants to fit there. Is my PSU obscure and non-standard?
What type of cable is correct? Is there any way I can modify the ones I have to work?
11 Replies Related Threads
    • Ribbons : 282
    Re: GTX 1080 Hybrid - correct power cables 2019/02/01 15:06:05 (permalink)
    One available 8-pin PCIe power dongle
    https://www.evga.com/Products/Specs/GPU.aspx?pn=2C922FA8-32A8-4393-BE2E-7744C544DBAA
    "I bought a pair of cables from ebay that I thought would fit and they do not.:" You cannot do this and can Short or Fry You Graphics Card
    You can only use the PCIe Power Cables that Came With You Power Supply. DO NOT MIX CABLES.
    Your Power Supply has the correct connector.
    You use the  6+2pin PCI-Express Connector to make one 8-Pin Connector
    Type: ATX 12V v2.3 & EPS 12V v2.91
    • Maximum Power: 650W
    • Fan: 1x 120mm Nano Ball Bearing Cooling Fan
    • Connectors: 1x 20+4pin Main Connector, 1x 4+4pin CPU Connector, 2x 6+2pin PCI-Express Connectors, 6x SATA Connectors, 6x 4pin Peripheral Connectors, 1x Floppy Connector
    • 80 PLUS Bronze certified
    post edited by bcavnaugh - 2019/02/01 15:16:48
    bill1024
    • Ribbons : 65
    Re: GTX 1080 Hybrid - correct power cables 2019/02/01 15:18:08 (permalink)
    If the PSU you already have have 2 PCIE wires, those are the ones you plug into the EVGA GPU
    Or if it does not have PCI-e cable, you have to buy cables made for your brand of PSU
    May want to consider getting an EVGA  or a seasonic gold 650-850 PSU
    Do not cheap out on a PSU
    I did not find a  Ultra, model HS-650BR  on ebay, you can try the manufactures site and get a cable.
    Eagle Lake Wood
    Re: GTX 1080 Hybrid - correct power cables 2019/02/01 15:18:12 (permalink)
    • Ribbons : 282
    Re: GTX 1080 Hybrid - correct power cables 2019/02/01 15:21:59 (permalink)
    The Blow Cables are NOT From your Power Supply DO NOT USE THEM.
     They are ONLY for use on an EVGA Power Supply.
    If you do not have the Cables that came with your Power Supply then you will need to Buy a New Power Supply.
    You must replace All your Old Power Supply Cables and replace them with the Cables that Come with the New Power Supply.
    post edited by bcavnaugh - 2019/02/01 15:26:16
    Eagle Lake Wood
    Re: GTX 1080 Hybrid - correct power cables 2019/02/01 15:27:57 (permalink)
    Here's the PSU -
    lso uploaded a Pic of the connector on the PSU. Is the female PCIE connector on my PSU non-standard? Do manufacturers take liberty with making their own connector on the PSU side?
    post edited by Eagle Lake Wood - 2019/02/01 15:39:25
    • Ribbons : 282
    Re: GTX 1080 Hybrid - correct power cables 2019/02/01 15:29:10 (permalink)
    Eagle Lake Wood
    Here's the PSU -
    also uploaded a Pic of the connector on the PSU. Is the female PCIE connector on my PSU non-standard? Do manufacturers take liberty with making their own connector on the PSU side?
    YES and you Can Not Mix Them.
    The Device you are plugging them into is Standard but the Power Supply End is NOT Standard.
    Power Supply is to old now and you most likely will not be able to get the correct cables for it.
    https://www.amazon.com/Ultra-U12-42466-Modular-Supply-SLI-Ready/dp/B00ITA1QGU
    post edited by bcavnaugh - 2019/02/01 15:33:53
    Eagle Lake Wood
    Re: GTX 1080 Hybrid - correct power cables 2019/02/01 15:42:20 (permalink)
    Thanks for the replies everyone. I didn't have any luck trying to locate the cables for the Ultra PSU, so it looks like I'll have to get a new PSU.
    Any recommendations on a decent low cost psu? A 750 perhaps.
    the_Scarlet_one
    formerly Scarlet-tech
    • Ribbons : 79
    Re: GTX 1080 Hybrid - correct power cables 2019/02/01 16:07:23 (permalink)
    Seasonic and EVGA seem to have good reputations for power supplies.  What is your budget?
    • Ribbons : 282
    bill1024
    • Ribbons : 65
    Re: GTX 1080 Hybrid - correct power cables 2019/02/01 16:25:39 (permalink)
    If you can wait until next Wednesday, EVGA has some really good deal on their B-stock PSUs.
    The sale price and often with free shipping on several PSUs on Wednesday.
    I have bought several, 650 to 1000w and only had one I had to send back.
    EVGA, Seasonic, XFX pro series. I even have an Antec platinum that has been good to me over the years.
    Best advice do not cheap out, go gold or platinum. Better quality and save on energy cost.
    Here is EVGA's b-stock page
    https://www.evga.com/prod...roductlist.aspx?type=8
    kidroc666
    Re: GTX 1080 Hybrid - correct power cables 2019/02/09 16:15:43 (permalink)
    Yeah that was comp usa's house brand it looks like there not making them anymore. never ever mix and match PSU cables they might look the same but there not!!!
    AMD-RYZEN-7-1800X@-4.0@-1.35
    32-GB CORSAIR VENGENCE RGB@3200@1.36
    PSU-EVGA GQ-1000
    CORSAIR-HYDRO-115-I-PLATINUM-280-ARG
    MSI-CARBON-PRO-GAMER-AM4+
    COOLER MASTER HALF-932-MODIFIED
    EVGA 1070-SC-BLACK@ STOCK-CLOCKS
    ASMEDIA USB 3.1 ADD-ON
    LG-BLUE-RAY BURNER
    SAMSUNG-EVO-970-PRO-250-GB
    X2-PIONEER-1TB-SSD-RAID-0
    X-2-WD-BLACK2TB-RAID-0
    CORSAIR K-68-RGB-KEYBOARD
    CORSAIR-DARK-CORE-RGB-MOUSE
    46INCH LG-4K-HDR
