GTX 1080 ACX 3.0 Buzzing noise & fan revving
df2rools
2016/06/09 12:06:57 (permalink)
Just got the card. Rise of the tomb raider with VXAO enabled makes the game crash every time, did not happen with 980ti ftw as i remember.
But the bigger issue is the NOISE oh my god the noise coming from the graphics card. even when the fans aren't spinning, if im not on the desktop its there.
whether its in an in-game menu or in game or benchmarking the buzzing ear bleeding noise is there. The fans seem to rev up and down which can be heard and also seen in GPUz with big sudden spikes and going back to normal as can be seen in the screenshot in fan speed(RPM) line.
it gets to 2.0-2.1ghz
Oh my god the noise.
I7 5930k @4.4 | EVGA GTX 1080 ACX3 | x99 Extreme4/3.1 | 32GB DDR4 quad channel | Corsair AX1200i | H115i
74 Replies Related Threads
    VegetaCreeper
    • Ribbons : 9
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:10:14 (permalink)
    It shows that the fans are going 100% most of the time.  That's why its so loud?!
    Be The change in the World you want to see
    Use my associate code if you want to save money on your purchases: DIC39SVDZOR8D11
    df2rools
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:12:10 (permalink)
    VegetaCreeper
    No, even when the fans are not spinning it is buzzing. That screenshot is just to show the fans revving when set to 60% or 80%.
    I think its most likely coil whine.
    xxthe_remedyxx
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:12:17 (permalink)
    Do you have the fans set to 100% manually?
    xxthe_remedyxx
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:13:23 (permalink)
    df2rools
    VegetaCreeper
    Is it like a screeching sound during load? Does the sound go away when you're just idling on the desktop?
    Phase3_Blad3
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:14:05 (permalink)
    df2rools-snip-
    It seems odd to me that the fans are 100% and the temperature is 80*C.  Make sure the card is getting good air flow from the front of the case - it is running hotter than the FE!
    i7-4770k - Corsair H90 - Asus Maximus VI Formula - 32GB DDR3 RAM - 2 x EVGA Geforce GTX 1080 - EVGA SuperNOVA 1000 G1 Power Supply
    df2rools
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:15:16 (permalink)
    xxthe_remedyxx
    df2rools
    VegetaCreeper
    Its fine on desktop, no whining/buzzing. When i enter a game (overwatch, rise of the tomb raider, start EVGA scanner) or even in the menus of overwatch and rise of the tomb raider it starts buzzing/whining.
    If I set it to fullscreen and i tab in and out it starts as soon as i tab in, as soon as i tab out to desktop it does not whine/buzz. It is driving me in-sane.
    crezno
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:15:59 (permalink)
    I have my fans set to run at 100% by 70C.  Doesnt hit 70C often but when it does i dont hear my fan.  I dont hear a buzz either.  Probably coil whine you are hearing, i have had some cards with very loud coil whine before.
    If your fan speed is sporadic, the newest Nvidia driver for Win 10 fixes that.  But your fan looks to be stable.
    xxthe_remedyxx
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:16:14 (permalink)
    df2rools
    xxthe_remedyxx
    df2rools
    VegetaCreeper
    Sounds like coil whine. What type of PSU are you using? Is it still the CoolerMaster 1200W? If so, what model?
    Miguell
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:16:41 (permalink)
    it is that loud?
    my with ACX is loud indeed...
    if you have android on your cell then go to play store and install a free decibel mesure software.. then..
    put that beast on load... ( play some high end game)
    place your cell on your desk and send us the results...  it should be interesting.
    Case: Cooler Master Stacker 830
    Display: 32" AOC Q3279VWFD8 @2560x1440@75Hz
    Cpu: Intel Core i7-8700
    Cpu Cooler: Cooler Master - MasterLiquid ML120L - RGB
    Mobo: Asus ROG Strix Z390-H Gaming
    Vga: Asus Dual RTX 4060 Ti 16GB Advanced Edition
    Ram: 32GB DDR4  G.SKILL - RIPJAWS V @3200Mhz
    Sound: Hama uRage soundZbar 2.1 Unleashed  - (Optical)
    Storage: 500GB SSD M.2 A2000  NVMe  Kingston (OS) + 8TB (4+4) HDD X300 Toshiba (Data)
    Psu: SeaSonic M12 700W
    Os: W10 Pro 64Bit
    df2rools
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:17:07 (permalink)
    Phase3_Blad3
    df2rools-snip-
    No at 100% fan speed the temp is about high 60s even OCd if i remember correctly. The GPU-z log is over a long period of time when i was trying different fan settings and speeds. It gets to 80C if left at default I think, usually mid 70s at stock settings.
    Phase3_Blad3
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:17:14 (permalink)
    df2rools-snip-
    If I were you, I would call EVGA support immediately and troubleshoot - sometimes they are familiar with the issue and can help you solve it.
    Otherwise, you should RMA the card as that is definitely not normal.
    • Ribbons : 282
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:19:35 (permalink)
    df2rools
    Welcome to the Forum df2rools
    Don't Overclock so high or put your card under water a custom loop or an AIO Unit.
    post edited by bcavnaugh - 2016/06/09 12:22:58
    xxthe_remedyxx
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:20:29 (permalink)
    df2rools
    Good point. Is the whine there under normal clocks?
    df2rools
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:23:39 (permalink)
    xxthe_remedyxx
    df2rools
    Yes.
    and yes im using the corsair ax1200i. I had a 980ti ftw and a gtx 780 before and those are 250W+ cards. I'm using the june 7th drivers.
    • Ribbons : 282
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:25:55 (permalink)
    xxthe_remedyxx
    df2rools
    The Noise is Fan noise not Coil Whine.
    But by weeks end you will see all kinds of users posting about how bad the Coil Whine is on the 1080 cards.
    xxthe_remedyxx
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:35:14 (permalink)
    xxthe_remedyxx
    df2rools
    When I say "whine" I'm referring to the noise he's experiencing. We're still trying to determine where the noise is actually coming from.
    Here's a test. Make sure your machine is idle on the desktop, launch Precision and set the fans to 100%. Is this the noise you're referring to, or is it a different type of noise?
    post edited by xxthe_remedyxx - 2016/06/09 12:38:21
    df2rools
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:41:30 (permalink)
    xxthe_remedyxx
    df2rools
    I don't know how to type this differently or say it in other words:
    The fan is NOT the noise.
    Even when the fans aren't spinning, as the ACX3 can do, it is buzzing. It is NOT the fan noise.
    I managed to take a quick video for anyone thinking its the fan thats spinning, you can clearly see the fan isnt spinning.
    the video doesn't do justice for the amount of noise im hearing.
    https://youtu.be/7rBLztIX9rQ
    xxthe_remedyxx
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:44:44 (permalink)
    df2rools
    xxthe_remedyxx
    df2rools
    If your card wasn't under load in this video, then you have a defective card. If it WAS (which I don't think it was becuase your fans weren't spinning), then that's coil whine.
    ragevirusqq
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:45:32 (permalink)
    Holy Cable management!
    df2rools
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:46:33 (permalink)
    Here is the same position when it is in desktop.
    Again, fans are not spinning, and my system is quiet. No noise when in desktop.
    https://youtu.be/luqZmvNjI9o
    xxthe_remedyxx
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:47:40 (permalink)
    df2rools
    Again, fans are not spinning, and my system is 100% quiet. No noise when in desktop.
    So in the first video, you were in a game?
    VegetaCreeper
    • Ribbons : 9
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:47:46 (permalink)
    Record a video of the sound with a cell phone and upload the video, so we can evaluate and determine if you are indeed having coil whine or simply loud fans (because they have been at 100%).
    #23
    RandyRick
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:48:17 (permalink)
    so, if you have it set to 1990 mhz it doesn't make the noise? The noise only occurs when you raise the clock above 2ghz?
    #24
    df2rools
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:48:49 (permalink)
    xxthe_remedyxx
    df2rools
    In the first video I was in Rise of the tomb raider menu. It happens both in menus and in-game. Desktop is where it does not happen.
    RandyRick
    Noise no matter the clocks. Desktop no noise, in game,  noise.
    #25
    xxthe_remedyxx
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:49:59 (permalink)
    df2rools
    xxthe_remedyxx
    df2rools
    That's coil whine son.
    #26
    • Ribbons : 282
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:52:23 (permalink)
    df2rools
    xxthe_remedyxx
    df2rools
    IMAGE Removed
    Sorry, then you should have said Coil Whine as I said above it would not take long.
    As far as the fan revving it is a known Driver issue and NVIDIA is working it.
    "Oh my god the noise." you really are not that clear from where the noise if coming from.
    Still all in all allow your card to run a few days if you can 7x24 running heaven benchmark tool to break in your new card.
    Nothing more then a repeat of the Coil Whine that the last 3 Generation have had from high end NVIDIA Graphics Cards.
    #27
    xxthe_remedyxx
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 12:55:39 (permalink)
    df2rools
    xxthe_remedyxx
    df2rools
    IMAGE Removed
    He's using the latest drivers Nvidia released that addressed the revving.
    #28
    df2rools
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 13:01:14 (permalink)
    xxthe_remedyxx
    df2rools
    xxthe_remedyxx
    df2rools
    It's the loudest thing i've heard. I rather not play than hear this. Now unfortunately, I called newegg and they informed me that they do not have these in stock, so if I return it they might give me a refund, or if they have it in stock, they'll give me a replacement. They make their decision 2-5 days after they get it. Which means im stuck with nothing. I can't order from someone else because they might replace it, and I don't want two graphics cards if they do. I'm really disappointed.
    Heres a bigger picture with the fans revving, i circled where it shoots up and then goes back to normal.
    Click to enlarge.
    http://imgur.com/PCLjimW
    #29
    • Ribbons : 282
    Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving 2016/06/09 13:12:04 (permalink)
    df2rools
    xxthe_remedyxx
    df2rools
    xxthe_remedyxx
    df2rools
    Click to enlarge.
    A good reason why I buy from EVGA's Website as they have Cards in Stock for the purpose of RMAs.
    Any Hoot Burn in your Card for a few days and the noise may go away altogether.
    Myself I do not hear any noise from your video https://youtu.be/luqZmvNjI9o
    If your cover is installed and the computer is placed on the Floor do you still hear any noise?
    post edited by bcavnaugh - 2016/06/09 13:15:03
    #30
