VegetaCreeper
- Ribbons : 9
Re: GTX 1080 ACX 3.0 Buzzing noise & fan revving
Thursday, June 09, 2016 8:14 PM
Call Evga Technical Support - They are Fantastic! 1-888-880-3842
Be The change in the World you want to seeUse my associate code if you want to save money on your purchases : DIC39SVDZOR8D11
NIR_Rimc
Thursday, June 09, 2016 8:16 PM
Case: Fractal Define 7 / MOBO: Asus Crosshair VIII Hero(WI-FI) / CPU: Amd Ryzen 9 5950X / RAM: Corsair Vengeance 4x8GB @ 3600 MHz CL14 / Nvme: 2 x Corsair MP600 2x1TB / VGA: EVGA Nvidia GTX 1080 FTW / Monitor: Dell AW3418DW 34'' 3440x1440 120Hz / PSU: Corsair HX 1050W / Sound: Logitech G633 / Keyboard: Corsair K70 RGB MK.2 LP MX Speed / Keypad: Azeron Compact / Mice: Logitech G502 / CPU cooler: Corsair H100i
- Ribbons : 282
Thursday, June 09, 2016 8:28 PM
df2rools
Thursday, June 09, 2016 8:30 PM
VegetaCreeper Call Evga Technical Support - They are Fantastic! 1-888-880-3842
I don't know how they could help with the coil whine, searching online it seems that there is no solution. If I need to RMA I know for sure that newegg will either refund or replace, and I rather do it through them. NIR_Rimc Do you using these drivers? http://uk.download.nvidia...international-whql.exe
Yes, the June 7th 368.39 drivers. bcavnaugh Any Hoot Burn in your Card for a few days and the noise may go away altogether. Myself I do not hear any noise from your video https://youtu.be/luqZmvNjI9o If your cover is installed and the computer is placed on the Floor do you still hear any noise?
Will letting the GPU run over the next few days actually reduce/solve the noise problem or is that a fairy tale? Yes, thats the 2nd video which shows no noise during desktop operation. The first video is the one with noise. putting the side door doesn't make a discernible difference, it is placed on the floor, same amount of noise. I noticed something, if I set Power Management Mode to Adaptive instead of Prefer Maximum and alt tab from rise of the tomb raider and back in, it sometimes gets stuck at 700mhz gpu clock, and it seems to not whine there. In regular gaming mode clocks with 1600/1800 boost it does make the noise, so it seems related to load and GPU clocks.
I7 5930k @4.4 | EVGA GTX 1080 ACX3 | x99 Extreme4/3.1 | 32GB DDR4 quad channel | Corsair AX1200i | H115i
VegetaCreeper
- Ribbons : 9
Thursday, June 09, 2016 8:32 PM
If you upload your invoice and register the card, they would probably swap it right out for a new one - its worth a call! They could probably send you out a new one faster than newegg
- Ribbons : 282
Thursday, June 09, 2016 8:41 PM
VegetaCreeper If you upload your invoice and register the card, they would probably swap it right out for a new one - its worth a call! They could probably send you out a new one faster than newegg
They also do cross-shipping if you want to pay for it.
- Ribbons : 282
Thursday, June 09, 2016 8:45 PM
df2rools
No Fairy Tale, you have about 1000 Posts where users are told to do this and some work and some do not. You must be new to computers to not know that computers have a Burn-in Time, why do you think that Dell and HP make you wait so long to ship out a custom build. They have to Burn it in to make sure all is well with the computer. Only use Prefer Maximum Power.
Stardust_One
Thursday, June 09, 2016 8:49 PM
It's possible that the whine will go away in a few days, - give it a try if you are satisfied with rest of it. + Put the gpu under load. No torture, please!
nike23
Thursday, June 09, 2016 9:01 PM
bcavnaugh Don't Overclock so high or put your card under water a custom loop or an AIO Unit.
I can oc to 2.1 with a custom fan profile set at 60% at 60 degree and the thing never gets above 67 under full load, no coil whine either this card is alot quieter than my titan it replaced...id say he has a bad card if its getting that hot with fans reving up...
- Ribbons : 282
Thursday, June 09, 2016 10:25 PM
nike23
Good for you, the fans revving up... issue is a Driver Issues Stated by NVIDIA and not a Card Issue. Also the OP did not state what the Temperatures are. Each card will run different as the same as how Dice will fall (Role) to the table.
post edited by bcavnaugh - Thursday, June 09, 2016 10:30 PM
XxXNittiXxX
Friday, June 10, 2016 4:42 AM
Holy hell batman the card is probably whining from experiencing your cable management first hand.
Trust, Honor, Respect 18+ Steam/Xfire:Nitti66 Currently enjoying Bad Company 2 MP
df2rools
Friday, June 10, 2016 4:46 AM
At this point I'm really disappointed in EVGA. I gave the brand multiple chances. My EVGA GTX 580 had artifacts and crashing which was well documented in these forums, support didnt want to help me, and I never got the rebate that I filled correctly. The GTX 980 ti FTW I bought a few months ago I didn't get the division code that was promised, again I contacted support and they did not help. I told myself I wouldn't buy another EVGA, but this was in stock on newegg, it was cheap and I went for it, dumb mistake. 3 cards 3 bad experiences, I've had 2 other brands and had zero problems with them.
trek554
Friday, June 10, 2016 5:07 AM
hmm now I am a little worried about even opening mine. I really do not have good luck with EVGA. even tried a 750 ti from them and the damn thing would drop to desktop idle speeds at times in some games. sent it back and got a Zotac 750 ti that works perfect.
Win 10 Pro | i9 9900KF | MSI Gaming Pro Carbon AC | FE RTX 3070 | G.SKILL 32GB DDR4 3200 CL14 | Samsung Evo 860 4TB SSD | Phanteks P500A | Seasonic FOCUS GX-1000| Sound Blaster Zx
Antykain
Friday, June 10, 2016 5:19 AM
df2rools At this point I'm really disappointed in EVGA. I gave the brand multiple chances. My EVGA GTX 580 had artifacts and crashing which was well documented in these forums, support didnt want to help me, and I never got the rebate that I filled correctly. The GTX 980 ti FTW I bought a few months ago I didn't get the division code that was promised, again I contacted support and they did not help. I told myself I wouldn't buy another EVGA, but this was in stock on newegg, it was cheap and I went for it, dumb mistake. 3 cards 3 bad experiences, I've had 2 other brands and had zero problems with them.
Sorry you feel this way and the bad luck.. Myself, I have never had an issue with EVGA's support. As a matter of fact, the few times I've had to use EVGA support to troubleshoot or start an RMA process, it was very smooth and went through quickly. One of the reasons I am using EVGA to this day and will continue with any future products ( DG-8x Series Gaming case, yes please.. :). EVGA's support is top-notch in my book. The best I've dealt with.. period. Anywho, do as the others have said.. let the card have a little break-in period. If the issue persists after a period of time still, then consider contacting EVGA support and start the process with them. I definitely would not recommend going through Newegg.com RMA process. You'll be without a card and a replacement for a longer period of time. Trust. Something to think about.. Coil whine is, hate to say it, not really seen as a issue worth RMA'ing a card to most GPU manufacturers and some will not even consider fufilling an RMA due to coil whine.. Extreme cases may be different of coarse. :) Good luck bud!
post edited by Antykain - Friday, June 10, 2016 6:07 AM
Rig Specs: ASUS Maximus XI Hero Z390 | Intel i9-9900k 5.1GHz | EVGA RTX 3080 Ti FTW3 Ultra | Corsair Dominator Platinum 32GB 3600MHz | EVGA SuperNOVA 1000 P6 | Samsung 970 EVO Plus 2TB NVMe | Samsung 970 EVO Plus 1TB NVMe | Samsung 860 EVO 1 TB | EK Custom Watercooling Loop | 2x Viewsonic Elite XG270QG 27" 1440p
XxXNittiXxX
Friday, June 10, 2016 5:32 AM
Why doesn't evga just use decent capacitors? They've had this issue for a while now, I remember having the issue with my 200 series card.
- Ribbons : 271
XxXNittiXxX Why doesn't evga just use decent capacitors? They've had this issue for a while now, I remember having the issue with my 200 series card.
You mean inductor. The inductors are whining. The the card uses tantalum capacitors. Tantalum capacitors don't have electrolyte, don't have vents, don't fail in the same way that electrolytic capacitors fail, and do not hiss. "Capacitor squeal" does not apply to this product. The answer to your question must be something similar to: The profit made by selling the product with cheaper inductors must apparently outweigh the cost of replacing a larger percentage of video cards with unacceptably loud inductors. If EVGA's replacement rate due to loud inductors was too great that it affected their profits, they would make necessary changes. Apparently they haven't felt the need to make necessary changes.
post edited by ty_ger07 - Friday, June 10, 2016 6:25 AM
Antykain
Friday, June 10, 2016 6:19 AM
Inductors
^^ This.. The coil inductors are where the coil whine is coming from. It's like a hyper-fast resonance in the coil, err inductor, causing the 'whine'. Saw a video a long while back with someone inducing different GPU loads and creating a song of sorts with the coil whine. Almost reminded me of the Formula-1 engine songs. lol
trek554
Friday, June 10, 2016 7:12 AM
well I finally installed mine and can report no issues after 30 minutes of testing so far.
trek554
Friday, June 10, 2016 8:02 AM
well I take back what I said about having no problems. two different times the gpu has dropped down to very low speeds in Rise of Tomb Raider for no reason. one time was after I alt tabbed but another was on a fresh launch of the game and it never went to full clocks. great job EVGA...
post edited by trek554 - Friday, June 10, 2016 8:21 AM
redgooner
Friday, June 10, 2016 8:16 AM
XxXNittiXxX Holy hell batman the card is probably whining from experiencing your cable management first hand.
Best quote I have seen this week. Was thinking the same...
D-007
Friday, June 10, 2016 8:23 AM
Nice, they release overpriced GPU's and can't even get the fans right.. Bravo.. Bravo.. They really stuck it to us this time..
If you ain't living on the edge, you're takin up too much room.
redgooner
Friday, June 10, 2016 8:46 AM
That's why I wait a month after release, and let others Gamma Test.
stalinx20
Friday, June 10, 2016 8:48 AM
So glad I'm waiting at the end of the year for these cards. redgooner That's why I wait a month after release, and let others Gamma Test.
It's more like "Alpha" testing.
post edited by stalinx20 - Friday, June 10, 2016 8:51 AM
goldi3
Friday, June 10, 2016 8:49 AM
trek554 well I take back what I said about having no problems. two different times the gpu has dropped down to very low speeds in Rise of Tomb Raider for no reason. one time was after I alt tabbed but another was on a fresh launch of the game and it never went to full clocks. great job EVGA...
But this is a NV driver problem and not a EVGA Problem!!! @ topic When i look the youtube videos, I would say maybe the ball bearing is damaged, or the motor is damaged. Why? Look at the fan blades they wobble. And this could be the high peeks in the monitoring graph. The motor wants to start but has not enough power. So increase the voltage and this is the noise your hear. How could it be damaged? Maybe when you installed it in your system.
stalinx20
Friday, June 10, 2016 8:52 AM
Are you maintaining the desired FPS when the card's speed drops, with no drops in FPS while the card slows down? if so, then the card is doing its job. What resolution are you at?
post edited by stalinx20 - Friday, June 10, 2016 8:57 AM
- Ribbons : 271
goldi3 @ topic When i look the youtube videos, I would say maybe the ball bearing is damaged, or the motor is damaged. Why? Look at the fan blades they wobble.
The wobble is normal. All EVGA ACX video cards with "dB Noise Inverter" fans do this when they are "off". The wobble does not create an audible sound.
trek554
Friday, June 10, 2016 8:56 AM
stalinx20
Are you maintaining the desired FPS when these cards' speed drops, with no drops in FPS while the cards slow down (assuming you have SLI)? if so, then the cards are doing their jobs.
I am not some noob but I guess I should have been more clear. the clocks drop very low for no reason at all. the memory alone drops to just 810 mhz and of course framerates plummet down to low teens. I have to restart the game for the card to act right. so far this problem has only occurred in that one game but I did see another person having similar issues on guru3d.
stalinx20
trek554
stalinx20
NO need to be a tool. A simple question deserves a simple answer. Remove the pole sir. Ok... clearly its the drivers. You'll have to wait till Nvidia does some fixing. Have a good day... sir.
trek554
Friday, June 10, 2016 9:01 AM
stalinx20
trek554
stalinx20
NO need to be an tool. A simple question deserves a simple answer. Remove the pole sir.
perhaps you should read a little closer before commenting next time. I was not being a damn tool and simply was saying that I should have been more clear about the performance drop so as not to look like a noob.
df2rools
Friday, June 10, 2016 3:01 PM
Okay, I've left it overnight and slept in a different room. It's still noisy as all hell. And to the guy posting about tomb raider clocks, I had the same experience with low clocks. It either goes to 700mhz or gets completely stuck at 1607 which is the normal clocks with 0 boost and just stays there no matter what, and also enabling the very last AO option, VXAO, just crashes the game. but this isn't really my concern, its the noise that is. I gave it my best and tried the only "solution" that the forum/thread came up with. Three bad experiences with EVGA. I don't care anymore if I return it and get an offer of $500 for an evga gtx 1080, im done. Going to box and ship it back in a few hours. Won't recommend it to anyone in our shop, and most certainly wont recommend EVGA to my friends.
